QTR-Quadtone RIP
Index last updated: 2026-04-28 23:12 UTC
gray photo gray matte printer profiles
2015-12-19 by walterbav@...
Using either lightroom or photoshop cc 2015 on an I mac 10.10 Yosemite. Have downloaded the QTR 2.7 I believe I have followed the instructions correctly but when I go to printer and select printer profile gray photo, gray matte and gray lab are not listed. The RGB photo, RGB matte and the RGB lab profiles are listed.
Thanks for any help
Walter
Re: [QuadtoneRIP] gray photo gray matte printer profiles
2015-12-19 by Norm Plummer
I’m having the same problem (see other post) with the gray profiles as well as some custom ones that I created with QTR-Create-ICC-RGB. Interesting enough, the 3880-EbvT profiles (which I downloaded from the net) work fine. I can print with the other QTR profiles (RGB-Matte, RGB-Photo) directly out of Photoshop with no problem.
Am still digging and will post when I figure it out.
Norm Plummer
> On Dec 19, 2015, at 12:29 PM, walterbav@gmail.com [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Thanks for any help
> Walter
Jeff,
PrintTool looks pretty interesting. However, If a profile is not appearing for other applications (like PhotoShop) will it appear for PrintTool?
Just wondering….
Norm
> On Dec 19, 2015, at 1:22 PM, Norm Plummer norm@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Norm Plummer
> > On Dec 19, 2015, at 12:29 PM, walterbav@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> > Thanks for any help
> > Walter
2015-12-19 by Roy Harrington
I guess its worth re-interating the color management issues on Mac.
1) Gray ICC profiles don't show up in Adobe products -- Lightroom or Photoshop
because Adobe has decided not to display them. The good news though is
that all the RGB ICC profiles work the same and show up as always.
If you are creating them use QTR-Create-ICC-RGB.
2) While you can use Photoshop to print, the color management is not strictly
correct -- you cannot disable CM, you cannot get exact results with CM and QTR.
(or other B&W driver like Epson ABW). Again the good news is that you can
still print and get high quality prints -- you just may need to edit the file to
compensate.
3) If you really want exact CM and create your own ICC profiles or QTR driver curves
the only exact method is to use Print-Tool. It's an extra product I wrote for this
as well as easier layout capabilities. It does No CM, and managed CM for
both Epson drivers and QTR driver both RGB and Gray.
Hope that helps.
Roy
On Sat, Dec 19, 2015 at 12:47 PM, Norm Plummer norm@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
Jeff,
Just wondering….
Norm
> Norm Plummer
> > Thanks for any help
> > Walter
Posted by: Norm Plummer <norm@normplummer.com>
Yahoo Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/QuadtoneRIP/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/QuadtoneRIP/join
(Yahoo! ID required)
QuadtoneRIP-digest@yahoogroups.com
QuadtoneRIP-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
QuadtoneRIP-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
Thanks to Roy for clearing thing up (once again and thanks for your patience!). Looks like PrintTool is the way to go - will be getting a copy shortly.
BTW; the problem with the RGB profiles not appearing looks like a permissions issue. When I opened the profiles up for both read and write, they started appearing. Won’t go into how to do that here because a person can really get themselves into a lot of problems playing on the command line….
Norm
> On Dec 19, 2015, at 4:01 PM, jeff.grant@... [QuadtoneRIP] <QuadtoneRIP@yahoogroups.com> wrote:
> Norm,
> I use PrintTool for QTR printing only. It shows me all the curves for my selected printer. I have no idea about ICC profiles.
> Sorry. I'm also nowhere near a Mac
