Bcn44 with 2 variables
2009-03-10 by philk22002
Hello is it possible to send 2 variables of 4 bits with the Bcn44 ? the message with Bcr2000 for mys Kenton Pro solo MKII ".tx $F0 $00 $20 $13 $03 $20 14 1 val0.3 val4.7 $F7 " and structure of the sysex message to kenton "The Pro-SOLO mkII can be controlled by Sysex messages in the following format: The first five bytes of sysex for the Pro-SOLO mkII are always the same for all data types [ 1] 0F0h - Sysex command [ 2] 00h - Company ident first byte [ 3] 20h - Company ident second byte [ 4] 13h - Company ident third byte [ 5] 03h - Product code Pro-SOLO [ 6 ] 0dddnnnn - where ddd is the data type and nnnn is the device number where ddd = 010 = data change (so for device #1, this byte = 20h) [ 7] 0000uuuu - where uuuu = low 4 bits of parameter address [ 8] 0000hhhh - where hhhh = high 4 bits of parameter address [ 9] 0000uuuu - where uuuu = low 4 bits of data [ 10 ] 0000hhhh - where hhhh = high 4 bits of data [ 11 ] 0F7h - end of exclusive ) " thank you Philk
