QTR-Quadtone RIP
Index last updated: 2026-04-28 23:12 UTC
New Automated QTR Profiling Tools
2016-10-31 by richard@...
Here is a link to information about new QTR profiling tools for dedicated black and white printers:
http://www.bwmastery.com/quadtoneprofiler/
I've done a lot of work automating some of the more repetitive tasks and came up with ways of using custom ink calibration images along with ColorPort or i1 Profiler for speeding up the whole process. I've automated everything from finding the ink limits for each shade, getting the exact cross over points, and generating the qidf profile. You basically just need to define the printer and the inks and then generate, print, and measure the targets. A lot of these things are similar to the standard QTR profiling approach but incorporate my methods of evenly dividing the tonal scale with the number of inks you want to use to get the best overlap for the smoothest profile. It takes something that would have taken more than two hours to now being about 15-30 minutes and using a single sheet of paper.
One thing I am most excited about is finally solving the problem of the sharp edges in the QTR-generated curves where one ink begins and the next falls off. The Quad Curve Smoothing tool i made allows you to change the start and end points of each ink as well as change the shape each the curve while maintaining the same general ink density as the original curves. These things still need final linearization so I spruced up my QuadLin curve linearization tools. It now has an even more advanced curve linearization to change the shape of the final density curve that doesn't rely on the QTR Linearize-quad app. The new version also uses measurements of 51-step targets that are interpolated to 128 control points for the correction curve, lookup, and new quad value calculations. (I even put in an option for my own data smoothing function for really noisy data that you might get from a SpyderPrint device). The instructions have methods for easily getting multiple samples from the spyder print and a 51x4 averaging and graphing tool for checking for linearity and using the QuadLin tools.
These things were all supposed to be part of the larger QTR book, but they kind of took on a life of their own over the past few months and I wanted to get them out there while I finish up editing, making screen shots and designing my QTR book. I am charging a little for the tools, but honestly that is the only way I could justify all the time I put into it, and to offset any support time for it in the future.
If you use the code QuadTonePro at checkout you'll get $15 off through the end of November.
Anyway, I hope this is useful and that no one get's too offended by the sales pitch...
Re: [QuadtoneRIP] New Automated QTR Profiling Tools
2016-10-31 by Myron Gochnauer
I don’t mind Richard’s mild advertising in our QTR group - - - his posts have been informative, and the subject matter is directly QTR-relevant.
I would be interesting in hearing back from members who try Richard’s profiling system/software. From the description it sounds as though it depends on Microsoft Excel. I don’t own Excel, and would have no other use for it. Am I correct in assuming that other heavy-duty spreadsheets that claim to be Excel compatible would work just as well???
Myron Gochnauer
BA, MA, PhD, LLB, LLM, dogman
goch@unb.ca
On Oct 31, 2016, at 7:03 AM, richard@richardboutwell.com [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
I've done a lot of work automating some of the more repetitive tasks and came up with ways of using custom ink calibration images along with ColorPort or i1 Profiler for speeding up the whole process. I've automated everything from finding the ink limits for each shade, getting the exact cross over points, and generating the qidf profile. You basically just need to define the printer and the inks and then generate, print, and measure the targets. A lot of these things are similar to the standard QTR profiling approach but incorporate my methods of evenly dividing the tonal scale with the number of inks you want to use to get the best overlap for the smoothest profile. It takes something that wo uld have taken more than two hours to now being about 15-30 minutes and using a single sheet of paper.
One thing I am most excited about is finally solving the problem of the sharp edges in the QTR-generated curves where one ink begins and the next falls off. The Quad Curve Smoothing tool i made allows you to change the start and end points of each ink as well as change the shape each the curve while maintaining the same general ink density as the original curves. These things still need final linearization so I spruced up my QuadLin curve linearization tools. It now has an even more advanced curve linearization to change the shape of the final density curve that doesn't rely on the QTR Linearize-quad app. The new version also uses measurements of 51-step targets that are interpolated to 128 control points for the correction curve, lookup, and new quad value calculations. (I even put in an option for my own d ata smoo thing function for really noisy data that you might get from a SpyderPrint device). The instructions have methods for easily getting multiple samples from the spyder print and a 51x4 averaging and graphing tool for checking for linearity and using the QuadLin tools.
