Homebrew_PCBs
Archive for Homebrew_PCBs.
Found a GREAT way to remove the paper residue, after toner transfer!
2004-12-28 by Thomas P. Gootee
Everyone,
I have finally found a GREAT way to remove the "Staples Picture Paper" paper-residue from a pcboard, after doing the toner transfer step!
Now I just hope that I can identify what this material IS, that works so well.
I am using a type of handmade kitchen scrubbing pad, purchased a long time ago through one of my old software customers, which was made by a blind woman whom my customer knew.
At the time it was purchased, my wife was still alive. So she is actually the one who purchased these. However, I was present and did hear my customer and my wife talking about them. And I DO remember that they said that they were either MADE OF something called "Crinolin", or, were made of something LIKE something called Crinolin. And I am not sure of the spelling of the word "Crinolin". I also SEEM to recall hearing them say something about how crinolin might have been the material (or LIKE the material) that was used to make womens' old-fashioned petticoats!
It appears to be a very-loosely-woven, somewhat-rough, slightly-stiff type of fabric. In my case, the stuff used to make the scrubbing pad may even have been shaped more like yarn, as if it came on a roll instead of in a sheet, and was then just "woven" and/or knitted (or something) into the shape of a scrubbing pad.
But, anyway: This thing works GREAT!!!! Once the top layers of paper have been removed, I can use this pad to COMPLETELY clean off a 4" x 6" board in about 30 seconds, INCLUDING all of the drill holes and small spaces, with very little EFFORT!!
I had gotten very proficient at using a toothbrush, for this step. And this pad does the job in much less than 1/10th the time, with much less than 1/10th the effort.
Notes:
The material does feel slightly abrasive. HOWEVER, I could NOT get it to scratch the copper, even when pressing fairly hard.
I will email my old customer, to verify with her what the pad is actually made from. If I find out anything more than "crinolin", I will post it, here.
Good luck!
Tom Gootee
http://www.fullnet.com/u/tomg
Re: [Homebrew_PCBs] Found a GREAT way to remove the paper residue, after toner transfer!
2004-12-28 by Roy J. Tellason
On Monday 27 December 2004 08:48 pm, Thomas P. Gootee wrote:
> Everyone,
> well.
> Notes:
> here.
> Good luck!
> Regards,
> Tom Gootee
I mentioned this to my other half, along with filling in some of the
background on what all you guys were trying to do, and she said, if you
want to find some of that material, just go to any "retro" clothing store--
that they oughta be able to fix you right up. She also said something about
"transfer paper" being available at the majorly large craft stores
("Michael's" being one around here), I dunno if that has been considered or
not, though she did say it was expensive.
Hope this helps...
2004-12-28 by Alan King
Likely the kind of thing that will sound right to your wife but be way off
for using..
Cut out vinyl letters. Peel away the scrap. Loose letters on backing. How
to get them to where you want them to go and keep the spacing? Transfer paper,
paper with moderate stick on one side. Put it on letters, peel it and letters
from backing, apply letters to surface, then peel transfer paper back off
letters. Just holds the spacing. Moderate stick paper but I don't think it'd
work for getting out of holes etc. Could be something else for some other
manner of transfer and more suitable, but this is the usual type.
As always, just do as I do and fuse several times when printing before the
ironing. Peels away cleanly after ironing that way, hardly had to do any
toothbrushing for a long time now. I'm using JetPrint Photo, but I assume
they'll all work about the same. Dry that coating out more thoroughly before
you iron and it won't stick much where there isn't toner in the first place.
Still haven't bothered baking after printing though for a proper drying, a
couple extra fusing passes does it well enough.
Alan
Re: Found a GREAT way to remove the paper residue, after toner transfer!
Alan,
Actually, the different paper types all work DIFFERENTLY, that way.
i.e. The JetPrint Photo Multiproject paper is ALWAYS that easy to remove, for me. But the Staples Picture Paper is definitely NOT easy to remove (until now!).
I have to use the Staples Picture Paper, instead of the much-easier-to-remove JetPrint paper, because, with my printer/toner combination (HP LJ4/HP toner), the Jetprint paper usually gets lots of pinholes in the large (and also often in the small) areas of toner, no matter what printer settings I use.
I will try the "multiple fusings" procedure again, with more than two passes this time, to see if that helps significantly, with my setup and the Staples paper.
Tom Gootee
ORIGINAL MESSAGE:
Date: Tue, 28 Dec 2004 01:04:42 -0500
Subject: Re: Found a GREAT way to remove the paper residue, after toner transfer!
