QTR-Quadtone RIP
Index last updated: 2026-04-28 23:12 UTC
QTR 2.7.3 on windows and R3000 front loading
2012-11-13 by Ciprian
Hello everyone,
Windows 7, QTR 2.7.2, Epson R3000. Printing from QTR GUI to the R3000 works very well as long as I use the regular paper load. Yet under certain situations I want to avoid the rubber pick-up roller so I try to use the front loading mech. Except the printer will refuse to run the job.
1. Ready the TIFF to be printed
2. Set options in QTR (doesn't matter which type of paper or ink I select), makes no difference when it comes to the printer selection of matte/glossy ink
3. Open the manual loading tray, load paper following the LCD instructions
4. Open the file in QTR, click print.
5. Printer winds up some mechanisms inside...
6. Printer will display an error message on the LCD "Warning: The media loaded does not match the settings selected. Check the print settings or reload media"
... the only option being OK. Despite being a "Warning" the printer behaves as if it's an error; pressing the "OK" button will result in the paper being ejected. I've tested all available QTR paper sources and it makes absolutely no difference. While the printer is stuck with that LCD error message, the Epson utility give a status of:
For sheets of paper, remove the roll paper and then resume printing.
For roll paper, select Roll Paper as the Paper Source setting in the printer driver and then resume printing.
For CD/DVDs, select CD/DVD as the Paper Source setting in the printer driver and then resume printing.
For thick paper, select Front - Poster Board as the Paper Source setting in the printer driver and then resume printing.
So, anybody out there with an R3000? Can pretty please you confirm that you can in fact print from the manual front loading tray or confirm that this is indeed an issue? I'm pretty sure I'm doing everything all right so it looks like a QTR bug to me but I just wanted to hear other opinions...
Re: QTR 2.7.3 on windows and R3000 front loading
2012-11-19 by wattsies67
This does seem to be an issue.
I have been trying to get the Print Tool to print a front loaded A4 print with my epson R3000 on a Mac running OSX 10.7.5 and am experiencing the same problems.
It seems that when trying to print through QTR (ie with the QuadR3000 printer) that under paper size in page set up there is no option for "A4 (Fr.-FineArt(Borderless,Retain Size))" as there is if you elect to print colour through the normal epson printer set up.
Roy, are you aware of this issue?
Jason
--- In QuadtoneRIP@yahoogroups.com, Ciprian <ciprian333@...> wrote:
> Hello everyone,
Re: [QuadtoneRIP] Re: QTR 2.7.3 on windows and R3000 front loading
2012-11-19 by Ciprian
... phew! For I second I was afraid I was doing something stupid. So it is an issue on Mac as well as on Windows.
I'm pretty sure Roy is already looking into this; guess we're all eagerly awaiting for a new build of QTR. :-)
> Jason
> > Hello everyone,
> job.
> resume printing.
> printing.
>     QuadtoneRIP-fullfeatured@yahoogroups.com
Re: [QuadtoneRIP] QTR 2.7.3 on windows and R3000 front loading
2012-11-19 by Roy Harrington
QTR has never supported borderless printing on any printer in any slot.
 The (Borderless,Retain
> Size)) stuff is Epson paper descriptions so work only with Epson driver.
Ciprian's issue as far as I know and am looking into is using the front
loader slot
for photo or matte paper.  But borderless is not on the list.
Roy
> > Jason
> > --- In QuadtoneRIP@yahoogroups.com <javascript:;>,
> > > Hello everyone,
> > job.
> > resume printing.
> > printing.
> > Yahoo! Groups Links
> >     QuadtoneRIP-fullfeatured@yahoogroups.com <javascript:;>
Roy Harrington
roy@...
www.harrington.com
2012-11-20 by wattsies67
Roy
I'm not trying to print borderless, but the QTR tool does not allow any use of the front loading slot for fine art paper.  The reference to "(Fr.-FineArt(Borderless,Retain Size)" is the generic setting that seems to be in the epson driver to tell the printer the media has been loaded through the front slot.  It would be a pity if you couldn't print on fine art paper through the front slot.
Jason
> loader slot
> Roy
> > > Jason
> > > Ciprian <ciprian333@> wrote:
> > > > Hello everyone,
> > > job.
> > > resume printing.
> > > printing.
> > > Yahoo! Groups Links
> > Yahoo! Groups Links
> Roy Harrington
> roy@...
> www.harrington.com
2012-11-20 by Ciprian
Well a little bit of guilt could eventually be assigned to Epson also: if issued a paper source command for a previous printer model they could have mapped that command to something sensible... e.g. issue a "Manual Front" paper source to an R3000 then it follows that the user will be content with "Front Fine Art" as the closest equivalent to 2880.
Let's hope Roy will come up with a solution.
PS. Roy, under the clear understanding that borderless was and won't be an option it QTR, jus out of curiosity: why not? I mean why can't we have borderless? I mean was it that Epson did not release the ESC sequences to move the print head past the paper margin or was it something else?
> Jason
> using the front
> > loader slot
> on the list.
> > Roy
> print a front
> running OSX
> problems.
> QTR (ie with the
> page set up
> colour through the
> > > > Jason
> <javascript:;>,
> > > > > Hello everyone,
> Printing from QTR
> use the
> use the front
> to run the
> > > > job.
> which type of
> when it comes to
> paper following
> inside...
> on the LCD
> settings
> media"
> being a "Warning"
> pressing the "OK"
> absolutely no
> that LCD error
> paper and then
> > > > resume printing.
> Paper Source
> printing.
> Source setting
> printing.
> Board as the
> and then resume
> > > > printing.
> pretty please
> the manual front
> an issue? I'm
> it looks like
> other opinions...
> > > > Yahoo! Groups Links
> <javascript:;>
> > > Yahoo! Groups Links
> > Roy Harrington
> > roy@...
> > www.harrington.com