Anyway, I hope this is useful and that no o ne get&# 39;s too offended by the sales pitch...
Just a quick note about the need for Excel: there are several user defined functions and macros for generating the ink descriptor file and for compiling the final quad curves/saving them without manual copying and pasting and risking breaking the formulas/lookups.
There is also the issue about how it looks... I've tried using several different spreadsheet applications for opening non macro enabled workbooks and the formatting usually breaks.
I was worried about the cost of excel, but office 365 for personal use is about $7 a month for 2 installs or $10 for 5 installs. Ideally, these would be stand alone tools but I am only now learning to develop for macOS and trying to learn .net for making windows apps is just going to be too much work for the relatively small market this is developed for.
I am really interested in some unsolicited reviews. I showed this to a few beta testers and they loved the idea and how it works, but I'm open to suggestions for how to make the current version better.
I am working on a version that will be tailored toward OEM inks that export neutral, cool, selen, warm, sepia with a single button and another version for digital negatives for either K3 or k6 inks plus toner partitions.
Richard Boutwell
RE: [QuadtoneRIP] New Automated QTR Profiling Tools
2016-10-31 by Dr. Elliot Puritz
I agree with Myron.
I think it obvious that Richard has spent months of work developing his new system even as he held a full- time job needed to pay the bills!
For those of us who have migrated to the Epson P800 and similar printers the ability to use third party black and white inks is not a current option.  It would be significant if QTR profiles might be used to obtain black and white prints from the inks installed in the P800.  Perhaps Richard can broaden his work flow and tools so that one can indeed produce such profiles for the P800.
Elliot
From: QuadtoneRIP@yahoogroups.com [mailto:QuadtoneRIP@yahoogroups.com]
Sent: Monday, October 31, 2016 1:33 PM
To: QTR group group <QuadtoneRIP@yahoogroups.com>
Subject: Re: [QuadtoneRIP] New Automated QTR Profiling Tools
Myron Gochnauer
goch@... <mailto:goch@...>
On Oct 31, 2016, at 7:03 AM, richard@... <mailto:richard@richardboutwell.com>  [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com <mailto:QuadtoneRIP@yahoogroups.com> > wrote:
All the best,
Richard Boutwell
http://www.richardboutwell.com/
Re: New Automated QTR Profiling Tools
2016-11-02 by brian_downunda@...
Richard and I had an off-forum conversation about when you charge for something and when you don't. It's possible that his hesitancy in posting his new for-sale tool-set reflects that conversation, but if so then it shouldn't. My view, FWIW, is that anyone can charge for anything, they just have to be able to demonstrate the value.
I haven't read all of the information about Richard's new tool-set yet, but my initial impression is that the value appears to be there. There certainly appears to be a lot of effort and ingenuity there, and he understands the curve creation process as well as anyone and better than most. Since this is a stand-alone product, I assume that there is a perpetual license (and a year of updates), unlike the forthcoming IJM tool-set which has a fairly hefty annual license fee (although all references to that seem to have vanished, so I can't be sure that that's still the case).
In another recent thread I asked about split-tone K3 recipes. As I have a current interest in K3 curves, I could well be interested in the new toolset. I noted a current thread on Lula in which you (Richard) said that the initial release is only for monochrome inksets. I'm a bit puzzled by that. You mean that you can 't use the current release at all for K3, or is it just that the toning components are missing, so that any curves you built would be warm curves without toners? I suspect the latter. Will K3 be a separate release, or an extension of the current release?
As for software, will these tools work in LibreOffice Calc? I gather there is some compatibility. Did you consider building this in Calc, given that it's free and cross-platform?
As an old die-hard Measure Tool hold-out, I understand I'd have to create my own MT-compatible charts manually. Such is the lot of an old die-hard.
2016-11-02 by richard@...
Thank you everyone for the comments. Brian, I put your questions in bold and responded below. It got long, even after some cutting...
