Ignition magneto??
2008-02-05 by Mike Sullivan
Looking for a source for a couple of items for my 1985 3.5L Rover V8 with the 4CU electronic module. I would like the ignition magneto plate and possibly the temperature temperature sensor that determines vapor lock?? Distributor 35DM8 or the 35DLM8 I know that there are alot of sensors Airflow sensor Carbon filter solenoid valve CO resistor Coolant temperature sensor (CTS) or CTS circui Fuel pressure regulator Fuel pump relay Fuel temperature sensor Idle speed stepper motor Injector valves Oxygen sensor (OS) or OS circuit Throttle pot sensor (TPS) or TPS circuit Vehicle speed sensor
