Bc2000 (for the BCF2000 & BCR2000) group photo
bcr2000 global channel
2008-09-21 by Josh
i'm using my bcr2000 to control a synth module. its multi-timbral and
each sound is editable on 1 of 5 channels. I've got the bcr set up to
edit on channel 1. is there a way to quickly change that preset to
send on channels 2-5? thanks.
Re: bcr2000 global channel
2008-09-22 by rpcfender
Hi
There are a couple of ways of doing it.
1) Copy the preset and edit the Midi channel and make a new preset of
this (x 4) Have them as preset 1 to 5 or 21 to 25 etc so you can use
the "<" and ">" buttons to flip between them. Use Mark's editor or, if
you feel like learning about BC language, my editor to make the changes.
OR
2) MidiOx on the PC will allow you map incoming Midi messages from the
BC and you can set up 5 maps for each channel and flip between them.
You will need to use the BC in one of the USB modes.
In Mode U2  in the Midi Devices list there will be BCR2000(16) and
BCR2000(16)-A
The '-A' one is the Midi A  out port on the back of the BCR. Connect
that to the synth Midi in
Hope that helps
Royce