''Richard and I had an off-forum conversation about when you charge for something and when you don't. It's possible that his hesitancy in posting his new for-sale tool-set reflects that conversation, but if so then it shouldn't. My view, FWIW, is that anyone can charge for anything, they just have to be able to demonstrate the value.
I didn’t hold off selling these earlier because of those conversations. But, as I said then, I wanted to make sure whatever I put out was in a state that I was happy with and proud of. I am proud of these, but of course there is more I wish I could have done before releasing them. I really thought they would have been done a month earlier, and I was dead set on getting them out before the end of Oct. I am happy with the functionality for its intended use as it is. From here I will spend some time working on the rest of the QTR book and will introduce updates as I get feedback from people who have already bought it. Then I will start to introduce some of the additional features I've been dreaming up. Basically, if I didn't get it out as it is now, I might never have, and that wouldn't be fair to people this could end up helping.
I did consider releasing some of the previous versions of some of these tools for free but was advised against it, and the time answering questions and fixing problems would not have been worth it. That is one reason I made the QuadLin stuff a service when I introduced it a few years ago. There was some hand tweaking and even more manual copying and pasting that would have just been too complicated and annoying for people—free or paid. I was able to make the correction curve tools available for free because they were relatively easy to make and there was very little that could go wrong with the formulas or the copying and pasting.
''I haven't read all of the information about Richard's new tool-set yet, but my initial impression is that the value appears to be there. There certainly appears to be a lot of effort and ingenuity there, and he understands the curve creation process as well as anyone and better than most. Since this is a stand-alone product, I assume that there is a perpetual license (and a year of updates), unlike the forthcoming IJM tool-set which has a fairly hefty annual license fee (although all references to that seem to have vanished, so I can't be sure that that's still the case).
Thank you, I spent a long time working this stuff out for myself and tested lots of different methods and learned a lot about stuff I never intended to along the way.
Format and pricing: I struggled a long time with how to price these tools and what format they should be in—including how much trouble I should go through trying to generate user licenses, serial numbers, and unlock codes, or or if I should just make it a software-as-a-service web app hidden behind a paywall. I decided that was all too much work for as small of a niche this QTR stuff is, and it would end up just being a little too user hostile…
So yes, once you have the download you can use it for as long as you want without too much restriction (basically you can’t start a profiling service using these tools or make copies to sell or hand out to other people). Basically, I ask that people pay the license so I can justify the time I’ve already spent on it and any time I spend making it better (and the time it takes for email support and spending a few hours responding to questions on forums. Maybe I’m asking too little after all….) jk, I do realize how I would react if this these tools three or four times the price. I would just build my own…
''In another recent thread I asked about split-tone K3 recipes. As I have a current interest in K3 curves, I could well be interested in the new toolset. I noted a current thread on Lula in which you (Richard) said that the initial release is only for monochrome inksets. I'm a bit puzzled by that. You mean that you can 't use the current release at all for K3, or is it just that the toning components are missing, so that any curves you built would be warm curves without toners? I suspect the latter. Will K3 be a separate release, or an extension of the current release?
The current release is for 1-6 partitioned gray inks only, and it does not have options for the toner partitions yet. There are several reasons for this, but mostly I needed to consider how different people will use the toner partitions with some of the automated features in the current tools. For instance, I’ve made profiles that have 4 carbon gray inks and two selenium (like shade 5 and 2) as toner inks that run under the whole scale, and I have plans on testing a K6+CMY ink set in the coming months. Something like would be cool to be able to do with the automated tools, but isn’t really applicable to people working with the OEM inks. basically, i don’t have a good solution yet, but it wasn’t a big enough reason to hold back releasing it—especially considering that so many people are only using single tinted systems like the Eboni or Piezography K6 or P2 ones and I spent a lot of time privately and publicly trying to fix problems that arise from the some of the QTR methods. This was just a way to solve some problems before people threw their printers off the roof.
I mentioned elsewhere that I am considering making these two completely different profiling systems—One for OEM Epson K3+C,M,Y,lc,lm,(o,g) and premade toner curve options, and one for dedicated black and white ink sets with custom toner partition options. They are really different products for different kinds of users. K3+color profiles are less demanding and are easier to make than profiles with more than 4 gray inks, and one the goals of these profiling tools was make creating K4-K6 profiles easier and to solve some of the problems with the nature of QTR-generated curves (sharp corners of the curves, and banding in the gradients).
