colophony as pcb protection - long term?
2005-01-30 by Stefan Trethan
I have recently bought a can of "lötlack" made by kontakt chemie / crc
industries germany.
The text on the can tells me it is colophony, and the smell tells me it is
solved in alcohol.
I didn't know before buying, and hoped it would be less tacky than the
homebrew colophony solved in alcohol brush-on. Well, it isn't, but better
slightly tacky than corroded.
What i wonder, what is the long-term experience with this sort of resin
coating on a PCB? Can i leave it on with no worries?
Are there other products that are as solderable but less tacky?
I know i could leave the PCB uncoated until after soldering, and use a
plastic spray, but it seems incredibly practical to just spray the fresh
PCB and not worry about corrosion, and having the added benefit of a flux.
Spraying over the colophony with acrylic to stop the tackyness seems like
a bad idea. But i don't want to clean it off (that tends to be so messy
and wastes loads of alcohol).
ST
industries germany.
solved in alcohol.
ST
