Homebrew_PCBs
CuCl questions
CuCl questions
2004-09-19 by Phil
I've used up my Ammonium Perchlorate so I got HCl and H2O2. I
understand that I need to use a bubbler to regenerate the etchant and
have seen references to letting it run a long time. How long should I
expect - hours? days?
Currently, my bubbler is a piece of vinyl tubing that I drilled #70
holes in, This produces somewhat large bubbles. I'll try it but do
those of you that use CuCl recommend something different, like an
aquarium airstone?
I'll be using about 3 Liters and doing a number of double sided boards
in the 10x15 CM size range, 1 oz copper. I have an aquarium heater
that will bring the temp up to about 100F (about 38C) if that matters.
Phil
Re: [Homebrew_PCBs] CuCl questions
2004-09-19 by Stefan Trethan
You need no bubbler with H2O2.
The H2O2 is the "quick" version to get the oxygen in.
The slow and nasty fumes version is to keep it bubbling for hours,
then it takes the oxygen from the air.
So you see, no bubbler required. You can keep it and see if it speeds up
etching because of the agitation.
> aquarium airstone?
As said if you use H2O2 for regeneration it isn't needed.
The big bubbles will be fine for agitation though.
NO DO NOT USE A HEATER!!!!!
The boiling point of HCl is VERY low, and even below the fumes increase
dramatically with heat. I experimented with that and don't want to repeat
the experience. Use a bubbler or mecanical movement/oscillation of the
board.
I'm still wondering if high frequency vibrations or even ultrasonic would
be a
good idea.
Quick guide for getting started:
Dilute the HCl to 10% or so. Put the board in and add a small amount of
H2O2.
You should see a reaction on the board and the etchant coloring slowly.
tiny bubbles are ok, but bigger, fast rising bubbles indicate too much
H2O2.
You must avoid that condition.
The H2O2 needs replenishing when the etchant turns from bright green to
dark green.
The HCl will need replenishing when you see blue "sludge" on the board and
etchant also gets slightly bluish. It is better to measure the HCl
molarity than
just using the blue sludge as a sign. see links section for a simple mehod
using two eyedroppers.
At the beginning you will need H2O2 each time. After enough boards there
is enough copper in to etch with CuCl only. Then you only regenerate with
H2O2
when the color turns. (note: H2O2 is lost if there is nothing to
regenerate left,
so don't add too much).
If you observe the things described it is a very good and cheap etchant.
Possible problems:
resist attacked (especially touch-up markers): reduce HCl, measure molarity
long etch times: not enough Cu solved yet, not enough H2O2.
etching stops suddenly but etchant is bright green, H2O2 doesn't do
anything:
HCl used up completely, add some, see the blue sludge on the board.
I hope i covered the most important things.
I really should write that up some day....
ST
P.S.: We MUST RESEARCH effects of vibrating the board and using ultrasonic
sound.
Could please someone use a ultrasonic cleaner (with water) and see if the
toner
comes off?
Re: CuCl questions
2004-09-19 by Phil
Thanks Stefan. This is the first time I've heard not to use a heater.
I recall reading somewhere to heat the CuCl solution so its a little
confusing. I looked for the page that said that but couldn't find it
since I didn't bookmark it. It might have been one that talked about
using CuCl salt, though.
I guess technically, this is HCl etching at first and then CuCl.
A How-To for HCl and H2O2 etching would be very useful.
Phil
repeat
> board.
would
> be a
> good idea.
Re: [Homebrew_PCBs] Re: CuCl questions
> Phil
you are right there, first Cl only, then CuCl.
the heating is no good. only a little is possible and that isn't helping
much.
HCl vapor is bad business, very bad.
Tomorrow i will try using pool-supply Clorine to regenerate. curious and
have a pool. 'night.
ST
[Homebrew_PCBs] pool clorine any good for CuCl?
2004-09-20 by Stefan Trethan
Hi all,
i was thinking the whole HCl H2O2 business is just for
getting Cl into the etchant to attach to the Cu, right?
