Cgs synth
cgs75 hot voltage outputs
2011-09-13 by scozbort
Hi!
Can't believe I only just found this place...
I'm having an issue with my VCS build and hoping someone has come across it before.
When I use the trigger in and slow fall times the module outputs very hot voltages - I think it would go to 15v if I let it.
But in cycle mode it outputs normal voltages.
I suspect a wiring fault but I can't see any mistakes, unless of course I have misunderstood how to wire it up - which is likely!
Hoping its an easy fix and thanks in advance
- Kevin
Re: cgs75 hot voltage outputs
2011-09-22 by scozbort
OK here is some more info.
Most people seem to have difficulty with the transistor pin-outs not matching the circuit. I don't think this is the problem here. The module functions perfectly (except for hot output), and the transistors were supplied in an Elby kit. I have emailed Laurie to see if the transistors he supplied are correct (can't seem to find a datasheet for them).
Also the calibration trimmer does offset the hot output voltage, but no where near enough. I was wondering if a 20 turn trimmer here would allow me to drop the voltage of the output right down whilst still maintaining the correct triangular waveshape?
Like I said it only outputs high voltages when its being triggered.
It's completely useful as it is, I just have to attenuate the output. Not comfortable send 15v signals around the modular. Or do I not need to worry about this at all? I know it distorts my VCAs pretty quick.
Any help much appreciated!
- Kevin
--- In cgs_synth@yahoogroups.com, "scozbort" <kevin.babbage@...> wrote:
> Hi!
> - Kevin
2011-09-22 by Elby Designs
The END OUT output should be clamped to 5V because there is a zener diode in
that line. If that is the output you are having problems with then the zener
is either faulty, not fitted, or the wrong value.
The OUT output doesn't have any such protection and it is feasible for the
output to approach power rail levels as it is driven directly from the
output of an opamp. I will need to study the front end more to determine if
there is any internal clamping but it might be worth asking Ken what are the
normal output levels to be expected. Maybe this output needs a simple
resistor divider.
The transistors are standard and should fit the pcb as is.
The only other problem I can see is that Ken has 4 x 220K listed in his BOM
and then says in the text that they should be 22K. I have supplied 220K
Best Regards
Laurie Biddulph
Mobile: 0400 257 645
Web: www.elby-designs.com
From: cgs_synth@yahoogroups.com [mailto:cgs_synth@yahoogroups.com] On Behalf
Of scozbort
Sent: Friday, 23 September 2011 6:43 AM
To: cgs_synth@yahoogroups.com
Subject: [cgs_synth] Re: cgs75 hot voltage outputs
- Kevin
> Hi!
it before.
> - Kevin
The CGS Modular Synth home page: http://www.cgs.synth.net/
Yahoo! Groups Links
Cheers Laurie, I appreciate you input!
Its the main OUT that gets hot. And I'm using a REV1.0 PCB so the 220k resistors should be correct. I thought about sticking a resistor on the output but that would affect the cycle out as well, which does not need attenuation.
Its sounding more like its functioning perfectly. Am I being over-cautious worrying about throwing (potentially) 15V slopes around the system?
- Kevin
> resistor divider.
> Best Regards
> Laurie Biddulph
> -----Original Message-----
> Of scozbort
> - Kevin
> --- In cgs_synth@yahoogroups.com, "scozbort" <kevin.babbage@> wrote:
> > Hi!
> it before.
> > - Kevin
2011-09-22 by Richard Brewster
It is not functioning right if the output swings to +15V when cycling.
Ken's notes:
Adjustments on the VCS board are set to obtain a 0 to +5 volt level when
the unit is cycling, producing a 100Hz triangle wave. An oscilloscope is
required for this adjustment. In an oscilloscope is not available,
adjust for the least distorted sounding waveshape.
I guess that he means the single trimpot by "adjustments on the VCS
board". I built two of these and did not have any problems.
Richard Brewster
http://pugix.com
> - Kevin
>> resistor divider.
>> Best Regards
>> Laurie Biddulph
>> Of scozbort
>> - Kevin
>> --- In cgs_synth@yahoogroups.com, "scozbort"<kevin.babbage@> wrote:
>>> Hi!
>> it before.
>>> - Kevin
>> Yahoo! Groups Links
That's the thing! When cycling it does produce around 5v. But when triggered externally it can get right up to 15v. But only with long fall times. Its like each successive trigger adds to the voltage when using long fall times.
> Ken's notes:
> Richard Brewster
> http://pugix.com
> > - Kevin
> >> resistor divider.
> >> Best Regards
> >> Laurie Biddulph
> >> Of scozbort
> >> - Kevin
> >>> Hi!
> >> it before.
> >>> - Kevin
> >> Yahoo! Groups Links
2011-09-23 by sasami@hotkey.net.au
A 20 turn trimmer will not increase your range of adjustment.
Most modulars would be unphased by seeing 15 volts at an input. Remember
that this voltage is current limited by both input and output resistors. For
example, the Serge is stated as being able to handle 25V at its inputs
without issue. It won't worry any of my designs either.
I would avoid plugging a hot voltage into an Analog Solutions module though!
I don't know the cause of this. It may in fact be operating correctly for
what you are doing to it. At the moment I am not in a position to test this
out myself.
Ken
> - Kevin
>> Hi!
it before.
>> - Kevin
>Yahoo! Groups Links
_______________________________________________________________________
Ken Stone sasami@... otherunicorn@...
Modular Synth PCBs for sale <http://www.cgs.synth.net/>
Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
The BOM and overlay are correct. There was a SINGLE 220k that needed to be
changed to 22k, and only on the red version of the PCB.
2011-09-23 by scozbort
Thanks for the info Ken. I've been using it fine with an attenuator on the output. I'm have mostly Frac and DIY modules, with 1 Euro and 1 or 2 DIY running on 12V, so I will just watch it with those ones. I will keep an ear out for anyone else experiencing the same thing, but I suspect there is nothing wrong with it. Thanks for making such a great device available!
- Kevin
> out myself.
> Ken
> > - Kevin
> >> Hi!
> it before.
> >> - Kevin
> >Yahoo! Groups Links
