Disklavier
Index last updated: 2026-04-28 23:20 UTC
Troubleshooting dead MX100A
2014-02-17 by <ataschner@...>
Hi
I bought a used Yahama Disklavier MX100A around 1990, which is also able to record.
Unfortunately some years ago it got ill...
First it froze around 10-15 seconds into the tune, later it would only spin the diskette and then it stopped even spinning up the diskette drive. There is nothing in the display and the digital display shows 00.
Is anybody on this forum familiar with any commonly known "problem components" or child diseases for this first version of the product ? Perhaps we could save some time and gray hairs ... :-) A friend has offered to help try and fix it and I am working on getting a field service manual in another forum.
TIA
Andreas
RE: Troubleshooting dead MX100A
2014-02-18 by <rkhleunghk@...>
hi,
if you have any problem finding the maunals, i actually got them. let me know if you need them and i can email it to you.
cheers
ray
Re: [disklavier] Troubleshooting dead MX100A
2014-02-19 by mangez@...
The original problem is often associated with faulty solenoids, especially pedal solenoids. If the disk has now stopped playing (i.e you can't see the time count moving), you may also need a new disk drive. You could try disk drive cleaning kit first.
On Feb 17 2014, ataschner@... wrote:
Hi
TIA
Andreas
2014-02-19 by <ataschner@...>
Thanks.
I have tried replacing the diskette drive, but still nothing happens. Nothing shows up in the display - it seems completely dead except that the display is turned on and the digital display shows 00. Trying to power on with L and R pressed does not even get it to go to test mode.
