PCB beginner
PCB beginner
2005-02-11 by Naveed Alam
I am a beginner and I intend to etch the PCD usind ferric chloride.
I want to know whether | should use marker to draw my PCB connections or is there any other technique to transfer the PCB to the board. Thanks.
Do you Yahoo!?
 Yahoo! Mail - now with 250MB free storage. Learn more.
Re: [Homebrew_PCBs] PCB beginner
2005-02-11 by Leon Heller
Sent: Friday, February 11, 2005 5:59 AM
Subject: [Homebrew_PCBs] PCB beginner
I used to get very good results with a fine paint brush and cellulose paint,
diluted with thinners. The thinned paint made it easier to get fine lines.
The paint was a better resist than the markers available then, and much
cheaper. I use the standard UV exposure technique now, of course.
Leon
Leon Heller, G1HSM
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.8.6 - Release Date: 07/02/2005
2005-02-11 by JanRwl@AOL.COM
In a message dated 2/11/2005 12:03:12 A.M. Central Standard Time,
naveedguy2@... writes:
If you have a Radio Shack (Tandy) store within reach, their
pressure-sensitive circuit patterns are the best thing since Swiss  milk-chocolate!  With
those, you can "rub-on" a PC pattern as fine as any  photographic method.  But it
DOES mean only a ONE-TIME pattern, of  course.  You must first clean the
copper with some household cleanser such  as Comet, etc., then rinse that
SUPER-well, and dry, and I usually at least  "wipe" the surface with lacquer-thinner
(acetone should do), and dry.   Then, apply the "rub-on".  then etch.
It is best to WARM the ferric chloride solution to about 38-40°C.  It  will
work much faster.  If hotter, it might loosen/remove the rub-on  stuff.  Not
sure.  I'm too shy to try!
Now the "professional" way to do PCB's is to make a 2x or 4x "artwork" and
then make negative films with which you "contact-print" onto a photo-sensitized
 etch-resist over the copper, but to do this successfully, one must have
experience, and a professional PCB house to do the actual "printing" and
etching.  Best, find a PCB house that will allow you to come over and gawk  and ask
questions.  Many won't HEAR of such a nice accomodation to other  than a
$250K/year customer, but some will treat young hobbiests with  civility.  TRY it!
Jan Rowland
