Bc2000 (for the BCF2000 & BCR2000) group photo
Foot switch LED's
Foot switch LED's
2008-08-24 by carbonbase23
I have this one preset that I use (probably modified from a factory
preset) in which the both footswitch LED's are always lit... (sw1 sw2)
This isn't really a problem other than the fact that I don't know why
they are lit... I can't seem to find the command in the script using
the PC BCSeditor or anything to tell me what is going on there...
Anyone?
Thanks!
Re: Foot switch LED's
2008-08-26 by Mark van den Berg
The BCR's SW1 and SW2 are programmed via buttons 61 and 62, so you
should see definitions for those buttons in the script.
(You might also look at the ".footsw" setting under "$global", but I
don't think this bears on your situation directly.)
Hope this helps a bit,
Mark.
