QTR-Quadtone RIP
Index last updated: 2026-04-28 23:12 UTC
Is this possible? .... curve points/point list
2008-01-23 by evanj1969
Is this possible?
 when working in the "curve creation" mode, if you select "load
curve" as opposed to "gray ink" or "toner" you get a curve tab where
you would normally enter the ink density.
 from that point, you can open up the "curve points/point list". it
appears the only way to get information there is to enter it manually.
 is it possible to load or display the information (points) from a
curve that has been created with the "toner/density/limit" method.
 in other words, if I where to open up a UCpk-raw-neut curve (on a
3800), could I display the curve in the point list that was created
for the light magenta channel when it was selected as a toner 2 with
a density @ 25 and limit @ 6 originally?
 I hope to take that toner curve, and make very small adjustments to
it, but I want to use the current curve as my starting point as
opposed to creating one totally from scratch.
any help would be greatly appreciated.
Evan
