Re: [Fwd: Re: [Homebrew_PCBs] Re: bubbler - more air for bigger bubbles]
2005-03-15 by Stefan Trethan
On Tue, 15 Mar 2005 12:04:44 -0500, uhmgawa <uhmgawa@...> wrote:
> Why not just use an inexpensive air compressor?  Even tank
> models can be had for ~$100 at places such as Walmart including
> pressure regulator.  You likely only need 3-5 PSI at maybe
> 1-2 CFM if that.
> A compressor is also useful as a source of air for reflow
> soldering and vacuum source (with a $10 venturi style pump)
> for desoldering, pick/place, etc..
A normal compressor intoduces oil in the airstream and can not be run
closed-loop because of metal parts.
I have set up a small fridge compressure, small storage tank and a nice
panel with regulator, gauges, and outlet at my workbench for the other
stuff you mentioned.
ST
2005-03-15 by uhmgawa
Resend, was dropped..
-------- Original Message --------
Subject: Re: [Homebrew_PCBs] Re: bubbler - more air for bigger bubbles
Date: Wed, 09 Mar 2005 16:58:34 -0500
CC: uhmgawa@...
References: <d0nbcv+ra46@...> <422F65DD.9040802@...>
Adam Seychell wrote:
> This is where you need more
> air than conventional home fish tank air pump. I've looked around for
> such pumps and found some hydroponic stores sell large pumps, and then
> there are places that sell pumps for outdoor fish ponds and even home
> sewage treatment. There are high volume air pumps that are not too
> expensive. These cheaper high volume pumps are a bit louder and shorter
> life span, but that is unimportant for etching.
1-2 CFM if that.
uhmgawa@...        www.gnu.org
Oil lubricated compressors can introduce oil but inexpensive
filters are exist for common applications such as spray
painting which can be used to remove airborne oil.  Alternatively
an oil-less compressor (teflon piston) are available and typically
cost less than oil lube versions.