I downloaded LibreOffice and tried opening a few of the files with Calc. It crashed repeatedly. Honestly, I didn’t try to build these with an open source spreadsheet app because these tools started out in Excel as personal profiling tools going back to 2010-2011. I kept extending and modifying them until it got to this point. I am not opposed to recreating them with Libre Calc, and i’ll look into it, but I have to consider how long it would take basically rebuilding everything from scratch. At that point it might be better to just make a stand alone profiling app…
''As an old die-hard Measure Tool hold-out, I understand I'd have to create my own MT-compatible charts manually. Such is the lot of an old die-hard.
I was an old MeasureTool holdout too, but I don’t think you can make custom targets from CGATS reference files with the free demo mode of ProfileMaker5. ColorPort works well, especially if you are using older measurement devices, but it still requires a reference file for the measurements. the reference files actually make working with i1 Profiler worse so I just manually define the chart structure and measure in strip mode. I started having a problem with i1 Profiler a few days ago when I went to make some screen recording videos and am still trying to sort that out. Honestly though, the more I work with ColorPort, the better I feel about it. The only problem I see with it is that it just doesn’t work with the newest measurement devices.
Anyway, this is long enough an it is way past my bedtime.
Cheers,
Richard Boutwell
2016-11-02 by forums@walkerblackwell.com
In my opinion, Richard’s tool is underpriced for how many support emails he’ll be getting asking questions about how to use it . . (or how to make curves or DNs!) . unless he assumes we’ll all support it on this forum for free?  Or on IJM’s forum? Or DigBlackAndWhite? This seems like a cost-neutral thing or possibly a money-loser at $40.00.
Piezography Professional Edition is a continually upgraded and modified toolset and support license (gives access to a private support forum for users who need direct a timely service as we are an internationally distributed company with many Piezo labs and artists doing printing every day needing custom support) and also it pays for continual Piezo master curve and tool development and documentation. It’s also cost-neutral (we calculated this) at $150.00 so I have no idea how Richard came up with $40.00 . . . there are a lot of factors to think about when releasing software or service or support beyond just the initial labor. Releasing something into the world costs money after someone has bought it. They expect documentation and support and compatibility with their version of Excel, etc etc etc. Some of this is directly reflected in this thread, and should be actually posted on a support forum that is no the QTR support forum but that does not exist (and that would cost time and labor and money to set up). You see what I mean?
best,
-Walker
> On Nov 2, 2016, at 3:18 AM, richard@richardboutwell.com [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Cheers,
> Richard Boutwell
> http://www.richardboutwell.com/ <http://www.richardboutwell.com/>
> http://www.bwmastery.com/ <http://www.bwmastery.com/>
2016-11-02 by Dr. Elliot Puritz
Hi Walker:
You have framed the issue of pricing well and have provided excellent advice.
Given what Richard’s program can accomplish he should surely take your suggestion and raise the price.
Elliot
Sent: Wednesday, November 02, 2016 7:16 AM
To: QuadtoneRIP@yahoogroups.com
best,
-Walker
On Nov 2, 2016, at 3:18 AM, richard@richardboutwell.com <mailto:richard@...>  [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com <mailto:QuadtoneRIP@yahoogroups.com> > wrote:
Cheers,
Richard Boutwell
On price, the QTR + Print Tool combo is $89. Personally I find it hard to see someone charging more than that for tools to create and refine curves for QTR, although pricing is entirely up to Richard. Clearly it's something he agonised about. In any case, competition is a good thing in a market economy, it's why they work.
@ Richard: According to https://help.libreoffice.org/Common/Using_Microsoft_Office_and , Calc and Excel use much the same language, but different objects and methods. It should be possible to migrate from one to the other once the correspondence is understood. I've done a fair bit of VB scripting. We can talk about this offline if you like. There's also the option to enable the feature Tools - Options' - Load/Save - VBA Properties'
But first you need to resolve this K-3 vs K-more-than-3 thing. My main interest at present is in the K3 version and people need to know what they've buying - one or the other or both. I gather that there may have been some initial confusion on this point.
