laser printers
laser printers
2004-11-05 by Susan Kivlin
I've been reading for a while but have never contributed so I hope you
don't mind me asking a
question.  Here at the university I've all the facilities for pcb
manufacture but my printer is to be
replaced with a new one.  The printer that I have, although it is
1200dpi, spreads the ink to the
extremes of tracks and solid copper areas, this as you know can cause
pitting.  It also stretches
the transparencies I use ( I've tried others with the same results ).
This is OK for small or
undrilled pcbs but for large i.e. > than 100mm by 160mm that have
already been drilled this causes
line up problems.  The software I use, Target 3001, enables me to
compensate for printers that
don't print true 100% but the stretch in my print outs vary each time, I
guess from the heat in the roller.
So my question is does any one have any recommendations for a printer.
The printer I use at the moment is an Hp laserjet 1200.
Thanks in advance
Susan
Re: [Homebrew_PCBs] laser printers
2004-11-05 by Stefan Trethan
On Fri, 05 Nov 2004 16:42:03 +0000, Susan Kivlin <sac@...> wrote:
> Hi,
> Thanks in advance
> Susan
Some have reported good results with tracing paper instead of
transparencies.
Others swear inkjet is the way to go, as there is no distortion.
There seems to be a big variety in ohp transparency quality, but if you
already tried a few..
The fuser temperature is not that much different with other printers, but
the transport system might be.
I didn't know anyone outside Germany uses Target, how is the 3001 version?
I think about buying
it because anything better is unafordable, but haven't actually done any
tests on the new version.
I used to use 2001, and it was a nightmare compared to orcad.
ST
Re: laser printers
2004-11-09 by Susan Kivlin
>>ST
Thanks Stefan,  I'll try inkjet today.
As for Target 3001!, I don't know how it compares as I've only used
orcad as a simulator and I've only used Target for pcb layout although
it also has a simulator.  As a pcb tool I've found Target to be easy to
use and have produced many boards that have been made here but also sent
out for manufacture.  We have produced 2 and 4 layer boards and all have
been fine.  We use pcb pool for manufacture and Target has an output
feature specifically for them.
I'll report how I find the ink jet printing.
Susan
