Homebrew_PCBs
Feed Screws for a Small CNC PCB Machine?
2005-05-16 by Bill Blackburn
Hi Guys
I am going to start building a small CNC milling machine (X = 7", Y =
7", Z = 6") for machining PCB's and I am wondering what I should be
using for the Feed Screws? I am not sure if a small machine like this
warrants installing Ball Screws? What about using a good stainless
threaded rod and a split nut to adjust the backlash? I have a Sherline
Mill with Stepper mounted directly onto the screws and I find the travel
speeds to be very slow. Sherline use 18 threads per inch on their Feed
Screws.
What are you guys using for your feed screws? When using directly
mounted Stepper Motors, what would be a good thread pitch for reasonable
travel speeds?
Thanks for the help.
Bill
Re: [Homebrew_PCBs] Feed Screws for a Small CNC PCB Machine?
2005-05-17 by Alan King
> travel speeds?
> Bill
Thinking 'linear motion products' but can't remember for sure if that's the
right company name. They have 1/4" lead screw, and plastic anti-backlash nuts.
A friend got some and 3 four foot sections plus screws was around $100 or a
little over, which isn't too bad really.
Most notable, pretty sure they had some that was 2 start. As in still 20
groves per inch, but 2 helix both at 10 pitch so you only had 10 turns to the
inch. Something like that is what you want if you can get it, still reasonable
from the smaller size but faster travel.
Alan
2005-05-17 by Stefan Trethan
On Mon, 16 May 2005 19:43:49 -0400, Bill Blackburn
<billblackburn@...> wrote:
> Hi Guys
> Screws.
> travel speeds?
> Bill
I will use M8 stainless on my machine. I think the pitch is too small but
it will only travel slower, i can live with that.
Don't have the money for fancy screws.
ST
