Re: [SPAM] Re: [SPAM] [cgs_synth] CGS48 VCO question
2009-06-22 by sasami@hotkey.net.au
A bead is a ferrite bead on a piece of wire. If you can find one, just use a
wire link. (yes, a piece of wire from an old resistor leg for example).
Ken
Ken
>A couple of clues:capacitors are already in then.
>1) You only need to do the modifications specific to your version of the
>board. Ver 0.2 modifications do not need doing.
>2) Decoupling capacitors are to keep the power rails stable. These parts are
>already on the PCB. You do not need to do anything extra.-Great, the
>resistor? thanks a lot. (I still have the remaining questions below if
>I don't have any V0.4 left, so hopefully someone else can answer the questions.
>-Doh!-One more thing. I don't know what a "bead" is. Is it like a
anyone can help.)steve
>>["Cut the track between Pin 5 of the TL072 in the bottom right corner and_______________________________________________________________________
>the 47uF capacitor. Make the cut near the capacitor."]
>>I can't find anywhere that pin 5 of the TL072 is connected to the 47uF
>capacitor. Pin 5 seems to be connected to a pad that is supposed to be a
>jumper wire. And that's another thing, in the Modifications for version 0.2
>it says to remove the jumper between pin 5 and the WS Trim. Should I still
>not put in the jumper or should I go ahead and do it since this is a later
>version.
>>["Jumper pin 5 to the Saw AC output terminal via a 100k. This will set PWM
>control to 50% at 0 volts."]
>>So, disregard the jumper that's marked on the PC board and just solder in a
>100K resistor between the hole at pin5 and the hole at Saw AC output?
>>["It is possible to place the resistor in place of the link on the PCB
>though the track modification is still required."]
>>I'm not sure what "link" means here.
>>["Replace the 330k resistor near the SYNC pad with a 220k resistor. This
>should stop clipping."]
>>I couldn't find any 330k resistor in this area.
>The CGS Modular Synth home page: http://www.cgs.synth.net/
>Yahoo! Groups Links
Ken Stone sasami@... otherunicorn@...
Modular Synth PCBs for sale <http://www.cgs.synth.net/>
Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
