Re: software 4 milling pcb ulp
2005-03-09 by lanebarr@bellsouth.net
there are a few ULPs for eagle that will do an isolation path
ok I fount a pile of ulp files which one should i use ??? OUTLINES???
how do you run a ulp from eagle???
can I mill and drill in the same pass???(with single sided boards of course)
I am thinking about autotrace in corel. That might do something similar.
Learning the hard way
Lane
Re: [Homebrew_PCBs] Re: software 4 milling pcb ulp
2005-03-10 by Brian Pitt
> course) I am thinking about autotrace in corel. That might do something
> similar.
> Lane
I think outlines.ulp was it ,I don't have eagle on this confuser so I'm going
from memory ,go to the 'file' menu pick 'run' and dig around for the .ulp file
you want to use
on a single sided board you can bend the leads out and surface mount
most things ,it looks a little strange at first but it saves a lot of drilling
Brian
"Nemo me impune lacesset"
