Bc2000 (for the BCF2000 & BCR2000) group photo
Computer Editor to BCR2000
2009-07-02 by s*
Hey all,
I'm a bit of a n00b here (at least with the BCR2000 anyways (I've only had it for a few days)). I'm trying to wrap my head around programming the BCR2000. Here is what I am interested in programming with it:
Protools, TG77, SQ80, Evolver, MPC1000, DP2, MPX1, A3, s950, Prophet2002, Mirage, Emax II, E6400, Pulse, ER1, ES1, Microwave XT
I have seen a few possible presets for Protools but, not much in the way of the other synths I have mentioned. I was wondering though if it is possible to use an already existing editor like Sound Diver, Unisys or MidiQuest to teach the BCR2000 to control these other synths?
If anyone has any information about how to create presets for these machines (or if there are any already created), I would greatly appreciate any help you can offer.
Thanks!
-s*
Odp: [bc2000] Computer Editor to BCR2000
2009-07-02 by filip pietrzykowski
HI,
I got s950 and mpc 1000, you can forget about midi CC in those machines I'm afraid....
really shame, though
bless
Hey all,
Thanks!
-s*
Marcin Gortat w Polsce!
Zobacz szczeg\ufffdy:
http://klik.wp.pl/?adr=http://corto.www.wp.pl/as/sport_gortat.html&sid=783
Re: [bc2000] Computer Editor to BCR2000
2009-07-02 by bambuotk@aol.com
For Protools it works with HUI in the peripherals settings if you are
using usb, but make sure you go to midi setup first, and set up your bcr  before
setting up in the peripherals settings, once you get that done  protools
should work fine, now you want download this
_http://www.midevice.com/News.aspx_ (http://www.midevice.com/News.aspx)
And follow instructions
James
In a message dated 7/2/2009 12:01:15 P.M. Eastern Daylight Time,
scartattack@... writes:
Hey all,
help you can  offer.
Thanks!
-s*
**************Dell Summer Savings: Cool Deals on Popular Laptops – Shop
Now!
(http://pr.atwola.com/promoclk/100126575x1222696924x1201468348/aol?redir=http:%2F%2Faltfarm.mediaplex.com%2Fad%2Fck%2F12309%2D81939%2D1629%2D1)
2009-07-02 by s*
Really? For MPC1000 as well? I assumed that any control of the s950 would be limited if any but, I am surprised that the MPC1000 would not offer any controls via the BCR2000.
2009/7/2 filip pietrzykowski
HI,
bless
Hey all,
Thanks!
-s*
Zobacz szczegóły:
2009-07-02 by s*
Thanks James,
I'll definitely check this out.
On Thu, Jul 2, 2009 at 1:26 PM, <bambuotk@...> wrote:
For Protools it works with HUI in the peripherals settings if you are using usb, but make sure you go to midi setup first, and set up your bcr before setting up in the peripherals settings, once you get that done protools should work fine, now you want download this http://www.midevice.com/News.aspx
James
In a message dated 7/2/2009 12:01:15 P.M. Eastern Daylight Time, scartattack@... writes:
Hey all,
Thanks!
-s*
2009-07-02 by s*
Just to clarify my original idea... Would it be possible to connect the BCR2000 to a computer, then take a blank preset on the BCR2000, then load up an editor in Sound Diver, Unisyn or MIDIQuest with an editor for one of the specific synths that I mentioned in my previous email and then set one of the knobs/buttons to learn, then trigger a specific parameter in one of these computer based editors to teach the BCR2000 to later control this parameter on the specified synth on it's own? Also, would I need to do this programming via MIDI or could I also do it via USB? I have attached a basic illustration to try and help explain what I mean. I guess what I am really trying to figure out is, if this is possible and if there is any specific way I should approach this or if there any instructions out there to help me figure out how to start this. I read the manual but, my first attempts at this have been unsuccessful.
Any help is greatly appreciated,
-s*
On Thu, Jul 2, 2009 at 1:46 PM, s* <scartattack@...> wrote:
Thanks James,
James
Hey all,
Thanks!
