Elektron Musical Instruments
Index last updated: 2026-04-28 23:22 UTC
Broken SID
Broken SID
2005-03-07 by ofthicktum
Hi
I stupidly used the wrong transformer in my SIDStation (all those ugly wallwarts look the
bloody same).
After opening up my SID there is a faint but ominous burnt smell.
I emailed Elektron they said it is probably a burnt out regulator. Has anyone had a smilliar
problem to this? Unfortunately my SIDStation is no longer under warranty so I am hoping it
won't be too expensive.
Kin regards
D
Re: [elektron] Broken SID
2005-03-07 by Rob Muller
The same thing happened to me - because the plugs for my Machinedrum
and Sidstation both look exactly the same. I'm going to look into
getting mine fixed locally, because the shipping cost to Sweden from
Australia and back are too prohibitive. Don't worry though - I emailed
Elektron and they said the Sid chip should be fine. :)
Unfortunately I haven't got it fixed yet, but I'd be interested to
hear how you go & how much it costs.
Cheers!
Rob.
On Mon, 07 Mar 2005 21:08:10 -0000, ofthicktum <electrodavid@...> wrote:
> Hi
> wallwarts look the
> bloody same).
> I am hoping it
> Kin regards
> D
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/elektron-users/
> elektron-users-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-03-07 by Graham
> Hi
> wallwarts look the
> bloody same).
> so I am hoping it
If it is just a regulator then they are pretty cheap themselves.  If you are
not familiar with replacing components on a printed circuit board then pass
it on to someone who has experience in this area.  *DO NOT* attempt to
repair it yourself if you are not 100% sure you are capable of performing
this.  If you do try and make a mess of it, it is highly unlikely that
anyone else will take on the job to undo your "fix".
A professional repair should not cost too much assuming that is all it is.
Re: Broken SID
2005-03-09 by Mark Rivera
> bloody same).
Depends on what they mean by 'regulator'.. There are chips called
'voltage regulators' that take in DC power (like 9V or so) and turn it
into something clean and usable by the surrounding hardware -- like 5V.
If that's all it is, the part is cheap.
What actually happened? Did it turn on and work for a while and then
shut off? Did it never turn on at all? etc... What kind of adapter did
you plug into it? Was is DC or AC, what voltage? And what is the voltage
of the SID's standard adapter?
Mark
Re: [elektron] Re: Broken SID
2005-03-09 by Don't t(h)read on my tentacles, Earthlin
Ditto
> voltage
Ditto
I may add, beside the regulator, other parts may be burned like caps.
Anyway, save if something expensive is carbonized (ICs, the CMOS SID)
it's more a time consuming fault tracking job/desolder/resolder.
Denis =G)
