due to the fact that I use another RIP for most of my work, my advances into tweaking QTR tend to be very rare, with never enough time to really catch up. I do tend to have the most recent versions, on both a Mac and a PC. Interestingly in the curve creation section of the PC version, there is no tab for a GO channel, only the usual gray and 2 toner tabs.
Anyway, just to perhaps share a bit of my months of experience working with GO and a K7 setup with a different RIP, the other posts about maximum ink are very relevant. After too many failures I wound up setting individual limits very low, then getting the GO channel curve right, then going back to see how much I could open up the limits in the gray inks for better resolution, before mottle or bleed became problematic.
Additionally, I found different papers required different GO curves, requiring different imaging ink limits, further complicated by the fact that bronzing tended to dry in over night with some papers negating the solutions I thought I had finalized.
You may very well find yourself needing 100% GO, or nearly, in highlights and/or at paper white.
I would not hesitate to consider a second GO only pass, since it's already in your printer and a simple setup.
Hope this helps a bit.
Tyler
--- In QuadtoneRIP@yahoogroups.com, "robert49brake" <robert49brake@...> wrote:
> --- In QuadtoneRIP@yahoogroups.com, "Tyler Boley" <tyler@> wrote:
> > I had no idea a GL channel in addition to the 2 toners was available...
> There seem to be a bunch of old techniques in QTR that are still floating around and working but have been superseded in function by later versions of QTR. I was also working with the UT_3D inkset over the winter and its' use of two grays to make a black present a lot of unusual demands on the current version of QTR. The current QTR seems to be tailored more for ease of use with an inkset with linear progressions in density. In Ron Reeder's use of QTR for digital negatives, which don't always seem to follow the needs of positive prints, I have found many usefull things that can be used in QTR, as well as in some of Paul Roark's methods used in his 3MK approach. Just more of the wonder that is QTR.
