SergeModular
Index last updated: 2026-04-28 23:13 UTC
True AD EG
True AD EG
2004-09-10 by cuari7
Anybody know of a way to turn a DSG/DTG into a true Attack/Decay EG?
I don't mean what one can get by feeding a pulse/gate into
the "trigger" input (the result of this is an AD envelope which
unfortunately WON'T retrigger until it decays back to zero. I don't
want this!!).
I want the ability to have an AD EG that can be retriggered with any
speed desired, without having to wait 'till it decays off.
Anybody know anybody who can monkey with this thing and turn it into
the above?
Let me know.
cuari7
Re: True AD EG
2004-09-10 by kirkdegiorgio
I get mine by feeding a gate into the INPUT jack instead of the TRIG jack...
is this correct folks?
any other methods...?
KD
> want this!!).
> the above?
> Let me know.
> cuari7
Re: True AD EG
2004-09-10 by John P
That's basically it as far as I know.
>KD
>>want this!!).
>>the above?
>>Let me know.
>>cuari7
>Keep on Patchin'!
>Yahoo! Groups Links
m/n/m/l
surreal electronic music, sound, noise
http://mnml.soulcatcher.net
Re: True AD EG
Actually feeding the gate into the input jack gives you
an "attack/release envelope, with sustain that is present for as
long as the key is depressed (so its actually an
attack/sustain/release envelope). What I want is something that will
allow me to get attack/release (up/down) even if I keep pressing the
key. This is excellent for percussive, staccatto notes. I know of at
least 2 synths which allow this option: the Moog Sonic Six and the
Buchla 200 (the Quad Function generator). They lett you choose
between A/D or A/R envelopes.
To better understand what I mean, take a conventional ADSR, the
program the following: Attack time: 0, Decay time: 50%, Sustain: 0,
Release time: 0. This gives you nice percussive notes (keep in mind
I don't use sequencers; only keyboards and body appendages ;-D...).
So, any ideas?
I kow there's a modification for the MOTM lag processor which allows
the same options (making it a VC-AD/AR EG. Kewl!!).
I just wish somebody came up with an idea to do the same for the
DSG. It would make it the PERFECT module!!
cuari7
PS: Panel still FS....
Re: True AD EG
2004-09-11 by John Loffink
Here's the patch. It will take two stages of a DTG or DSG with the post
1994 GATE OUTs as opposed to the old END out, as well as a scaling processor
stage.
GATE to TRIG IN on first DSG stage, set Rise/Fall to short values. GATE OUT
gives an inverted trigger.
GATE OUT of first DSG stage to Scaling Processor INPUT2, Bias with +5V on
Input 1 and full invert of INPUT2 (you could also use a Dual Processor).
This gives a positive biased trigger.
OUTPUT of Scaling Processor to second DSG stage INPUT. OUTPUT is your
triggered AD. Set Rise and Fall to taste, but if Fall exceeds the time
between GATES then you'll get envelopes that retrigger at the falling slope
point, which is normal retriggerable envelope action.
John Loffink
> -----Original Message-----
> From: cuari7 [mailto:medejd@...]
> Sent: Friday, September 10, 2004 7:47 PM
> To: SergeModular@yahoogroups.com
> Subject: [SergeModular] Re: True AD EG
> So, any ideas?
> cuari7
> Keep on Patchin'!
Re: True AD EG
2004-09-11 by James R. Coplin
The main problem is trying to change the clock as a gate stream to a pulse
stream to avoid the sustain stage of the USG. I just took the gates from the
clock or whatever into the trigger in on one part of the USG with the attack
and decay set to zero. Take the output of this input the input of the other
part of the USG and set your slopes accordingly. The attack time of the
first usg seemed plenty fast to not have to use the gate and go through an
inverter etc. Any objections to this approach?
As an aside, if you are using the USGs as a envelope with a sustain stage,
the level of the sustain is equal to the voltage present at the input.
Sticking an attenuator on your gates gives nice control of the height. I'm
particularly fond of running the gates through a vca of some sort using a
sin to set the envelope height.
Another good USG envelope trick is to use you sequencer outs to control
"chains" of sustain stages for more complex envelope shapes!
I probably should invest in a whole panel of USGs at some point as they are
by far my favorite module on the whole planet in any system!
James R. Coplin
If anyone asks of my whereabouts,
simply tell them i've gone out the window
for a spot of tea and am not
expected back any time soon.
> From: John Loffink [mailto:jloffink@...]
> Sent: Friday, September 10, 2004 8:28 PM
> Subject: RE: [SergeModular] Re: True AD EG
> processor
> stage.
