Homebrew_PCBs
Cables and connectors
2005-01-19 by Dale Mosby
I have made some boards using the toner transfer method with fairly
good results. Something closely related is the matter of getting
cables connected to a printed circuit board. I would very much like to
hear of good ways to build nice cables and connectors that are "clean"
and approach the looks and durability of commecial cables.
I work with amateur (ham) radio and many of the new radios use RJ45
plugs for the microphone. I do have a good crimp tool for RJ45 use and
make my own cables for home networking. I have constructed a couple
cables to connect to such radios, ending up with a short stub of cat 5
wire coming from the RJ45 plug then converting to some shielded wire
for audio and flexible cable for the other signals. I end up with
something that works, but is nowhere near as nice as the commercial
cable.
I suspect that there must be some injecting molding machine (at a cost
of a few million, no doubt) that creates all these nice cables that
come with commercial equipment. My current solder and heat-shrink
methods don't approach the quality of my PC boards and seem the "weak
link" in the homwbrew process.
What solutions have others found for nice cables & connectors?
Re: Cables and connectors
2005-01-19 by Phil
Can you find PCB mount connectors for all the connector types you use?
If so make a little PCB with the two or more connector types on it
and the correct wiring in between. Fisrt, though, find a box that
will fit the board and connectors, nibble out holes and you've got a
professional looking adaptor. Basically, an adaptor box. Easy as
pie. Or for stationary equipment, you can build a connector panel.
Lots of options.
Of course, there is no substitute for having the right connector on
the main PCB in the first place.
> cable.
Re: [Homebrew_PCBs] Re: Cables and connectors
2005-01-19 by James Washer
I think you missed the OP's point.
He's asking "how to make commercial quality cables".
- jim
On Wed, 19 Jan 2005 17:59:25 -0000
> Lots of options.
> > cable.
> Be sure to visit the group home and check for new Bookmarks and files:
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/Homebrew_PCBs/
> Homebrew_PCBs-unsubscribe@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Re: [Homebrew_PCBs] Cables and connectors
2005-01-19 by Leon Heller
Sent: Wednesday, January 19, 2005 5:05 PM
Subject: [Homebrew_PCBs] Cables and connectors
> cable.
I use Molex KK connectors, which are widely available. Suitable tools for
crimping the terminals aren't expensive.
Leon
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.6.13 - Release Date: 16/01/2005
2005-01-20 by ron amundson
> method with fairly
> matter of getting
> very much like to
> cables.
> radios use RJ45
> short stub of cat 5
> some shielded wire
> I end up with
> the commercial
> cable.
> machine (at a cost
> nice cables that
> and heat-shrink
> and seem the "weak
Vertical insert molding machines and molds are
actually not that spendy. $100K for a used machine,
and a mold would set you up real well, up to a few
hundred thousand/year.
Book molds are yet another way to go, figure on under
$10K tooling. But the piece part cost is higher, and
you are limited to the upper ten thousands/year. A
friend had his molds made for $3K, but its a really
simple connector.
As far as DIY, its time consuming.... but cheap
1. create a nice looking master (wood, clay, or wax)
2. create a silicon rubber mold from the master
3. create a clamping arrangement to hold the silicon
rubber mold onto the cable and connector
4. cast the connector/cable assmebly
Your biggest expense will be a vacuum system to degas
the casting material. If you don't mind a few bubbles
here and there, some materials are more forgiving and
work find without degassing. Silicon rubber molds are
good for 5 pieces if you are not careful, and you
might even be able to make 30 or 40 if you are
careful.
If you need more than 30 or 40, it pay be cost
effective to have a casting mold machined from
aluminum. I've got thousands of products in the field,
some of which were medical using aluminum casting
molds for the connectors. However for prototypes and
proof of concept, the silicon rubber works fine. Much
of the time, we installed small circuit boards right
within the connector assembly (the first few of course
were home brew).
Do not however try to use hardware store silicon. Its
not for casting, and does not work very well.
Ron
Do You Yahoo!?
http://mail.yahoo.com
2005-01-20 by James Washer
Ron,
thanks for providing this... but can you provide a bit more info?
Any "name brand" silicon I should buy?