2016-11-02 by wattsies67@...
Wlaker, IJM provides both the inks and various tools to run the piezography inksets which it sells as a turnkey solution, with many promises about its performance and comparative advantages to other approaches. It's not an inexpensive solution. Nor would you expect it to be. Clearly it has taken a lot of research and development to produce and in the early days of digital printing it provided a hope for a black and white solution that didn't otherwise appear available in the digital paradigm. Where it makes sense, it is an excellent product in many respects. I used the selenium inks for a few years, but unfortunately I don't print often enough that I can overcome the frustration of the ink settling issues in printers like the 3880.
However, I think there is a fair difference between a company like IJM and what Richard is doing which as I understand it is basically making available some tools he has developed on a "see how you go with these" basis and is seeking to recover some reward for the effort he has made creating them. Richard also has a day job. I certainly wouldn't expect a lot of aftermarket care for the outlay involved, although I am sure Richard will provide that through various channels as he has been pretty helpful in his contribution to this and other forums to date.
The main thing here is that we have a number of very valid alternatives for digital black and white printing and are fortunate to have people who continue to develop products and solutions which they are prepared to share with all of us, often on pretty affordable terms. More importantly, the knowledge that people are prepared to share on forums like this enable us to all become better at our craft.
Richard, I'm looking forward to your book and to your tools for the K3 OEM inks.
Jason
2016-11-02 by Bill Kennedy
Jason-
I'm not speaking for Walker, or Inkjetmall, though I've been a satisfied customer since the later 1990's.
I applaud what Richard has accomplished. It is no small thing! I've already purchased and downloaded his software (which is very underpriced, in my opinion). I hope Richard, and others, continue to push for better tools and better solutions, and I intend to support them.
The "hidden" issue is tech support. Roy's QTR is a miracle of sorts. I've never met him but admire the support he offers through forums. I can only imagine what else he has to field that doesn't show up on the forums. Richard seems to have elected to travel a similar path and I hope it works for him. Overall, though, you'll notice that most "tech support" comes from dialogues and responses to questions through the forums. Honestly, I don't think there is any other way it could work and I'm grateful these forums exist.
Inkjetmall not only has pushed the boundary with a relentless commitment to R&D but, in my experience, the best customer service and tech support in this market.
I buy groceries from vendors that I want to support so they can stay in business, prosper, and continue to sell me the stuff I want to buy. I'm more than willing to spend a bit more to contribute to what is essentially a very fair system. I pretty much take that approach with everything I purchase, when I have a choice.
I know that every dollar I spend at IJM is actually an investment. Not just in their future, but in mine.
Bill Kennedy
Professor of Photocommunications
Area Coordinator
St. Edward's University
Austin, Texas USA
From: wattsies67@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com>
To: QuadtoneRIP <QuadtoneRIP@yahoogroups.com>
Sent: Wed, Nov 2, 2016 4:32 pm
However, I think there is a fair difference between a company like IJM and what Richard is doing which as I understand it is basically making available some tools he has dev eloped on a "see how you go with these" basis and is seeking to recover some reward for the effort he has made creating them.  Richard also has a day job.  I certainly wouldn't expect a lot of aftermarket care for the outlay involved, although I am sure Richard will provide that through various channels as he has been pretty helpful in his contribution to this and other forums to date.
J ason
2016-11-02 by Keith Schreiber
Jason,
I don’t think you need to educate Walker on who IJM is and what they do - he is a part of it. I’m not sure that is what you intended, but it sure is how it reads to me. I say this as a long-time on-again-off-again small scale Piezography user who earlier this year went in in a much bigger way due to Walker’s PiezoDN system for digital negatives.
As for Richard, he has had some free tools available from his website for at least a year or so. They may have been a little unpolished until now, but they were way better than anything else available at that price that I am aware of. I’ve actually only used his Digital Negative calibration spreadsheet, since that is what I do, and though I’ve gone all in on PiezoDN of army own digital negative work, I still help a few computer challenged friends (and some who only lack a good spectro to make the necessary readings) with making QTR profiles, and Richard’s tool have proven to be much better than my own spreadsheet or those of a few others that I have tried. I am very much looking forward to his new tools and will be happy to pay for them.