-s*
Re: Computer Editor to BCR2000
2009-07-03 by rpcfender
Hi
No you can't 'Teach' the BC to send continuous changing Midi messages.
It will only 'Learn' a single message not a variable one. OK for
switches.
The BC will put out a continuous Midi including sysex (including a
checksum if your synth needs it) but you have to program it.
Behringer say it won't, but it will.
The Behringer manual won't tell anything about how to do this kind of
stuff.
0) Go the the Wiki mentioned at the Home page of this group for some
basic info
1) go get Mark's editor at his web site Mountain Utilities (Link in the
files section )
2) get a copy of the sysex spec of the synth - You can use SoundDiver
etc to output the message so YOU can look at it with MidiOx instead
of/as well as looking in the sysex spec.
3) Read my pdf in the Documents section of the Files here or Mark's full
BCL document at his web site
4) Have a look at some of the synth files in the preset section of the
Files for examples of synth controlled by the BC
5) Select a control (eg encoder ) on the editor and go to the "Learn'
section of the editor and write in the sysex message you want the
encoder to output. Dowload it to the BC
6) Come back here for more help if (when?) it doesn't work as you
thought it should.
All the best
Royce
load up
of the
of
of
this
do this
basic
really
specific
help me
attempts at
> -s*
> On Thu, Jul 2, 2009 at 1:46 PM, s* scartattack@... wrote:
> > Thanks James,
are
your bcr
done
> >> James
> >> Hey all,
only had
Prophet2002,
the way
is
or
appreciate
> >> Thanks!
> >> -s*
> >> Dell Summer Savings: Cool Deals on Popular Laptops - Shop
Now!<http://pr.atwola.com/promoclk/100126575x1222696924x1201468348/aol?r\
edir=http:%2F%2Faltfarm.mediaplex.com%2Fad%2Fck%2F12309%2D81939%2D1629%2\
D1>
2009-07-03 by filip pietrzykowski
In one of JJOS's re-incarnations (MPC 3rd party OS) you can assign one or two CC to MPC ( 1 or 2) and that's it...
mpc isn't multitimbral, one program at once only, one midi channel...
quite unbelievable as for machine in 2000 ish.....
2009/7/2 filip pietrzykowski pl>
HI,
bless
Hey all,
Thanks!
-s*
Kolejna odwa\ufffdna produkcja TARANTINO.
Zobacz kontrowersyjne B\ufffdkarty
http://klik.wp.pl/?adr=http://corto.www.wp.pl/as/bekartywojny.html&sid=782
2009-07-07 by s*
Thanks for all the advice guys. If anyone is working on an editor for any of the synths I mentioned:
Please let me know. I am familiar with sysex (basically only as far as dumping goes) but, still very new to editing it. I am going to attempt to work on a TG77 editor (as a hardware editor for that thing would be very handy). I assume that the TX81z sysex will be a good file to reference to as they are both Yamaha FM synths from a similar time frame. I also found a pdf of the Midi data format specs for the TG77. If anyone can offer any helpful suggestions, I would greatly appreciate it.
Thanks again,
-s*
2009/7/3 filip pietrzykowski
mpc isn';t multitimbral, one program at once only, one midi channel...
HI,
bless
Hey all,
Thanks!
-s*
Zobacz szczegóły:
Kolejna odważna produkcja TARANTINO.
Zobacz kontrowersyjne Bękarty
2009-07-08 by rpcfender
Hi
you might like to look at my TQ5 preset - Yamaha 4 Op FM synth as a starting point.
http://launch.groups.yahoo.com/group/bc2000/files/Presets/TQ5/
Royce
> Thanks again,
> -s*
> 2009/7/3 filip pietrzykowski filipmail@...
> > 2009/7/2 filip pietrzykowski filipmail@...
> >> HI,
> >> I'm afraid....
> >> bless
> >> Hey all,
> >> Thanks!
> >> -s*
> >> Zobacz szczegó³y:
> > Kolejna odwa¿na produkcja TARANTINO.
> > Zobacz kontrowersyjne Bêkarty
