Good afternoon, everyone.
Fred, the DKC100XG indicates that this is a playback-only grand. In the simplest situation, the DKC-850 can be introduced as a MIDI add-on unit. Personally, I see little to be gained by using the DKC-850 as an add-on unit in this context. You won’t get DisklavierRadio or DisklavierTV, and you’ll lose the floppy drive. You will gain the ability to play MIDI data from a computer via USB, but you currently have the ability to play MIDI data from a computer using a USB MIDI interface. About the only things that you gain are internal song storage plus the ability to play song files from a USB devices, such as a USB flash drive.
If you want to use the DKC-850 as an replacement control unit and enjoy expanded benefits, you’ll need to call Yamaha Piano Service to see what the options are. I know that they have a couple of Mark II-to-Mark IIXG upgrade kits available. Anyone who upgrades a full function Mark II to a Mark IIXG can then replace the control unit with a DKC-850. I am not sure if this is an option in the case of a playback-only model. It is hypothetically possibly that all you need are a couple of replacement circuit boards in order to be able to proceed to adding the DKC-850 as a replacement control unit. Best to discuss this with Yamaha Piano Service: (800) 854-1569
I have a DKC-850 on my piano, and I have a couple of inexpensive, 3rd party USB floppy drives that work just fine with it. However, many USB floppy drives do not. Personally, I would use computer software to convert all of my floppy disks to files that I store on my computer and then copy them to USB media.
PianoBench
> On Dec 26, 2014, at 2:11 PM, thepianoman@comcast.net [disklavier] <disklavier@yahoogroups.com> wrote:
> Hello,
> I have a customer with a DKC100XG that is thinking about upgrading to DKC850. Can anyone verify that this would be a replacement install as opposed to an add on through MIDI?
> Also the floppy drive doesn't work on the 100XG and it seems that last time I checked the cost of a replacement drive was around $400?
> Thanks
> Fred Brown RPT
