Bc2000 (for the BCF2000 & BCR2000) group photo
Added a syx fpr AKAI MINIAK
2011-06-18 by sghookings@tiscali.co.uk
Not sure how many people use this, but just incase I added a preset at
http://launch.groups.yahoo.com/group/bc2000/files/Presets/AKAI_MINIAK/
Basically, I tested this against a Miniak, and via Miniaktools (current private beta) to ensure that the screen was updated in agreement with BCR/Miniak.
The BCR and Miniak just about agree. Couple of bugs in MiniakTools have been found, that I will correct.
I hope to improve on this template.
Essentially, because so much of the Miniak (and I guess this template would work with the Micron) is non-standard, I have to use a few tricks.
For example, send LSB for 7bit range NRPN buttons.
But I havent done the trick of a fake easypar to "sync" the ++/-- buttons.
For truely -ve range buttons/encoders you cant use this trick.
Until either Behringer bring out a S14 type, or someone learns how to take Willem's BCR hacking framework and modify the firmware.
It's not a big deal though. I mean, there are sufficient knobs/presets that two adjacent knobs (either row or column wise) can me -ve range and +ve range respectively.
So I have exposed:
Preset 1 -- Osc1/2/3 (groups 1, 2, 3) voice (group 4)
Buttons: poly/unison/F1-2, and various categories (drive, EXF types).
The main pots control the levels and balances, meaning this first preset is quite powerful.
Preset 2 -- Envs 1/2/3 (groups 1, 2, 3)
F1/2, LFOs and SH (yes all the -ve/+ve ranges of each!)
Preset 3 -- Track points -16 ... 0 via groups (1, ... 4) and one knobs in bottom right
EFX control
Preset 4 -- as 3, but TP 0 -- 16 (-ve and +ve ranges)
Preset 5 -- Mod source 1 ... 6 (1 .. 4 via encoder groups)
Preset 6 -- Mod source 7 .. 12
I have tried to make it as intuitive as I can.
Thanks for the replies with the PDF. I still didnt get to grips with their template. Just how hard is it to align text under a button! I feel a mini project for my daughter coming on.
So this is on the "to do".
Obviously, read it into the BC Manager to move any buttons/knobs around.
Regards
Steve H