So i thought maybe there are other ways to get this done.
Pool clorine.
There are two types, anorganic and organic.
the organic version is for long-term, it is cyanuric cloride.
(it is a acid).
I had that so i put a few shavings of a tablet in a small amount of used
CuCl.
No regeneration could be observed but there was severe gassing and clorine
gas smell.
I diluted that and disposed of it. (was only a tiny sample).
The anorgainc clorine used in pools is calcium hypochlorite.
it is used to quickly kill everything if the water is already half green.
It is not used for long durations (it doesn't stay in the water).
I'm not sure if i have that variety somewhere to try. I would guess
it is potentially better useful for CuCl etcants, because using another
acid seems
not the solution to simplify the process.
I do not have the chemistry knoweledge to find out what is going on there,
but i'd like to know what you think of using other forms of clorine than
HCl
as clorine source.
Could calcium hypoclorite potentially work? could sodium hypoclorite
(bleach)
potentially work? Why not?
Could someone summarize the chemical reactions in CuCl / HCl / H2O2
etchants
in simple terms, so that i might understand it too?
Well, thanks a lot.
ST
[Homebrew_PCBs] CuCl pool stuff
at tha classic CuCl page:
<http://users.rcn.com/rexa/Projects/CuCl_ech.html>
I found
> It should be noted that in commercial high-volume applications
> regeneration of cupric > chloride by air oxidation is too slow to be
> completely practical, so faster methodsare used to reverse the reaction,
> such as direct chlorination, electrolytic action, or > intense oxidation
> with hydrogen peroxide or sodium hypochlorite.
see, sodium hypochlorite! that's bleach, well, one kinds of bleach.
I wonder if calcium hypochlorite does the same.
ST
Re: [Homebrew_PCBs] CuCl pool stuff
2004-09-20 by Earl T. Hackett, Jr.
I'm going back 15 years or so, when cupric chloride etching was becoming a
common system. I don't remember anyone replenishing their etchants with
anything other than hydrogen peroxide and hydrochloric acid. These are
cheap chemicals and the waste can be easily converted to copper oxide
(hydroxide) and sent off for reclaimation. A production etch line was 4 ft
wide and ran 4 to 6 ft per minute with 18 x 24" boards spaced 2" apart.
That's a lot of copper going into solution so the etchant had to be
replenished at a high rate. For the hobbist who etches a board once a week,
simply bubbling air through CuCl etchant and adding a bit of HCl is the
easiest method to regenerate the etchant. If you want to run bigger batches
of boards, get a bigger sump of etchant and let it regenerate for a few
days. One of the links on the list suggested using a picnic cooler as an
etch tank - IMHO a good idea.
The addition of any additional salt content, either sodium or calcium, can
be a problem. I'd have to dig way back to get the details, but in general,
its a good policy to avoid adding stuff to a chemical system if it can be
avoided. There are side reactions that can be really bad news - like
hydrogen gas generation that can cause big BOOMS.
Sent: Monday, September 20, 2004 4:03 AM
Subject: [Homebrew_PCBs] CuCl pool stuff
> I found
> ST
> Be sure to visit the group home and check for new Bookmarks and files:
2004-09-20 by Adam Seychell
I agree. Its best to keep the chemistry simple, and air is not something
that you can add too much of. I found that air regeneration of CuCl
depends greatly on bubble size. The finer the bubbles the faster the
regeneration. If the bubbles are extra fine then the regeneration rate
is fast enough to cause noticeable heating. A 1 or 2 inch layer of
foaming on top of the etchant makes it work very fast , in one or two
hours or so compared to several days. If anyone is getting problems
with HCl fumes then they have too much acid. Air generated CuCl etches
ok with almost zero acid. The important thing is to keep the tank
relatively sealed because of mist produced from bursting bubbles will
eventually cover everything in the surrounding area with microscopic
droplets of etchant.
