QTR-Quadtone RIP
Index last updated: 2026-04-28 23:12 UTC
having a challenge re-installing my Epson R2400 printer
2016-07-05 by Frank Eberdt
Recently the hard drive on my Mid 2009 15” MacBookPro died and I had to have it replaced.
I want to use this computer both for regular digital printing using Photoshop and for making digital negatives using QTR
with an Epson stylus Photo R2400 printer
I installed El Capitan (OS 10.11.5) on the machine and then installed QTR
then realized I would also need to  install Epson’s latest driver for this version of the OS
so that I could do “regular” printing
the Epson web site instructs you to do the driver install using Apple’s System Preference and Printer install tools
When I tried to select the 2400 to add it to my printer list I could only get the selection noted as
“QuadToneRIP 2.7.7 Epson R2400”
So I assume I would have to Remove QTR from the machine so there would not be this conflict
I used the QTR “uninstall” tool, deleted the QTR folder from the applications folder and also deleted QTR from the Library folder
however I still only get the QTR R2400 listing noted above when I try and add the R2400
I restarted the machine but nothing changes
what do I need to do now in order to be able to use this printer for both QTR and for regular digital printing
thanks for your help
Frank
Re: [QuadtoneRIP] having a challenge re-installing my Epson R2400 printer
2016-07-06 by Frank Eberdt
problem solved (so far, haven’t reinstalled QTR yet)
phoned Apple support and they walked me through how to delete my cached files
that solved the issue
regards
Frank
> On Jul 5, 2016, at 3:21 PM, Frank Eberdt feberdt@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Frank
