> On 3 Feb 2018, at 18:39, Roy Harrington roy@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Epson and QTR driver are completely independent drivers -- nothing transfers back and forth.
> QTR driver does not have a specific selection for this but you may be able to set it from the
> front panel (I'm not sure about 3880). I also think the Manual paper feeds have a larger platen gap.
> Roy
> On Fri, Feb 2, 2018 at 3:19 PM, ian@... <mailto:ian@ianbarberphotography..co.uk> [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com <mailto:QuadtoneRIP@yahoogroups.com>> wrote:
> If I want to widen the platen gap on the R3880 printer when using Print Tool, do I choose the R3880 printer from the drop down option top right of Print Tool, change the Platen Gap and then switch back to the QTR printer from the same list ?
> Roy Harrington
> roy@... <mailto:roy@...>
> www.harrington.com <http://www.harrington.com/>
