photoresist using laser printing
2004-09-18 by Tom Keys
I've read somewhere that people don't like using laser printers for
making their artwork, when using photoresist.
  Is the reason for this that the toner is not dark enough?
  I'm asking, becaused something came to my mind.  You can buy foil
transfer for laser printers and copiers, for as low as us$15 for 8"x100'.
  I can't see foil itself being transparant to light in any way.  Has
anyone ever tried this?  Print the artwork onto a transparancy, then
transfer the foil onto the toner, should give you 100% opaque artwork
for the photo transfer.
Re: [Homebrew_PCBs] photoresist using laser printing
2004-09-18 by Adam Seychell
I've never personally seen this transfer foil. Once the foil has been
transfered, is the remaining foil just a negative of the image ? Maybe
it is possible to use the foil paper as a negative photomask after doing
the transfer. Just a thought.
Adam
Re: photoresist using laser printing
--- In Homebrew_PCBs@yahoogroups.com, Adam Seychell <a_seychell@y...>
doing
> Adam
The foil sticks to the toner.  so you print how you would normally
print onto the transparancy for the transfer, then you stick this foil
on top of the toner, and heat it.  The toner melts, and sticks to both
the transparancy and the foil.  Peel the sheet of foil away, and
wherever there was toner, there will now be foil on top.
Its used to make things metalic, like a seal on a certificate would be
gold or whatnot.
The remaining foil is probably trash, i seriously doubt it could be
used as a negative.
2004-09-18 by Leon Heller
Sent: Saturday, September 18, 2004 3:42 AM
Subject: [Homebrew_PCBs] photoresist using laser printing
My LJ 5P works very well for artwork. I print onto tracing paper and get
excellent results.
Leon
2004-09-18 by Bengt
Hi Leon,
what is *tracing paper* ?
Bengt
and get excellent results.
> Leon
Re: [Homebrew_PCBs] Re: photoresist using laser printing
Sent: Saturday, September 18, 2004 8:31 AM
Subject: [Homebrew_PCBs] Re: photoresist using laser printing
> Hi Leon,
It's thin semi-transparent paper that used to be used by draughtsmen for
tracing drawings. It should be available from most stationers, one near me
stocks it. It comes in A4 pads, these days.
Leon
Leon Heller, G1HSM
2004-09-19 by Bengt
Thanks Leon,
Now I know what you mean, is there any specific brand that is OK with
the the thermal *stress* of a laser printer? Dont want to get it to
melt on the fuser :) done that :(
Bengt
draughtsmen for tracing drawings. It should be available from most
stationers, one near me stocks it. It comes in A4 pads, these days.
> Leon
> Leon Heller, G1HSM
2004-09-19 by Leon Heller
Sent: Sunday, September 19, 2004 8:26 AM
> Thanks Leon,
It's paper, so won't melt. It's thin stuff, so might wrinkle. I cut it to
size and attach it to ordinary paper with a piece of masking tape. That way
I use less of it and it doesn't wrinkle. It is quite expensive, compared to
ordinary paper, probably because it isn't used much nowadays.
Leon