<snipped>
Alan
2004-12-28 by iR
a while back i discovered 'THE BEST" way to remove the papaer residue
**Ammonia based windows cleaner**
also, before you do the iron on, clean the board with window cleaner -
works much better then meths, and unlike steel wool, doesn't take any
of the copper of with it
anyhoo... after ironing, take a blade from a craft knife and seperate
the backing of the paper from the coated side. it's very easy - the
coated side is stuck down firm and the paper back isn't. peel it all
off with the blade. now then, normally you'd think to soak the
remaining paper off with hot water for 20mins or whatever - don't
bother! spray the board with window cleaner making sure it soaks in
properly - which it will do much better and faster (re:instantly) then
water does. now then, no waiting around, no soaking for minutes,
simply rub the paper off! use a sponge, a dish brush, your finger,
anything! it'll come off easier then you could have imagined
hope this helps you all
cheers
iR
http://oc4free.scalded.net
2004-12-29 by ballendo
Well, Paul simon spells it Crinoline... <G>
FOR EMILY, WHEREVER I MAY FIND HER
PAUL SIMON
What a dream I had, pressed in organdy
Clothed in crinoline of smokey burgandy
Softer than the rain
I wanderd empty streets, down past the shop display
I heard cathedral bells, tripping down the alley-way
As I walked on
And when you ran to me, your checks flushed with the night
We walked on frosted fields of juniper and lamplight
I held your hand
(instrumental)
And when I awoke and felt your warm and near
I kissed your honey hair, with my grateful tears
Oh I love you girl
Oh how I love you girl
--- In Homebrew_PCBs@yahoogroups.com, "Thomas P. Gootee" <tomg@f...>
wrote:
> Everyone,
step!
works so well.
> Notes:
will post it, here.
> Good luck!
> Regards,
> Tom Gootee
RE: [Homebrew_PCBs] Re: Found a GREAT way to remove the paper residue, after toner transfer!
2004-12-29 by Gary Anderson (G)
Hi iR
What kind of paper are you using that this process removes the paper.
Iam new to the group and my first board didn't work so well.
Iam using a Lazer4L printer and normal 80g paper. I ironed it onto the
board and the image did transfer, but it wasn't very clear and after
etching the tracks were not of equal size.
Iam doing things correctly???
Gary
ZR2G
Sent: Tuesday, December 28, 2004 11:44 PM
Subject: [Homebrew_PCBs] Re: Found a GREAT way to remove the paper
cheers
iR
Be sure to visit the group home and check for new Bookmarks and files:
http://groups.yahoo.com/group/Homebrew_PCBs
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
<http://us.ard.yahoo.com/SIG=129s3b174/M=295196.4901138.6071305.300117
6/D=groups/S=1705083291:HM/EXP=1104356686/A=2128215/R=0/SIG=10se96mf6/
*http:/companion.yahoo.com>
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=gro
ups/S=:HM/A=2128215/rand=558404249>
Yahoo! Groups Links
* To visit your group on the web, go to:
http://groups.yahoo.com/group/Homebrew_PCBs/
* To unsubscribe from this group, send an email to:
Homebrew_PCBs-unsubscribe@yahoogroups.com
<mailto:Homebrew_PCBs-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
This e-mail and its contents are subject to the Telkom SA Limited
e-mail legal notice available at
http://www.telkom.co.za/TelkomEMailLegalNotice.PDF
2004-12-29 by Thomas P. Gootee
iR,
Thanks for the suggestion!! I will definitely try it, with the next board I make, with the Staples Picture Paper.
By the way: I have started using a lot more pressure, when I iron the toner on, using mainly just the tip of the iron, after preheating the board. And now I find that I don't have to soak the board for more than about one minute. I usually run cold water onto the board for about half a minute or less, to cool it, initially, and then hot water for about one minute, after which I can peel all of the top layers of paper off using my thumbs and fingers, very quickly. Then I re-wet the remaining layer with hot water for a few seconds and use the crinoline pad to remove it, which takes something like half a minute for a 4" x 6" board.
Tom Gootee
=======ORIGINAL MESSAGE:
Date: Tue, 28 Dec 2004 21:44:06 -0000
cheers
iR
Re: [Homebrew_PCBs] Re: Found a GREAT way to remove the paper residue, after toner transfer!
2004-12-29 by Leon Heller
Gary Anderson (G) wrote:
>Hi iR
No, ordinary bond paper isn't suitable. You need 'shiny' paper like that
used for glossy magazines, which is coated with clay, or ink jet paper.
Glossy magazine paper works very well, BTW.
Leon
Checked by AVG Anti-Virus.
Version: 7.0.298 / Virus Database: 265.6.5 - Release Date: 26/12/2004
2004-12-29 by Alan King
> Alan,
> now!).
Well the JetPrint does work very well even without multiple fusings with your
webpages normal method, I did neglect to fill in that I have also modified other
things. I'm generally too impatient to see the outcome to allow it to soak
well, so I changed other aspects to not need soak time. In that case, even
JetPrint leaves an annoying level of junk in parallel traces, TSOP pads, small
holes, etc. The extra fusings make it work great even without much soaking, I
have my boards in etch within 5-10 minutes of printing and etched and starting
soldering with 45 mins to an hour. Even at that a bit longer soaking does make
it a little easier, but almost always I just get too annoyed to wait.
