electroetch experiments => problem
2005-07-02 by mihai_hagianu
Hi guys, i have tryed before, and restarted now to experiment with electroetching, as an alternative method to FeCl3. I and up with the same problem all the time. The electric courent is peeling off any stencils i'm using. I have tryed toner, different paints i've found here in the house(few oil based,acrilic,enamel), and even sticky tape( :) ).I have also tryed different acid for electrolite ( H2S04, HCl, acetic)in different concentrations, to see any improuvement, but the result is the same: -if I put the board, with the selected stencil in the acid,without power connected to it, it lasts ok, - if I apply electricity to it, to start electroetching, it works ok for a while, but after some time, the stencils are peeled off, for a reson i do not undestand nor can prevent yet. - I have tryed to electroplate the board, to check if the peeling happens, and of course it does not. - I have tryed different current densities, but the peeling still happends...some times sooner, sometimes later. any ideeas what am I doing wrong ? thanx, Mihai