I have a vacuum pump... but I cannot figure out how I would attach it to a rubber mold.. would that just collapse the mold?
Do you have any pictures?
- jim
On Thu, 20 Jan 2005 01:06:56 -0800 (PST)
> careful.
> were home brew).
> Ron
> Do You Yahoo!?
2005-01-20 by Stefan Trethan
On Thu, 20 Jan 2005 10:55:18 -0800, James Washer <washer@...> wrote:
> Ron,
> mold?
> - jim
you don't vacuum the mold, you need a small vacuum chamber in which you
put the container of silicone or whatever you want to use to cast. the
vacuum makes the bubbles HUGH and causes them to rise to the surface,
effectively de-gassing the liquid. then you take the liquid out and cast
with it.
Of course you can also vacuum the un-cured mold and pattern just after
casting if it fits into the chamber.
You can join <http://groups.yahoo.com/group/casting/> for more information.
I was looking into it a short while back, but decided it is too expensive
and i have enough stuff to do right now. But it opens a lot of
possibilities...
ST
Re: Cables and connectors - casting
2005-01-20 by Dale Mosby
Ron - Thanks for the pointer to casting group. I joined that, see a
huge number of posted messages and I will look through some of those
for information.
I was defnitely looking for something quite inexpensive - on the
order of my investment in toner transfer PBC process. I would not
mind the expense of a vacuum chamber to remove bubbles from rubber.
I have heard the warnings against using hardware store
Silicon "calking" for electrical wire potting. I have tried potting
connectors using some automotive gasket compound. While that had a
nice "rubber" feel to it, it did not seem to really "glue" itself to
the wires well. I have dripped some 5 min epoxy into things like the
RJ45 plugs to help anchor wires. That seems useful in limited
situations.
Any pointers to what to ask for as a molding compound that would dry
reasonably hard are stick well to insulated wires. Is "silicon
rubber" a well known description when looking for this material?
If we stray too far from PCBs or the discussion gets too long I'm
happy to take this away from the newsgroup. But making high quality
cables seems pretty closly related to making boards, as most of my
electrical projects have cables/connectors with them.
Thanks for the data so far. - dale
Re: [Homebrew_PCBs] Re: Cables and connectors - casting
> situations.
The hardware shop stuff doesn't lend itself to casting i fear. On another
note, never try to use acrylic sealant. i didn't have anything else at
hand and tried to isolate a 240V connection on a relais with it. I didn't
wait for it to cure and switched on, it does conduct electricity quite
well. Not sure if the cured stuff does too.
I'm not sure if silicone can be used for the plug housing too, it seems to
me it is meant for making the mold only. it does not stick to anything but
silicone (good for releasing the pattern from the mold).
But there are various flexible and inflexible casting materials you can
try.
As i have no experience with it i suggest you ask in the casting group.
ST
2005-01-20 by Norman Stewart
The big problem with the hardware store silicone (and this
goes for the industrial grades too) is that the inexpensive
ones release acetic acid in the curing process. This
attacks copper - wires, circuit boards, etc. Find a
silicone that doesn't have a vinegar smell to it as it cures.
Norm
Version: 7.0.300 / Virus Database: 265.6.13 - Release Date: 1/16/2005
2005-01-21 by Steve
--- In Homebrew_PCBs@yahoogroups.com, James Washer <washer@t...> wrote:
> Ron,
You can learn more at the NW Propmasters Yahoogroup, take a look in
the Links there. I'm listowner of that group, too.
http://groups.yahoo.com/nwpropmasters
You don't vacuum it while it is in the mold; you put the resin under
vacuum to pull the air out, then pour it into the mold.
I buy most of my silicone and plastic casting from Smooth-On.
Steve Greenfield
2005-01-21 by Steve
--- In Homebrew_PCBs@yahoogroups.com, Norman Stewart
Or use polyurethane rubber. You can get it in many different grades of
flexibility, from hard as a rock to so soft it is sticky. I think
those sticky lint rollers are made from a grade of polyurethane rubber.
Steve Greenfield
2005-01-21 by Alan King
If you do this part, get a Foodsaver. Good for food and pulls an ok vacuum
in one of the cannisters.
