Cgs synth
Cynare impact /resonance problem
2008-10-08 by Dave
I've built a cynare and for the most part it works fine. I've added
the pots to control the 6 osc pitch and also the impact mod. The
problem I'm having that the impact mod doesn't seem to do much unless
I turn the resonance knob and then the impact sound can be heard for
about 2-3seconds and then it fades away. The filter itself seems to
work ok, the resonance knob turns up the resonance. Any ideas as to
why this is happening? I did have some problems with having the
transistors in backwards, I turned them around and reused them. Is it
possible one of them could be blown?
Dave
Re: Cynare impact /resonance problem
2008-10-08 by sasami@hotkey.net.au
The impact is a very short transition that at best adds a "thud". It is
possible it is working just fine, but you aren't recognising it due to
amplifier/speaker combinations etc.
>Hi,
>Thanks,
>Dave
>The CGS Modular Synth home page: http://www.cgs.synth.net/
>Yahoo! Groups Links
_______________________________________________________________________
Ken Stone sasami@...
Modular Synth PCBs for sale <http://www.cgs.synth.net/>
Australian Miniature Horses & Ponies <http://www.blaze.net.au/~sasami/>
2008-10-08 by Michael Ford
Hi Dave,
Have you increased the value of the 1N impact capacitor ? This is
marked in red in Ken's schematics. I use a 10n here with a 25k pot
and it give a satisfying range of "thwaps."
It shouldn't last 2-3 seconds, are you sure that's not just the
filter ringing ? The impact sound is essentially a click mixed in on
the attack of the drum sound.
Michael Ford
http://www.metalbox.com
On Oct 8, 2008, at 2:01 AM, Dave wrote:
> Hi,
> Thanks,
> Dave
2008-10-10 by Dave
I just replaced the 1N cap with a 10N cap and it sounds good, Thanks
for the tip :)
Dave
--- In cgs_synth@yahoogroups.com, Michael Ford <liquidcolor@...> wrote:
> Hi Dave,
> Regards,
> Michael Ford
> > Hi,
> > Thanks,
> > Dave
