RE: [bc2000] badly needing help
2009-09-19 by Marco Sa
If you are using Windows you don't need huskervu and midiyoke.
In Windows XP you need to install the drivers from the Behringer site (USB MIDI DRIVER (V1.2.1.3) for BCF2000 & BCR2000 (94 KB)), in Windows Vista you don't need to install the drivers.
Also, make sure you have installed the latest firmware (BCF2000 Version 1.10 (70 KB) ) a start the unit in Mackie mode.
This works fine for me in Sonar and Ableton Live, in fact I find that Ableton Live is one of the best applications dealing with external controllers.
I hope this helps.
The downloads are at http://www.behringer.com/EN/Support/B-Control-Downloads.aspx
Good luck,
Marco
To: bc2000@yahoogroups.com
Date: Sat, 19 Sep 2009 04:11:51 +0000
Subject: [bc2000] badly needing help
check out the rest of the Windows Live™. More than mail–Windows Live™ goes way beyond your inbox. More than messages
I hope this helps.
Good luck,
Marco
Its been over a year since i got this BCF 2000 from dubai as direct dealership is not available in india. Since then my nightmare started. I havent used it at all for the past one year as i found the setting up difficult. and i dont have support here.
i have cubase sx3 and i want to use bcf 2000 atleast to control the cubase mixer so that i can do automation.
As instructed i have downloaded huskervu and midiyoke and installed it.
i have booted the bcf in mackie mcc mode and set up mackie control in cubase.
and setup goes like this
in cubase
mackie control
input: bcf2000 (01) to out: midiyoke 1
in huskervu input: midiyoke 1 to output bcf2000 (01)
but on starting a project in cubase the faders dont even respond.
can some one please help me in laymans terms on what i need to do to get this thing work on cubase sx3???
some help will be greatly appreciated as i have done a song with many midi and audio tracks badly waiting to be mixed and automated
please do help
in cubase
mackie control
please do help
