QTR-Quadtone RIP
Index last updated: 2026-04-28 23:12 UTC
Lineariztion and Ink Partition Question
2005-10-13 by Mark Stracke
I'm having trouble linearizing an 1160 with piezotone inks. I get the
Ink Pattern printed well and have a limit to set in the curve I am
making. The question is: how to determine the values I should enter
for the three grey dilutions? I'm on a Mac..
	When I try to linearize based on an included curve for piezo inks I
get an error regarding the densities not constantly increasing. The
readings I get from my eyeOne do seem to be increasing throughout the
scale, sometimes only by .1, but they do increase. This error problem
is why I am trying to build my own curve from scratch.
	I measured the max density patches on the other three inks. The
values are in L and converted to density. Do I use these numbers to
calculate the entries for my curve? And if so how? Or am I totally off
base. Any help would be appreciated.
btw, I have worked through this process before with the freeware Mac
program on 10.1 and 10.2. I stupidly threw out my old version and the
curves that had worked so well when I installed the latest version to
check it out. So I have some experience and have achieved success in
the past.
Thanks in Advance
Mark Stracke
Re: Lineariztion and Ink Partition Question
2005-10-13 by Olivier
If I can help : please see below.
Olivier
--- In QuadtoneRIP@yahoogroups.com, "Mark Stracke"
I have the same setting except a 1290 and XP, I assume you use only 4
parts of grey on a 1190.
inks I
problem
This is the way I adopted too. So first look for a DEFAULT INK LIMIT
by measuring the darkest (densier) patch of the Ink Pattern with the
smallest % (you should be somewhere 60-70%). I decided to take the
habit to limit a little more than balck boost is the way later to
increase Dmax.
Reprint with Ink limit (slider pushed a bit on the right in the main
QTR window, see Tom's tuto for images)at the corresponding %tage.
Make sure to re-measure the K line from 100% to 70%, density MUST
decrease.
The
off
Now you can measure the 100% patch of the other greys and convert it
into a %tage of K. Here I'm just copying another post :
we are looking for is what would match 1.29 (the 100% light-black)
so in the black ramp we have: patch 40 is 1.22 and patch 45 is 1.33
imagine that we had intermediate patches 41, 42, 43, 44 -- which is
most likely to match the 1.29?
mathematically what you doing is: 5 levels (i.e 45 - 40) is a
difference
of 1.33 - 1.22 = 0.11 but we only want 1.29 - 1.22 = 0.07
so (0.07 / 0.11) * 5 = 3.2 levels i.e. 40 + 3.2 = 43.2
Or:
wanted-diff-levels = total-diff-levels * (wanted-diff-density /
total-diff-density)
3.2 = 5 * ( 0.07 / 0.11 )
Now quickly since you know : you set up your curve, Black Boost (110-
115% of default ink limit, Highlight (4)/shadows (8); overlapping
around 10-15% to have some dark grey ink with K...
Now print the stepwedge with this raw curve (you've named and saved
it prior to this) possibly at 108% to have large patches on A4 and
measure more easily, measure it, drop it to the linearize droplet,
reprint the now linearised stepwedge, remeasure with the eye-one,
produce the file (either from a PM5 .txt example or apparently in any
format with the latest version) to drag-drop to Create-ICC. And
you're done.
If I'm wrong somewhere (I do it from memory), someone will surely
point it out.
Save your qidf and icc files in a safe place, this is all you need to
re-create the curves and the results.
to
> the past.
> Thanks in Advance
> Mark Stracke
Olivier
inks I
problem
increase Dmax.
decrease.
The
off
difference
Or:
total-diff-density)
you're done.
point it out.
to
> the past.
> Thanks in Advance
> Mark Stracke
2005-10-16 by Mark Stracke
Thanks Olivier for your advice. I'm still sticking on a point or two.
Reminder: I'm trying to linearize a piezotone inkset set on an 1160
printer.
   I'm on a Mac so I don't have the QTR window.
   After finding the ink limit from the first printing I reprinted the
inkseperation file and used the ink limit drop box in the final print
dialog to set the limit. I wanted to set 70% as my ink limit so I
chose -30 (lighter). There was virtually no difference in the
resulting print. The inks leveled out at the same point. I have
subsequently printed the file with -50(lighter) and +50(darker) and
all the prints are pretty much the same. Clearly I'm getting something
wrong here, any suggestions?
   set up: Inkseparation.tiff
   Mac OS X 10.4
   Photoshop 7
   open file with no color management
   source space-untagged rgb
   print space-same as source
   mode: qtr calibration
2005-10-16 by Olivier
Hi Mark,
The slider you want to move to 70% is actually the "Ink calibartion
mode"  called INK. It's in the middle of the window and it goes from
left to right. It's just above "ink limit adjustment shadows".
Olivier
two.
> printer.
main
print
something
>    Mac OS X 10.4
>    Photoshop 7
2005-10-17 by Mark Stracke
The problem is, there are no sliders. I'm using a Mac. Any insights on
why the ink limit setting in the printer dialog seems to have no effect?
Thanks!
Mark
> Hi Mark,
2005-10-17 by Olivier
I'm on XP. However I'm surprise on Mac you don't have the slider when
in Calibration mode : I think i's a farily standard interface Mac/Pc.
The Ink Calibration Mode slider limit the total amount of ink you will
be loading the paper with so that K goes clearly decreasing when
measured from 100% to 0% (in fact L* or density of each K patch). You
can then measure each other ink 100% patches vs the K patches.
If you do not have this slider (again I'm surprised)then I can't really
advise. But I'm very very surprised (you find it when you click option -
> calibration mode and can't miss it the heading is red.
Olivier
--- In QuadtoneRIP@yahoogroups.com, "Mark Stracke" <markastracke@y...>
effect?
> Thanks!
> Mark
Thanks again Olivier,
 Things do work differently on the Mac. Inkjet Mall has a good tutorial with screen shots so
you can see what I'm referring to. The Mac version follows the Windows about 3/4 of the
way down the page.
http://inkjetmall.com/nk7support/k7-2200-guide.htm
 The QTR dialogs are part of the print driver and you print out of an application. Selecting
"Calibration" from the drop down menu doesn't change the interface, and as I said I
adjusted the "Ink Limit Adj" drop down but saw no change at -30 (For my 70% limit) and
no discernable difference between -50 and +50. I made a huge move to see if anything
was happening and I don't see that anything changes. This should make a really big
difference, right???
  Can anyone from the Mac side advise on this? I have been making curves by guessing at
partitions and working on the text files, but I'd like to get some accurate readings on the
ink partions (black and 3 piezotone greys)
Thanks for any help
Mark
> Olivier
