Bc2000 (for the BCF2000 & BCR2000) group photo
Jupiter 80 and Behringer BC
2014-05-16 by spiralout311@...
While the Jupiter 80 has a great touch-screen display, menu diving can be a pain. There is a ipad app for the Jupiter 80 that will give one quick access to editing the oscillators. But has any one added at BCR/BCF2000 to control a Jupiter 80?? Theoretically it should work, correct? What are the steps, tips and tricks on getting it to work?
Re: Jupiter 80 and Behringer BC
2014-05-17 by rpcfender@...
It is relatively straight forward.
First you need to work out just how much (ie how many and what parameters) you want to control. Always the hardest part.
Roland have implimented a good selection CC (continuous controller) actions in their synth since the XV series and some even before.
On the JP80 have a look at the Midi Implementation manual and you will see that it can control a hole heap of general parameters from Vol, pan etc as well as 3 Tone Modify parameters (not sure what they do in the JP80 as I don't have a JP80) as well as a few the Blender
You can turn portamento on and off as well as legato, resonance, cutoff, attack, decay, vibrato rate, delay (read LFO).and depth (LFO to Osc pitch).
All without going near Sysex. So you can program these from the BC itself.
With sysex, of course you can control all the parameters and you will need Mark's editor or if you are happy to write code , my editor.
All the best
Royce