Try putting a loop or Z bend into the wire, and embedding it into expoxy or
other compound. Most cables are either fully molded as a single piece, or have
the cable jacked pushed back and reformed into a plug and the connector shell is
made around that. Take apart a few and you'll see that most aren't made like
you're talking about in the first place, so it's probably a bad way to go.. The
ones that are are the same material and solvent welded, you're not likely to
accomplish that with random wire jackets and potting material. Most wires have
release agents and/or a thin oil film from machine handling, you'd need a very
good strip and roughen before even trying to glue. Simply not worth the effort
vs more normal mechanical methods.
Alan
Re: Cables and connectors - vacuum chamber
2005-05-05 by Robert Hedan
I'm fabricating my own vacuum chamber right now. I'm using a
pressure cooker and 2 venturi pumps (PneuAire) connected to a
ordinary shop air compressor. I'm waiting for a reply from Maesco
for prices on their vacuum dial indicators.
The 9L. pressure cooker was on sale at Canadian Tire for $55, about
the same price on EBay for a used unit. Once I perfect the process,
I'm buying a 2nd pressure cooker, cutting the bottom on the 1st unit
and having it welded on top of the 2nd one.
That way I can expand my capacity and retain the existing plumbing.
The pumps and dial indicator are mounted on the existing holes in the
lid.
The nice feature of the pressure cooker is the quick release
mechanism. I was considering cutting & welding 2 barbecue tanks
together, but I'd have to fabricate a sealing section.
About degassing liquid plastics, unless I read wrong you have 2
alternatives (I'm not sure if this applies to other liquids):
1. place the unpoured mix in a vacuum chamber.
2. place the cast along with the poured mix in a high-pressure
chamber.
Robert
(sorry if this info was already discussed, I haven't read the entire
thread and I'm searching for Silkscreen information, this topic just
caught my eye)
Note: www.SmoothOn.com is an excellent source is materials for
casting. I use liquid plastic #326 for my casings.
you
surface,
cast
> with it.
after
information.
expensive
> possibilities...
> ST
Re: [Homebrew_PCBs] Re: Cables and connectors - vacuum chamber
2005-05-05 by Stefan Trethan
On Thu, 05 May 2005 19:57:19 -0000, Robert Hedan
> chamber.
> Robert
there is a good group on casting (casting@...).
Go there!
You can basically degass both, the moulding material and the stuff you use
to make the part.
You do not _need_ to degass anything, if you don't run into problems.
Vacuum makes the gas huge, causing it to rise to the surface and be
removed.
Pressure compresses the bubbles, they are still there, just compressed.
vacuuming removes the gas, it basically can't be bad. (tho make sure you
don't "cook" the material beyond the point where all gass is gone, at
enough reduced pressure everything will cook at room temperature). But if
you don't run into trouble don't bother to do it.
Pressuring is what i have read only useful in very limited applications,
for example casting clear parts where the gas is shrunk so tiny you can no
longer see it. (The casting must be put in the chamber, with the mould,
and stay pressurized until cured).
remember that if you pressurize a mould with bubbles, it will form small
hollows where the bubbles are close to the surface.
And most importantly: remember vacuum chanber failures are REALLY BAD!!
And pressure chamber failures are REALLY BAD!!. Even something like a seal
blowout can seriously damage your hearing. a 1 liter container opening
rapidly at only 1 or 2 athmospheres is really loud, you would not expect
it.
And also remember i did only lurk around the casting group for a few days,
deciding it is to complicated and expensive for me to get involved with at
this point, so i know nothing about it, at all.
But this is the wrong group for this anyway.
ST
2005-05-05 by Earl T. Hackett, Jr.
I didn't get the start of this thread so I'm getting in late. I take it
that the object is to make some custom connectors. I do this routinely to
make connectors that will fit into the recesses of my models. I also use
vacuum equipment to make castings and laminates (and on occasion a spy
satellite) so I have some experience with that process as well.
First, as far as safety is concerned, a pressurized vessel is far more
dangerous than a vacuum vessel. I was the safety officer for our autoclave.
