Uneven etching problem
2005-07-21 by Stuart Wallace
Bit of a ramble -- sorry about this...
I've recently developed a bit of a problem with my etching process and
I'm hoping that someone can give me some suggestions for improvement.
Up to now I've been etching FR2 boards at roughly 10/10 (10 mil tracks,
10 mil spaces) with good yield. I've recently moved to FR4 substrate and
8/8 rules in order to make a board for a slightly higher-speed design,
and yield has now dropped to zero. I've uploaded a couple of pictures of
my latest effort -- they were taken with a camera phone so they may not
be very useful. I have been experimenting with UV exposure times: the
top side of the board was exposed for 2 mins 45 secs; the bottom side
for 2 mins 30 secs. I normally expose for 2 mins 15 seconds but this
doesn't seem like enough for the FR4 board.
Top layer: http://www.atom.net/stuartw/board-top.jpg
Bottom layer: http://www.atom.net/stuartw/board-bottom.jpg
The details:
Artwork: transparencies printed at 1200dpi on a Canon i560
Board: Farnell FR4 double-sided photosensitised
UV exposure unit: home-built, 2x15W tubes approx. 5cm from the subtrate
Developer: Farnell KOH/NaOH pre-mix
Etchant: Farnell FeCl3 crystals made up to near-saturation
All the chemicals are less than one week old. I've used them to develop
and etch three Eurocard (160mm x 100mm) boards so far. My process
involves the following steps: drill some alignment holes in the board,
remove the protective sticker from one side and expose it, then remove
the sticker from the other side and expose that. I then develop the
board in a tray of developer solution at room temp while manually
agitating the board and turning it over frequently in order to try and
develop both sides evenly. After about 2 mins 30 secs I wash and etch
the board.
The problem is that I'm getting regions of board that are clearly
over-etched (e.g. top right corner of the top side in the picture above)
and other regions that have barely etched at all (left hand side of the
same picture). The under-etched regions emerge from the etchant stained
orange, which seems odd. I suspect that the over-etched regions occur
because I'm etching for too long as a result of the other areas which
refuse to etch.
I'm going to put my (home-built) bubble etcher back in to service this
evening to see if it improves matters -- so far I've been manually
agitating the boards in a bath of etchant.
Can anyone suggest any likely causes of this problem? I'm willing to
accept that my process may never be good enough to produce boards at
8/8, but the fact that I can no longer reliably etch even heavy tracks
is depressing!
Incidentally, I'm not at all happy with the quality of the Farnell
(Newark in the US, I believe) FR4 board -- I have found scratches and
areas of missing photoresist in the latest batch. Has anyone else had
this problem?
Thanks for your help.
Stuart
Re: [Homebrew_PCBs] Uneven etching problem
2005-07-21 by Leon Heller
To: <homebrew_pcbs@yahoogroups.com>
Sent: Thursday, July 21, 2005 4:59 PM
Subject: [Homebrew_PCBs] Uneven etching problem
> Hi,
I get boards looking like that when I use old PCB stock. The resist is only
good for six months or so after it has been applied.
Leon
Checked by AVG Anti-Virus.
Version: 7.0.323 / Virus Database: 267.9.2/53 - Release Date: 20/07/2005
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Re: Uneven etching problem
2005-07-21 by Phil
How are you getting circulation of your etchant?  I don't know if
that's your problem but when I've had uneven etching, it's been due to
poor circulation.  A good bubbler solved the problem for me.
--- In Homebrew_PCBs@yahoogroups.com, Stuart Wallace <stuartw@a...> wrote:
> Hi,
and
pictures of
> The details:
> the board.
above)
> refuse to etch.
> is depressing!
> this problem?
> Stuart
2005-07-22 by Russell Shaw
Leon Heller wrote:
> From: "Stuart Wallace" <stuartw@...
>>Hi,
> Leon
I agree. The solution is to lay the board flat in a shallow container of
ferric chloride and do the etching by brushing the etcher over the pcb
with a paintbrush for a few minutes until done. I'm using 5-year old pcb
like that and it comes out as sharp as fresh stuff.
The other problem you have is fine tracks being destroyed. This can be caused
by two things. If you remove the plastic film from the pcb then lay the pcb
printout against it from an inkjet, the outgassing of the ink can affect
the photoresist coating, as i found with epson ink and spray-on prp resist.
You must dry the printout in front of a fan heater for upto 10 or 15mins
until you can't smell the ink much.
If you leave the protective plastic film on the pcb, the ink of the printout
is then further away from the copper, and because the uv light is so close,
lots of undercutting and fuzzy edges can result. I fixed that by making a
uv light box that has a 125Watt mercury HID UV lamp backed with a cylindrical
parabolic reflector, and the globe is 60cm from the pcb.
2005-07-23 by Adam Seychell
Stuart Wallace wrote:
> Hi,
> Stuart
Is does appear like your getting uneven etching.
There are two main causes.
1) non-uniform solution agitation.
2) photoresist residue.
To solve problem 1, you have to attack your etch tank design. This
problem creates areas of the PCB that are over etched (traces get overly
thin or completely removed), while other areas remain slow to remove.
You picture shows the fiber glass weave pattern on the partly etched
copper foil. this leads me to think you have a resist residue problem.
I only have experience with negative dry film photoresists, and come
across the residue problem many times. The longer the film has been on
the copper the more difficult it is to remove the residue in the
developing step. PCB fabricators won't process a PCB with resist applied
longer than a day. I've had PCB stock with resist thats over a year old,
which can only be developed with difficulty.
The subtle problems of resist residue generally cause trace shorts and
various spots on the PCB, especially in "tight" corners where the
developing action was least.
The only fix I've found to using aged photoresist coated boards is to
be more aggressive with the developer. There is a fine balance between
over developing (causing traces to swell and lift) and under developing
(causing incomplete removal of invisible residue).
Use hotter developer solution ( 35\ufffd ~ 40\ufffdC), and longer times with the
paint brush strokes. Rinse then, etch for 20 seconds. If copper does not
turn matte pink in some areas then there this is signs of photoresist
residue.
Good luck
Adam
2005-07-23 by Bob_xyz
If the short etch does show signs of residue, can the board be rinsed
and additional developing attempted? Or is it all over at that point?
Regards, Bob
--- In Homebrew_PCBs@yahoogroups.com, Adam Seychell <a_seychell@y...>
wrote:
<snip>
Re: [Homebrew_PCBs] Re: Uneven etching problem
> Regards, Bob
Yes, I've done that before and it seems to work a 2nd time just ok.
Note: the residue is invisible. I've seen it as an extremely thin clear
film that peals off the copper when scrapped with a pin while viewing
under a 40X microscope.
> wrote:
> <snip>
