Disklavier
Index last updated: 2026-04-28 23:20 UTC
dkvutilities
dkvutilities
2005-08-03 by dwnunderoz
Hi Folks, I've recently joined this group and have read some of the
past correspondence between members and am impressed with the
knowledge people have.
I have an Upright MX95 (serial # 4959049) which has a separate not
built in Yamaha DKC5R Control Unit. The unit uses 720K 2DDformatted
disks in ESEQ and has a MIDI function. Thanks to you guys I've been
able to download a few MIDI tunes and play them through my PC
running Windows XP Professional. I've also downloaded the
dkvutilities program containing ESEQ Explorer, MID2ESEQ and
ESEQ2MID,Veloset & dkvcopyI and need help with this.
I'm trying to Copy downloaded FIL files & MIDI files on to  floppys
I can play through the Control Unit but am not getting anywhere
despite following the readme instructions that came with the
dkvutilities program. I'm not getting to first base.  I can't seem
to format 720K discs on my PC. The Format option in Windows is set
to 1.4 and does not allow any other format option to be made; Can't
format through Windows DOS. I've tried changing the BIOS (during
boot up) to the 720K format option but the PC looks for a 5.25
drive. I've tried the different options in the floppy bios setup to
no avail. If I format a disc in the Control unit the PC cant read
it – says unformatted disc. At the risk of boring people, I would
appreciate someone guiding me through the steps I should take on the
PC to achieve the format process that will allow me to convert MIDI
and TIF files to the ESEQ the Disklavier will read.
Stafford Whitwell
Re: [disklavier] dkvutilities
2005-08-03 by Danny
 I can't seem
This is a subject that has come up here several times with differing solutions,
some that would work and others would not. Windows XP supports most 'older'
items that the old versions of Windows had, but apparently, this was one item
that was removed; the capability of formatting  3.5" 720K diskettes...
Here is one solution that you can try that was posted a couple of years ago by
Chine-Chine Wang:
Please allow me to add on to this excellent method to format 720k disks
- the easiest way to do this in Windows XP is this:
   1. Click on "Start"
   2. Select "Run"
   3. Type in "cmd /k format a: /t:80 /n:9" (without the quotes) and hit Enter.
   4. Follow the prompt (insert DD floppy and hit Enter).
The beauty is that the next time you need to do this, the long command
will be remembered in the previous commands of the "Run" box (as
pull-down selection), as long as you're logged in on the same computer
as the same user.
You can use other alternatives such as a batch file or a shortcut to
execute this (assuming that, like me, you sometimes have trouble
remembering seldom used DOS command switches), but the run box takes the
least effort.
Danny
2005-08-04 by Stafford Whitwell
Many thanks Danny for your information - yes yes it worked ! The first disc I tried was formated with the Control Unit but came up on the PC with "Invalid Media or track O bad - disk unuseable". I tried another disc and I've been able to copy these to the floppy OK and the Disklavier plays them. Now I'll have to address converting the Midi fles to floppy. Thanks again
Danny wrote:
I can't seem
Chine-Chine Wang:
1. Click on "Start"
2. Select "Run"
as the same user.
least effort.
Danny
Do you Yahoo!?
Try Yahoo! Photomail Beta: Send up to 300 photos in one email!
