Re[6]: [disklavier] playing from excel
2016-12-18 by Spencer Chase
there has not been enough interest to justify the time it would take to put this all together. i wrote a while ago explaining how to do this with programs currently available on my website. i am pasting that information again here.
the method can be tested by downloading the "keyword tools" and also the keyword to excel program from the download page of my web site. The keyword lister will only list keyworded text events which follow the format name: value. this is explained in the doc included withe the keywords tools zip. it also list track names which are the most common way people add meta data. there are too many other ways to add meta data so i only bother with these two to avoid overload of information. i can modify the program if anyone has a favorite text type they would like to add to the list.
the current version of the programs default to the working folder which is convenient. i believe that the versions on the web site use a default folder which can be created and used or it can be changed each time the program is run. to update this zip with the current version and make sure the documentation is correct will be a little work which i will only do if there is enough interest.
the web page for downloads is http://spencerserolls.com/Files4Download.html
the keyword to excel program is about half way down the page and the MIDI keyword tools zip is near the end. if you use any of the programs on this site, i recommend getting the latest versions from me if you are really going to use them a lot. i have mad improvements but they are not necessarily documented.
Best regards, Spencer Chase
67550-Bell Springs Rd.
Garberville, CA 95542 Postal service only.
Laytonville, CA 95454 UPS only.
21220 92nd Place W., Edmonds, WA 98020
Spencer@...
Spencer@...
Spencer@...
http://www.spencerserolls.com
http://www.poodlex.com
(425) 791-0309
(707) 223-8212
Spencer@...
Spencer@...
Spencer@...
(425) 791-0309
(707) 223-8212
------ Original Message ------
From: "rightnightboy@... [disklavier]" <disklavier@yahoogroups.com>
Sent: 12/17/2016 11:33:43 PM
Subject: Re: Re[4]: [disklavier] playing from excel
Im interested in such a bundle !
