OK - from memory, the trick is to connect a higher value cap in
Parallel with the 47nF cap, so;
* Connect a wire from each side of the 47nF cap to each centre lug of a
DPDT toggle switch.
* Connect a larger value non polarised cap across one pair of outer
lugs. Try a 1uF or bigger.
* Leave the other outer lugs unconnected.
* OR: If you have a centre-off type DPDT switch, try connecting a
different value cap across the other outer pair, for even greater range
changes. If doing this, you might want to experiment with decreasing
the 47nF a bit for faster MAX speeds.
The 10K resistor between the wiper of the 500K SHAPE pot and pin 2 of
the TLO74 can also be increased to lower the MINIMUM speed.
For some very slow sweeps, I increased the 10K up to as much as 1M2,
and used a 1uF cap. There is a relationship between the two which can
affect the waveshape at extremes of speed - again, this is from
memory....
Lastly, changing the 4K7 to GND from the SPEED pot has an effect on MAX
speed.
Hope this helps. :-)
cheers,
Dave
On 16 Oct 2012, at 20:51, sirolffoonav wrote:
> Great it will clock too.
> Haven't found timing info on electro-music.com and muffwiggler search
> function seems to be out. any wild guess is welcome too. I'll have to
> install a resonant gate first tonight.
> --- In cgs_synth@yahoogroups.com, Dave Kendall <davekendall@...>
> wrote:
> > Hi.
> > On 16 Oct 2012, at 07:54, sirolffoonav wrote:
> > > Looking forward to handy extra modulation with this module! How
> fast
> > > or how slow would the LFO go with just the 47n cap and no mods?
> > > I'd love to have it at least from around 30 seconds to almost
> audio.
> > > Will this go without mod? Curious for other cap speeds too.
> > Have a look on the muffwiggler.com DIY forum, and on
> electro-music.com
> > DIY forum - there's a wealth of information in there about modding
> the
> > CGS LFO.
> > Do a search - (you need to be logged into Muff's to do this) and all
> > sorts of goodies will turn up.
> > Short answer, wire a DPDT switch with an extra cap(s) across the
> timing
> > cap, and you can go reeeeaaallllllyyyy sssslllllloooooooowwwww.
> > You can get non-polarized 3.3uF caps quite cheap nowadays.....
> > > I'll only use the vari outs for now. This way all the knobs
> (speed,
> > > shape, vari) will affect the lfo, no?
> > > And is it still possible to trigger the cgs programmer/sequencer
> > > while running the LFO on 12V (80%) with a very narrow
> pulse/square?
> > Most CGS modules have comparators on their CLOCK and TRIGGER
> inputs, so
> > the answer is very probably yes :-)
> > cheers,
> > Dave
