Hand solder 28 pin tssop?
2005-01-04 by Moore
I want to switch packages on a design, I've been using a 44pin plc
which is a reasonable challenge.  I'd like to go to a 28pin tssop.
ANybody hand soldered one of these?
 Phil
Re: [Homebrew_PCBs] Hand solder 28 pin tssop?
2005-01-04 by Kim Lux
Good question: I've got a similar challenge facing me.  A bunch of
components I need to use are only available as SM and I've never used
them on hand built boards.
I'll extend the question: do I need special tools to work with SM
components for prototype boards ?  I'm used to using a chip clip to get
signals off DIPs.  Should I put test headers on SM boards ?
Kim Lux,  Diesel Research Inc.
2005-01-04 by Stefan Trethan
On Tue, 04 Jan 2005 12:11:08 -0700, Kim Lux <lux@...>
you must decide if you want to iron-solder the ICs or use an oven.
for testing headers are a good idea, i think for some smd packages there
are test clips too.
ST
2005-01-04 by ron amundson
> using a 44pin plc
> a 28pin tssop.
> Thanks,
>  Phil
Its not bad under magnification. I avoid it, as its
time consuming, but  I've done a few boards with them.
Usually I cheat, and get my tech to build them... but
inevitably during test and debug, sooner or later I
need to replace it when he's not around.
A stereomicroscope makes doing so very easy. I have
done so with a magnifying head piece however. Lastly,
its a lot easier if you have solder mask... but with
care you can do so with a DIY board.
Ron
Do You Yahoo!?
http://mail.yahoo.com
2005-01-04 by Leon Heller
Sent: Tuesday, January 04, 2005 7:03 PM
Subject: [Homebrew_PCBs] Hand solder 28 pin tssop?
Quite easy if you use the 'drag-soldering' technique - tack down two
opposite corners, apply plenty of flux, put a small amount of solder on the
soldering iron tip and wipe the tip along the pins and remove any shorts
with desolder braid. It can be done with an ordinary soldering iron but a
Metcal like the one I use has a special tip:
http://www.metcal.com/tips/minhoof2.html#fine
Leon
Checked by AVG Anti-Virus.
Version: 7.0.298 / Virus Database: 265.6.7 - Release Date: 30/12/2004
2005-01-04 by Randy Wilson
One method it to "swamp solder" the part and then wick/suck up the
excess.  Someone has a web site on this, but I can't recall the URL.  I
do it with a hot air re-work station, but I sure miss the days when
everything came in a DIP.  Of course with lead solder going away and
new alloys coming into play we'll have even more headaches soon.
Re: Hand solder 28 pin tssop?
2005-01-04 by boons007
The Tssop28 is not a problem to work with,
you will need fine Tweeser, fine solder, a very fine tip.
and especialy "Magnifying glasses" and steady hands
It is easy to work with lead pitches of 0.5mm(0.020") or wider
i dont recomend the very fine 0.27 (0.012) lead pitches
the main problemn with tssop28 is if your etching boards and do not
have solder mask that you can easily short between the leads.
also if your using Toner transfer method the toner lines often will
short durring the Heat transfer process.
BoonS
used
get
2005-01-05 by Alan King
   Another vote for this, far faster than trying to do each pin seperately.  I
do it with my regular solder sucker, just hold it a little further from the pins
and it leaves just enough solder on the pins and pads.
2005-01-06 by Philip Pemberton
In message <crepa0+d2nq@...>
I've soldered an SSOP28 which is more or less the same as a TSSOP, just with
a larger body. I aligned it with blue-tack, then nudged it a bit with a
screwdriver to get the alignment absolutely bang on. Next I soldered two
opposite corners - the alignment was still OK, so I removed the blue-tack,
put some flux on the board (and lots of it!), put a bead of solder on the tip
of the iron and ran it down the pins. Repeat that for the other side, then
check for solder bridges and unconnected pins under high magnification and a
bright light. Clean off any bridges with desolder wick, then use Isopropyl
and a stiff brush to remove the flux residue.
Later.
Phil.                              | Acorn Risc PC600 Mk3, SA202, 64MB, 6GB,
philpem@...              | ViewFinder, 10BaseT Ethernet, 2-slice,
http://www.philpem.me.uk/          | 48xCD, ARCINv6c IDE, SCSI
... I tell them there's no problems...Only Solutions...