There are indeed a number of available alternatives, but IJM/Piezography, in my opinion and experience, stands apart in terms of quality, innovation, and support.
I mean this in all earnestness. There is no sarcasm intended. And I apologize if I have misread or misunderstood your comments.
Cheers,
Keith
jkschreiber.com
> On Nov 2, 2016, at 2:32 PM, wattsies67@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Jason
2016-11-03 by Walker Blackwell
I believe it can (or will be?) able to Lin for dig neg.
Richard, if you find that you need to raise the price to pay for your written support dialogues, I for one would fully support that. It looks like a good tool and I'm interested in where it goes.
Cheers all,
Walker
On Thursday, November 3, 2016, michael.mutmansky@yahoo.com [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Richard,
I don't see it mentioned in here or on your website; can this be used to linearize for digital negatives?
---Michael
2016-11-03 by richard@...
Thank you, everyone for your comments and for all the support for the new system.
I would never expect anyone to answer questions about my products here, lulu, bwdigitalprint, or on the IJM sites. I can understand Walker’s concern about having to answer questions about my workflow on the Piezography forums and I discourage anyone posting questions there about my stuff there. One of the reasons I made this set of tools was because I found I was answering too many questions for other people's systems and set out to make a tool that would hopefully cut down on some of that.
About there not being a support forum for this: It is being built. I was a little hesitant at making yet another internet photography forum, but I decided that a private forum for customers only would be in everyones’ best interest. I think general/presale questions like the ones here are relevant, but I don't expect other people to answer those for me, and I hope they don’t become excessive or annoying to general readers. I have enough questions from people already to create a real FAQ and will put that up shortly.
More about support: I had already planned on a second membership site for all the support materials and video tutorials. I am working on that now, but in the mean time, I am answering questions by email through the form on the bwmastery/quadtoneprofiler page or directly at support@quadtoneprofiler.com
As for the price: I am happy to hear people think it is worth more than I am selling it for, but I thought long and hard about the price and what I would consider fair given that the range of people using go from hobbyists to professional print labs. I think I have struck a good balance based on it being dependent on Excel, the cost of QTR (as Brian pointed out), and the fact that people still need to either invest in (or already have) a measurement device.
Digital negatives: The current tools will NOT work for digital negatives, because the math behind some of the stuff needs to be inverted for it to work properly. I do have a non-automated digital negative version, but there is a lot of manual data entry and copying and pasting that I would not consider user friendly. I will be incorporating all the automation stuff in the current tool and will be releasing it as a second product in about three weeks. The DN version will be based around the same workflow of measuring custom ink calibration images that generate all the ink descriptor file settings. There will also be a deluxe edition will have DN curve smoothing and linearization tools. There are some cool things I have in mind that will make it easy to create a negative for traditional darkroom work or positive film for gravure. I have spoken to a few gravure people that I will work with to test it so those features might be further off.
Cheers,
Richard Boutwell
2016-11-21 by richard@...
I just finished the update that adds support for the 10-channel x900 printers for all the profiling tools and included a few new goodies (and a few bug fixes). If you already bought them you should have already received an email with the update. For new people:
The automated profiling tools can now be used with printers that have as many as 10-channels to make profiles with up to 8 gray dilutions (overkill? maybe, but that is the internal QTR curve creation program limit)
The CurveSmoothing tools now have a new proportional ink balancing formula and an option to match the original ink load with all channels or only the UCK3 channels. This option is great for smoothing curves with toner partitions and prevents weird color shifts from the ink load balancing. It also has a nifty black boost feature similar to the QTR K Boost setting in the ink descriptor file (you can read about that here: http://www.bwmastery.com/blog/2016/the-qtr-black-boost-setting)
The QuadLin advanced curve linearization tools have been updated for 10-channel .quad files, but are otherwise the same (for now).
A new version for making toning profiles will be coming before the end of the year.
Cheers,
Richard Boutwell
