PCBs at home
PCBs at home
2005-06-22 by Ray Dinwiddie
Hi all a new member, just found your group, thought I would share
some on my recent discoveries re; homemade PCBs.
Etchant: I use muratic acid (Ace Hardware) 1 part, Hydrogen Peroxide
(Walgreens) 2 part, heat to 130 F, agiate with air, and dissolve 1
Sq. In. single sided copper board per 1 oz. of etchant mix in about
20 sec. Advantages; cheep $.10 per oz.; very quick; clear, you can
see the copper vanish; safely dispose of 8oz. in 2 gal. of water
down the potty, and most importantly the hot quick action seems to
elimiate the pitting of the copper that a slower etchant bath
produces. Disadvantage: this solution saturates quickly and 1"
single sided board per oz of solution is close to the satuation
point, beyond which further etching ceases.
Etchant Tank: Plexiglas pipe 1/8 side wall, any diameter you want,
available at any local glass shop that advertizes plexiglas. Heat
the pipe in the kitchen oven at 250 F for 15 min. and strech it over
a wooden (1x4,1x6,2x4 etc) mandrel to form a oblong tube. When cool
pound out the mandrel. The tube shoud be about 2" longer that you
want the finished tube, so that you can cut off about 1" at each end
to remove the heat damaged ends. Cement the tube upright on a piece
of 1/4 plexigal sheet to form a base. The glue is the universal PVC
glue (Ace Hardware). Airate, with 1/4 clear PCV pipe plugged at the
end and perforated with a hot needle, aquarium air pump or
compressor, make a value by folding the air hose and pinching the
fold together at the exact spot with a clothes pin. Heat the tank
with a household heat lamp. Do the job outside!!.
Re: [Homebrew_PCBs] PCBs at home
2005-06-22 by Stefan Trethan
On Wed, 22 Jun 2005 07:30:50 +0200, Ray Dinwiddie
Heating the solution is a pretty bad idea, because you get a huge amount
of HCl vapor that is REAL BAD to anything around.
HCl doesn't have a fixed boiling point, but already below 50C it will
produce huge amounts of fumes.
safely dispose down the potty, must disagree. The 2 gal of water at best
protect your drainpipes, the sewage treatment plant still doesn't like the
copper. better bring to proper waste collection facility.
If you etch that fast, you have WAY too much H2O2. You will see serious
amounts of chlorine fumes, which are toxic. You should not see any bubbles
forming all by itself in a proper etchant.
My suggestion: Learn how to do a proper job and how to maintain this
etchant at a reasonable operation point (see CuCl etching links). Then you
will also be able to regenerate it and not need to put it down the drain.
Been there, done what you did, found it is no good.
The stretched tube idea isn't bad.
For those who can't get plastic pipe you can make a tank out of glass, is
easier to cut too. glue with silicone.
You will not have to go outside with a properly maintained etchant.
ST
Re: PCBs at home
2005-06-22 by Steve
My local plastics guy says plexiglass is not good for constant contact
with water. It will absorb some and swell, causing crazing.
Steve Greenfield
> > available at any local glass shop that advertizes plexiglas. ...
Re: PCBs at home
2005-06-23 by gregben
--- In Homebrew_PCBs@yahoogroups.com, "Steve" <alienrelics@y...>
contact
This is true. Here's a simple but long duration experiment.
Fill a 8x10" (approximate) tray (polyethylene is good) with
water (half full) and place
a piece of acrylic plastic (3mm thickness is good) over it like
a lid. The acrylic sheet needs to cover the entire tray and should
overhang a little on all sides. The sheet is not in direct
contact with the water. Note flatness of plastic at start of
experiment.
Leave undisturbed in a normal room environment for two weeks or
so. At the end of this period note warpage of acrylic plastic.
The observed warpage is due to water absorbtion on the bottom
surface.