> OUT
> slope
> John Loffink
> > So, any ideas?
> > cuari7
> > Keep on Patchin'!
> > Yahoo! Groups Links
> Keep on Patchin'!
Re: True AD EG
Without the inverting/bias stage this results in a gate voltage that is
high 99% of the time, rather than low.
John Loffink
> From: James R. Coplin [mailto:moog@...]
> Sent: Friday, September 10, 2004 8:53 PM
> the
> attack
> other
> are
> James R. Coplin
> > processor
> > stage.
> > OUT
> on
> > slope
> > John Loffink
> > > So, any ideas?
> > > cuari7
> > > Keep on Patchin'!
> > > Yahoo! Groups Links
> > Keep on Patchin'!
> > Yahoo! Groups Links
> Keep on Patchin'!
Re: True AD EG
That's why I said to use the regular outputs not the gate out! With a zero
rise time the leading edge is fast enough to trigger the input of the other
half of the USG without having to mess with an inverter for the gate!
True, it isn't as steep as the gate but from looking at it on a scope it is
fast enough that I doubt it would matter for things like enveloping. I
certainly can't hear a difference even at really high rates. Others
applications this might become critical. Using the gate and an inverter
"strictly" is more correct but I think you generally can save patching by
using the pulse generated from the outputs rather than needing the gate
without loosing anything as the rise time is sufficiently fast.
James R. Coplin
> Sent: Friday, September 10, 2004 9:20 PM
> John Loffink
> pulse
> > the
> > attack
> > other
> an
> stage,
> I'm
> a
> > are
> > James R. Coplin
> post
> > > processor
> > > stage.
> GATE
> > > OUT
> > on
> Processor).
> time
> > > slope
> > > John Loffink
> > > > So, any ideas?
> > > > cuari7
> > > > Keep on Patchin'!
> > > > Yahoo! Groups Links
> > > Keep on Patchin'!
> > > Yahoo! Groups Links
> > Keep on Patchin'!
> > Yahoo! Groups Links
> Keep on Patchin'!
Re: True AD EG
2004-09-11 by John P
Using the regular output is fine for percussive (fast) attacks, but what
if you want to do the same thing with longer attacks? The solution
would seem to be to use the Loffink's gate & inverter method. For the
inverter you could use just about anything, incl the BLOG inverter.
The attack & decay time of DSG #1 in the chain would have to be longer
also to 'feed' the attack buildup of DSG #2. For added fun, VC the
attack & decay times of DSG #1.
In this case, I think the DSG #1 would be called a 'one-shot': hit it
with a pulse and it gives you one pulse out, with 'on' time you can vary
if you want.
>James R. Coplin
>>John Loffink
>>pulse
>>>the
>>>attack
>>>other
>>an
>>stage,
>>I'm
>>a
>>>are
>>>James R. Coplin
>>post
>>>>processor
>>>>stage.
>>GATE
>>>>OUT
>>>on
>>Processor).
>>time
>>>>slope
>>>>John Loffink
>>>>>So, any ideas?
>>>>>cuari7
>>>>>Keep on Patchin'!
>>>>>Yahoo! Groups Links
>>>>Keep on Patchin'!
>>>>Yahoo! Groups Links
>>>Keep on Patchin'!
>>>Yahoo! Groups Links
>>Keep on Patchin'!
>>Yahoo! Groups Links
>Keep on Patchin'!
>Yahoo! Groups Links
m/n/m/l
Re: True AD EG
OK, how about this then? ;)
You can take the output of the first section in the USG into the VC of
itself and set the VC control all the way left and set to modify the rise
time. This will still create a fast enough rising edge to trigger the input
section of the other half of the USG. Adjust the rise time on the first half
to taste as you would with the inverter. The VC adjustment makes the rise
time an extremely rounded squared off wave. This allows for long attack
times except in cases where very long attack times are needed.
Inverters? We don't need no stinking inverters!
James (Who is always short of inverters) Coplin
> From: John P [mailto:johnp299792@...]
> Sent: Friday, September 10, 2004 9:55 PM
> Subject: Re: [SergeModular] Re: True AD EG
> if you want.
> zero
> other
> is
> >James R. Coplin
> >>John Loffink
> >>pulse
> from
> >>>the
> >>>attack
> >>>other
> >>an
> >>stage,
> >>I'm
> >>a
> >>>are
> >>>James R. Coplin
> >>post
> >>>>processor
> >>>>stage.
> >>GATE
> >>>>OUT
> >>>on
> >>Processor).