To make me more attentive to the safety concerns, my office was in a direct
line with the autoclave door. If the thing blew, I'd go right along with it
across I-95. I made sure it wouldn't blow. Everyone probably has several
dozen vacuum chambers in their homes in the form of light bulbs. Failure of
a vacuum chamber results in things being drawn into the chamber, away from
the operator. As long as the structure doesn't shatter (like a light bulb)
not much harm can come of it. A pressure vessel failure can cause major
distruction even at relatively low pressures.
For potting connectors, there is probably no need for either vacuum or
pressure pots. There are epoxy formulations which will degas with little or
no assistance. The biggest problem is keeping the uncured epoxy in place
while not contaminating the electrical contacts. I've used Epon 814 and
Versamid 104 mixed at a @:1 ratio to pot circuit boards. This is not the
recommended mix ratio, but cured at 105°F overnight it produces a bubble
free solid matrix. If you can construct a 2 part mold and figure out how to
keep the resin from leaking out the bottom, it should be fairly easy to
produce your custom connectors.
For my purposes, since each connector is unique, I just plug headers and
sockets together (I use perf board to position the parts and major cutting
and fitting is usually required) then I use a brush to coat them with a
thixotropic epoxy paste. I then stick the whole mess into the spot where
they will have to fit (mold released of course) and let them cure. Do this
once for the male side and once for the female side and I have a connector
fitted to the particular installation.
2005-05-06 by Brian Clancy
Grant.
Light bulbs contain inert gas at atmospheric pressure.
Vacuum tubes (thermionic valves) contain? a vacuum.
This is why the glass is so much thicker than a light bulb.
The most dangerous example of the devices is the large TV picture tube.
If you have a look the faceplate glass is quite thick, especially on the
super flat screens.
Cheers
Brian
-------Original Message-------
Date: 05/06/05 09:08:10
Subject: Re: [Homebrew_PCBs] Re: Cables and connectors - vacuum chamber
Snip>
< Snip
2005-05-06 by rruss45826@aol.com
In a message dated 5/5/2005 4:07:58 P.M. Eastern Daylight Time,
robert.hedan@... writes:
Gang,
One word of caution here! Tanks and such designed for PREASURE don't
necessarily make good vacuum chambers! Catastrophic implosion can be just as deadly
as explosion! Please be careful! The best vacuum chambers I have seen are
just big enough to handle your need and made out of heavy lexan or plexiglass
Just be safe out there!
Ray Russell
NMRA-40609
General Contractor
Norfolk & Western Railroad
Pocahontas Division
Circa 1958
Visit The "NEW" Pocahontas Website at:_ Click here: N & W Pocahontas
Division_ (http://members.aol.com/rruss45826/public_html/index.html)
OR_ Click here: Pocahontas Home_
(http://milliron.home.sprynet.com/Pocahontas/Pocahontas1.htm)
For the old website!
In a message dated 5/5/2005 4:32:33 P.M. Eastern Daylight Time,
stefan_trethan@... writes:
it.
Wow! Talk about Karma! I just wrote the same thing before I read yours.
So to all of you attempting this out there! Do this in a safe zone and don't
be anywhere near it while it is functioning!
Ray Russell
NMRA-40609
General Contractor
Pocahontas Division
Circa 1958
2005-05-06 by Robert Hedan
Are there other dangers besides sound waves? I can easily protect against
that, I have high-quality ear protectors used at the firing range.
If a chamber implodes, can debris be projected outwards...?
Or is the contained liquid a source of danger? If so, I could easily drape
the unit with several layers of thick cloth. If there are no metallic
projectiles, that should be enough.
If I could afford a new vacuum chamber, I'd buy one. But the realities of
family life and trying to set up a lab is not compatible. I have to cut
corners, but I'm also trying to cut them as safely as I can.
Robert
-----Message d'origine-----
De : Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] De
la part de rruss45826@...
Envoyé : mai 6 2005 00:17
À : Homebrew_PCBs@yahoogroups.com
Objet : Re: [Homebrew_PCBs] Re: Cables and connectors - vacuum chamber
it.
