Another Reynolds paper
2005-07-22 by curtgood
Hi, I am a newbie, and this is first post. Have enjoyed reading all the ideas, and when I came to the one on Reynolds Parchment paper, I thought it would be worth trying. However, the local supermarket did not stock the Reynolds Parchment paper, but did have one of it's own store brand. I thought I would try it, even though it was not labeled "silicone". I also found a new Reynolds Aluminum Foil, labeled "Non-Stick" that did have a silicone coating, so bought a roll of it. First tests indicate that both work very well, but the aluminum foil was especially interesting, since it transferred more quickly and more completely than the parchment paper, perhaps due to the better heat conduction of the aluminum. To run the foil through the laser printer [HP LaserJet 5L] I taped it to another piece of paper. Some care is required to keep the foil from wrinkling, of course. Since the aluminum is not transparent, it may be hard to get proper alignment, but it seems to me that this could be done with a few alignment holes punched in the aluminum to match marks on the pcb. I wonder if this could also be used to transfer markings to the painted front panel of a project? "Further experimentation is required." Regards, Curt W4QBU
