Multilayer press DIY?
2005-02-26 by mannapragada
2005-02-26 by curt_rxr
>If you have access to a drill press ( or better yet a milling machine )
> Anybody on the list know of a homebuilt multilayer (4 layers max)
> press? Think&Tinker website has a cryptic notation saying a press can
> be built for under 300 bucks but for the life of me I cannot find any
> specs or ideas after a couple of hours of on line searches. The
> Think&Tinker web site sells all the copper laminates for building up a
> multilayer stack but no furher mention of a press to press all the
> layers together. Any help would be appreciated.
> Thanks
> Madhu
2005-02-27 by Alexandre Guimaraes
> The only "gotchas" are to remember to step drill any through holes (.
> think Towers of Hanoi ) so you can solder to each layer and to preheat
> the press before use to help "kick" the epoxy.
> It works for me! ( And costs next to nothing!! )
> Curt Richards
> Curt Richards
2005-02-27 by Madhu Annapragada
>>Thanks
>>Madhu
> you can drill alignment holes in 2 pieces of steel plate. One hole
> will be the home or ( 0,0 ). Continue to drill holes at regular
> intervals corresponding to your normal board sizes along the x and y
> axes, taking care to keep everything square. Mount an alignment rod (
> I used 1/8 W2 drill rod )into the home position on one piece of steel
> plate( which becomes the base of the press ). Cut two more alignment
> rods and ease the ends such that they are a snug fit in the remaining
> holes. Reem the holes on the other plate so that it slides on and off
> the rods.
> When you go to laminate your board drill alignment holes in the stack
> before any other operation and check that the boards slide on and off
> the alignment pins. Etch your boards, spray the press with a light
> coat of silicone, squeegee on a thin coat of epoxy on boards and place
> on the base and lay the top plate on the stack.
> Curt Richards
> Be sure to visit the group home and check for new Bookmarks and files:
2005-02-27 by curt_rxr
> Hi, Curtsound so
> Do you have any pictures of the setup and process ? You make it
> simple !! Can you show us some more of it ?Hi Alex,
> Best regards,
> Alexandre Guimaraes