Wow! Talk about Karma! I just wrote the same thing before I read yours. So
Ray Russell
Yahoo! Groups Links
In a message dated 5/6/2005 12:41:53 A.M. Eastern Daylight Time,
Robert
Sound waves can shatter your ear drums. Your heavy layers of cloth will
probably not help much here but your ear protectors are a good bet. While it is
true that explosion is worse, implosion carries some of the same issues. Stuff
can fly. Here a heavy blanket is best. The other thing that most people
don't think about is shock factor. What are you doing when it blows (Or sucks in
this case! 8>)) LOL If you are cutting out a previous mold you could
seriously cut yourself or others.
PLEASE! I am not trying to scare you! Just be prudent and be careful! Keep
the kids out of the way! ALWAYS ALWAYS test out a new device of this type
OUTSIDE for the first couple of times! If your going to pull it down 2
atmospheres normally pull it down to 3 several times as a safety check! A failure
outside is a whole lot safer then inside!
In closing just be safe! I have 3rd degree burns over 33% of my body from a
stupid mistake 20 years ago that to this day remind me to be careful!
Ray Russell
NMRA-40609
General Contractor
Pocahontas Division
Circa 1958
RE : [Homebrew_PCBs] Re: Cables and connectors - vacuum chamber
Ok, so an exterior testing session is warranted and no dangerous operations
must be done while the contraption is on. I can find a sand pit and put the
contraption in there for failure testing. I have a van, so transporting my
5500W generator for the electric air compressor is not a problem either.
How can you pull the vacuum down 2 atmospheres? Assuming I am at 1
atmosphere, isn't 0 a vacuum? Or did I miss something and you can a bigger
vacuum? Huh? How can you go to negative atmosphere? I thought atmospheres
were mostly used for pressure chambers.
I often see reference to 0-30Hg for vacuum chambers, something about mercury
level. I figure I'll see where the vacuum dial sits at rest, and where it
goes as air is pumped out is the vacuum side.
Robert
it is
Stuff
sucks in
failure
Ray Russell
Yahoo! Groups Links
Re: RE : [Homebrew_PCBs] Re: Cables and connectors - vacuum chamber
In a message dated 5/6/2005 1:21:48 A.M. Eastern Daylight Time,
Robert
Most vacuum is measured in HG which is mercury. being so heavy you can use a
much smaller scale! Now if I remember my old school books normal atmosphere
at sea level is about 15lb's per sq inch. Now 2 Ats. would be 30lbs per sq
inch. No go to vacuum and the same applies but in the opposite. So 30HG vacuum
would be 2 Ats. When I do A/C work this is the standard test we do. Draw down
to as close to -30 hg and cap it off. wait 1 hour and see if we have any
leaks then charge the system.
If I did not get any of the math right I am sure someone will jump in and
correct it! High school was a long time ago! LOL
Just putting the mold under 1 At or -15lbs of vacuum will do the job you
need to do!
Ray Russell
NMRA-40609
General Contractor
Pocahontas Division
Circa 1958
2005-05-06 by Stefan Trethan
> Keep
> type
> A failure
I did not know one could pull a vacuum of more than one athmosphere ;-)
On which planet (or under how much water) do you need to be to do this?
Implosions are generally just as dangerous. while the pressure differences
are smaller than with pressure tanks my personal theory is the lack of air
inside is the reason why flying debris is not decelerated on it's way to
the center. It does not stop there of course.
Testing a pressure tank is done with water, maybe a simliar approach is
good with vacuum. I could imagine filling it with old clothes for the
first try would help with the risk. (Using a liquid could be a problem
with the pump and boiling..)
That said, i think with a stainless steel tank such as a pressure cooker
the risk is acceptable.
Go to casting@yahoogroups, when i was there this very topic was discussed
to exhaustion.
ST
2005-05-06 by Norm Stewart
The 30 Hg is the height in inches of a column of mercury supported by
the vacuum (980 millimeters, for you metric buffs, , IIRC) - NOT the
weight in pounds. That corresponds to 14.7 lbs per square inch (sea
level, normal temperature). You can't do better than 1 atmosphere of
vacuum, even in outer space!
On the other hand, for outgassing resin, you don't need near perfect
vacuum; even a 5 pound vacuum will draw out lots of bubbles. Just use a
less viscous resin mix, or pump longer. Also, periodically relieving
the vacuum and then pumping some more seems to help.
Norm
>Robert
>need to do!