Might want to keep an eye out for a HP 6L. I've had great results with mine,
the toner is different and seems generally easier to deal with than the LJ4 test
prints I've done. Can't really recall any pinholes, but as long as the board
comes out usable with SMT with sharp trace edges I haven't searched too
critically, so may have had one here or there. Also to make sure we're
comparing apples to apples, I'm using the Graphic Image Paper that has lees
chance of pinholes but leaves more junk on the board not the Multi Project that
has more chance of pinholes but leaves less on peel. Just the GIP leaves almost
nothing as well with multiple fusings, even with no soaking..
> paper.
I really just went to 3-4 fuses once I had the idea to do an extra just to
make sure, may not be any improvement over 2 just takes little effort for
another extra pass or two. Again even that may not matter with a reasonable
soak, I iron, run cold water for a min or two while forcing into the paper with
my thumbs, and then start peeling. Too damn impatient I know but it is working
well enough for TSOP level parts for me. Also seems to make the ironing phase
less critical. Caveat that my boards do tend to be 4"x3" or less and SMT, few
large areas etc, so larger boards would likely take a bit more care even with
what I'm doing. But mine are relatively complex for the size with usually lots
of traces in tight spacing, so a pretty good test of what's happening.
Still haven't tried the Staples myself since I have plenty of JPP on hand and
Staples is 30 miles away. But from the general reports of a little more
sticking I'd guess it has a higher moisture content in the coating to start,
just a basic guess but the extra fusings should have an even greater improvement
for it, so worth testing.
2004-12-30 by x xx
"Crinoline" is an undergarment. "Crinolin" is a material, correctly described below, used to give shape to the attenunated crinolines that were the rage in the late 1950s.
Sam, who was old enuff to appreciate them and who is still young enuff to treasure the memory :-)
PAUL SIMON
As I walked on
I held your hand
(instrumental)
Oh I love you girl
wrote:
> Everyone,
step!
works so well.
> Notes:
will post it, here.
> Good luck!
> Regards,
> Tom Gootee
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
Post your free ad now! Yahoo! Canada Personals
[Homebrew_PCBs] some progress and a few problems
2004-12-31 by Terry Mickelson
Some time ago, I tried the blue "press-n-peel" transfer system with
limited success. Their press was also purchased and I think that was a
good idea. Just lately, more press-n-peel was ordered but it looks
thin, the coating was light and streaky and the hp-1300 printer must
have liked it a lot because it just ate this new stuff. I sent the rest
of it back.
Taking the advice of some members of this forum, a local printer gave
me some magazine paper. It's glossy on both sides, takes toner well and
comes off afterwards. He also said that ink-jet paper had a pitted
surface that takes ink in small puddles but will put small holes in
toner. Could be.
One of the first problems that I ran across with this paper was a
close but not exact alignment between the top and bottom sheets on a
light table. They should align exactly since they came from the same
drawing, just different layers. I use Canvas 9.
Next came time and temperature in the press:
At 350 degrees and 45 seconds, toner runs like water. HOT = wavy edges
to lines.
It had slightly better line definition, i.e. straighter edges to the
lines, at 250 degrees for 5 minutes. It got even better at 200 degrees
for 5 minutes. Next, I'll try a lower temperature but there're no
markings on the press below 200 degrees. I put a piece of thin double
sided PC board in the press to act as a bottom plate. The work is put
between this and the press's hot plate. So far, no differences have
shown up between the (work) PC board's two sides.
Toner transfer here (200) was virtually complete. Some holes appeared
but that's more likely due to board cleaning faults. Thanks for the tip
on using a rag instead of paper towels too! I'm getting closer but we
all seem to know that we won't get the best results until we've seen
every possible fault first.
Please keep posting. Even a one liner can save hours of otherwise
wasted time.
Thanks to all,
TM
2005-01-02 by iR
--- In Homebrew_PCBs@yahoogroups.com, "Gary Anderson \(G\)"
<andersg@t...> wrote:
i'm using "HP Everyday Semi-gloss photo paper"
it's nice and cheap at $14NZD (~$10USD?) for 100 A4 sheets. i'd assume
full gloss paper works too but haven't tried it as this stuff is fine
cheers
iR
> Hi iR
> Thanks
> Gary
> ZR2G
> -----Original
Message-----
> From: iR [mailto:irmadman@h...]
> cheers
> iR
> ADVERTISEMENT
> click here
Re: some progress and a few problems
2005-01-06 by Vasile Surducan
--- In Homebrew_PCBs@yahoogroups.com, Terry Mickelson <tmdslca@t...>
system with
was a
must
rest
> of it back.
printer gave
well and
in
> toner. Could be.
was a
a
same
No, just because one is mirrored. Some printers alter the drawing
scale even it shoudn't. My best results were on Xerox authoadesive
paper, where the paper itself was removed and the toner was
transferred on the glossy face.
I suggest to keep the temperature as high as possible and put a few
papers between your iron and the shit to be transferred.
best regards,
Vasile
http://surducan.netfirms.com
2005-01-06 by Phil
--- In Homebrew_PCBs@yahoogroups.com, "Vasile Surducan" <vasile@s...>
Note also that moisture content of the transfer substrate (i.e. paper)
is a factor here. I've been running the paper through the
printer/copier several times to dry it out before actual printing.
Seems to reduce distortions.
Phil