> >>time
> >>>>slope
> >>>>John Loffink
> >>>>>So, any ideas?
> >>>>>cuari7
> >>>>>Keep on Patchin'!
> >>>>>Yahoo! Groups Links
> >>>>Keep on Patchin'!
> >>>>Yahoo! Groups Links
> >>>Keep on Patchin'!
> >>>Yahoo! Groups Links
> >>Keep on Patchin'!
> >>Yahoo! Groups Links
> >Keep on Patchin'!
> >Yahoo! Groups Links
> m/n/m/l
> Keep on Patchin'!
Re: True AD EG
I see now. Yes, this does work for percussive type envelopes.
John Loffink
> Sent: Friday, September 10, 2004 9:36 PM
> other
> is
> James R. Coplin
> > John Loffink
> > pulse
> from
> > > the
> > > attack
> > > other
> the
> through
> > an
> > stage,
> > I'm
> using
> > a
> control
> they
> > > are
> > > James R. Coplin
> > post
> > > > processor
> > > > stage.
> > GATE
> > > > OUT
> +5V
> > > on
> > Processor).
> your
> > time
> falling
> > > > slope
> > > > John Loffink
> will
> the
> at
> 0,
> mind
> D...).
> > > > > So, any ideas?
> allows
> > > > > cuari7
> > > > > Keep on Patchin'!
> > > > > Yahoo! Groups Links
> > > > Keep on Patchin'!
> > > > Yahoo! Groups Links
> > > Keep on Patchin'!
> > > Yahoo! Groups Links
> > Keep on Patchin'!
> > Yahoo! Groups Links
> Keep on Patchin'!
Re: True AD EG
2004-10-05 by Carbon111
> OK, so this thread is almost a month old, but I think this is a simpler
> patch, that actually works better than the others proposed. The
> question was, how to use a DSG/DTG to get a true attack/decay envelope,
> which can be retriggered before completely decaying.
To get an AR (or ASR for that matter) that will retrigger before the cycle end, use the Input *and* the trigger input together. My MIDI/CV (Kenton Pro-Solo) has seperate gate and trigger outs.
Or am I missing something?
Best Regards, James
http://www.carbon111.com/serge.html
Re: True AD EG
2004-10-06 by Bob Hearn
> Best Regards, James
Oh, I should have mentioned that the original poster specifically did
*not* want a sustain, just attack/decay.
If you feed a gate into both trig. in and input on a DSG, you get
sustain. Also, it will give you retriggering of a sort, but depending
on your rise setting, the envelope might not fully rise again - it will
only rise until the gate turns off, or the peak is reached, whichever
comes first. And the peak may not be where you want it - my TKB puts
out 8v from KP. (Is that unusual?)
Original thread is here:
http://launch.groups.yahoo.com/group/SergeModular/message/2773
Cheers,
Bob
Robert A. Hearn
rah@...
http://www.swiss.ai.mit.edu/~bob/
Re: True AD EG
2004-10-06 by Carbon111
> sustain.
Ok...the original thread does go back a ways ;)
I thought if you put a trigger pulse (not a gate) only into 'trig in',
the DSG was a one-shot AR with full retriggering. If thats not the case,
then maybe try feeding the trigger pulse to both 'input' and 'trig in'
and don't use a gate logic signal at all.
Now you've got me questioning the DSGs behavior...I'll mess with it
tomorrow a bit ^_^
Best Regards, James
True AD EG Revisited...
2004-10-16 by Carbon111
Hey I know this post is a little stale but I finally got my Serge back
together after its little stint on the road and wanted to revisit this.
Both my Synthesizers.com controller and my Kenton MIDI/CV converter have
3 outputs: Trigger, Gate and CV.
By routing the trigger signal (not gate) into the "signal in" *and*
"trig in" of the DTG, I get *exactly* the kind of response cuari7 was
looking for - A retriggerable AD envelope that will complete its cycle
(without having to keep a key depressed)if not retriggered by a keypress.
Best Regards, James
Re: True AD EG Revisited...
2004-10-16 by cuari7
True.
HOWEVER......
If you program a slow attack, the pulse sent by the Kenton is so
short that it'll die off way before the envelope reaches its peake
(I tried this first years ago, with my Animal and a Kenton Pro2000,
no less). Works great with snappy attacks, though........
cuari
cuari7 wrote:
> True.
> HOWEVER......
Arrrrgh! You are of course correct. I was so busy checking out various
"fall" times that I didn't adjust the "rise" very much :(
Best Regards, James