>Ray Russell
>NMRA-40609
>General Contractor
>Pocahontas Division
>Circa 1958
>Yahoo! Groups Links
Internal Virus Database is out-of-date.
Version: 7.0.308 / Virus Database: 266.11.0 - Release Date: 4/29/2005
2005-05-06 by Roy J. Tellason
On Thursday 05 May 2005 09:07 pm, Brian Clancy wrote:
> Grant.
I was of the impression that it was at somewhat lower than atmospheric
pressure, otherwise you wouldn't get that "pop" when they break.
As close as they could get to it, yeah.
Not that much thicker, overall. I sure broke enough of them when I first
started messing around with this stuff.around with it, about 40 years or so
ago. Maybe more so if you're talking large transmitting tubes, but those
aren't exactly common.
Those are rather dangerous, yeah.
> super flat screens.
The reason for that is two things -- that the outer layer of it isn't glass,
but instead is a rather thick plastic that won't shatter. Early sets had a
separate safety glass and the face of the tube was much thinner. The other
reason it's that thick is because of lead in the glass to absorb x-rays, at
least for color tubes, which is what makes TV sets and monitors a bit
"hazmat" rather than just being able to put 'em in the trash. Monochrome
monitors and old B&W tv sets don't have that issue.
On Fri, 6 May 2005 14:57:54 -0400, Roy J. Tellason
It is lower than athm., put a propane torch against it and the softening
glass will be pulled in.
(yes i am aware that experiment could have resulted in shattering hot
shards and be beeing blind...)
There's Argon in there.
> The other
> x-rays, at
Why is x-rays created, and why is it not beeing created in BW TVs?
Always wondered..
Hell this is getting OT.. maybe we should take it to E_101.
ST
It takes a certain technique to work with glass and have it not shatter. I
found that out the hard way back when I was into messing around with
chemistry sets and such stuff.
What I thought.
> > The other reason it's that thick is because of lead in the glass to absorb
> > x-rays, at least for color tubes, which is what makes TV sets and
> > monitors a bit "hazmat" rather than just being able to put 'em in the
> > trash. Monochrome monitors and old B&W tv sets don't have that issue.
> Always wondered..
Higher voltage. Typical monocrhome tube uses no more than 12-15KV for an
acceleratign potential, color tubes use 25-30KV. Apparently that's enough
to make a difference.
I can still remember the old tube-type color sets where the HV rectifier and
regulator tube were enclosed in metal, and if they'd been in service for a
while the glass would be a dark brown color from xray bombardment.
>>The other
>>x-rays, at
>Always wondered..
>ST
B/W tv's used 15Kv or so accelerating voltage - created soft x-rays.
Color sets needed more energetic electrons for the color phosphors, so
used ~23Kv, IIRC, and generated harder x-rays. The x-rays are only
generated while the HV is on - they are not residual. Any hazmat must
be in the toxicity of the phosphors used to generate the colors.
Norm
Version: 7.0.308 / Virus Database: 266.11.5 - Release Date: 5/4/2005
> >Always wondered..
> >ST
Even that's a little high, 12KV was more common.
> used ~23Kv, IIRC,
25KV was more common, and in the earlier tube stuff the shunt-type regulator
tube would age, and the voltage would climb somewhat, except of course that
the tube-type HV rectifier was also aging. Then there was the occasional
fault, like the infamous "4-legged capacitor" that Zenith had a problem
with. It seems that the cap maker substituted materials or similar and these
failed rapidly, and drastically, allowing the HV to go up over 40KV.
Sometimes it was so bad it'd arc right through the glass and crack the tube.
All of those failures were covered under warranty by Zenith, which was also
a matter in a lawsuit with the cap maker.
> and generated harder x-rays. The x-rays are only generated while the HV is
> on - they are not residual. Any hazmat must be in the toxicity of the
It's the lead in the faceplate glass -- read what I wrote up there.
2005-05-07 by Earl T. Hackett, Jr.
I should have been more specific - we use fluorescent lights.
As for vacuum chambers, I just measured mine. It's a commmercial unit made
of an acrylic type plastic, 1/8" thick, 12" in diameter, 12" high with a
flat top.
Sent: Friday, May 06, 2005 3:13 PM
