Don't use paper towels
2004-09-10 by crankorgan
After you clean up your copper surfaces don't use a paper towel on
the copper. Air dry the copper. I was told if you rub the board with a
paper towel it leaves a coating. I think he said it was some kind of
silica? Maybe somebody he knows?
                                                 John
Re: [Homebrew_PCBs] Don't use paper towels
2004-09-10 by Leon Heller
Sent: Friday, September 10, 2004 1:15 PM
Subject: [Homebrew_PCBs] Don't use paper towels
Silicone oil, perhaps. It used to be used on the fuser roller in some Xerox
copiers. Don't get it in your eyes, it makes them sore for several hours
(speaking from experience).
Leon
Leon Heller, G1HSM
Re: Don't use paper towels
Thanks Leon! Now that makes sense. The mistake I was making was not
shaking the spray can of sensitizer. I can't tell you how many boards
I sprayed in the dark. I was allowed to use a small a red light. After
cleaning the board I would stand them up in the dark and spray them. I
then dried them using an old hair drier. The negative was that red cut
and peal stuff. I did some boards for a local college through a guy at
work. He got his degree and left our company without paying me!
--- In Homebrew_PCBs@yahoogroups.com, "Leon Heller" <leon_heller@h...>
wrote:
> From: "crankorgan" <john@k...>
some Xerox
hours
> Leon
> Leon Heller, G1HSM
2004-09-14 by mikezcnc
I called Bounty out of curiosity. I read before about the possibility
of paper contaminating my boards. Bounty checked with their chemical
engineers and no, there is nothing that could possibly transfer and
contaminate except for the paper that is printed!!!! The paint can be
dissolved and leave particles or even images as mentioned on the
packaging. Hopefully it helps.  Mike
not
boards
After
them. I
cut
at
<leon_heller@h...>
towel on
with a
kind of
> some Xerox
> hours
> > Leon
> > Leon Heller, G1HSM
2004-09-14 by Phil
I've been using paper towels all along and have never had a problem.
possibility
chemical
be
> not
> boards
> After
> them. I
red
> cut
guy
> at
> <leon_heller@h...>
> towel on
board
> with a
> kind of
> > some Xerox
several
> > hours
> > > Leon
> > > Leon Heller, G1HSM
2004-09-14 by crankorgan
Phil,
     It just hit me! Besides the paper towels I was also told to build
a rocking table instead of using bubbles. Less mess. I bought a AC
geared motor from Edmund Scientific. A simple cam on the motor shaft
lifted one end of the table creating a wave. The people who were
trying to help me had worked in a PC house that did goverment work. My
problem was I did no shake the little spray can of sensitizer. By
buying a board that was already coated I was able to figure out where
I was messing up. My negative was that red mask on clear. You cut the
red away and leave clear traces. I then bought the pads and trace
tape. They would be laid out on a clear sheet of plastic. I exposed
the board to my shop florescent light for 3 minutes. I think I was
suppose to use UV. A few months later people started using copiers.
      They also sold rub on traces back in those days. You had to wear
white gloves and use a wooden burnishing tool. The paper seemed waxy
and it had traces and pads on it. The same method as rub on lettering.
Some of the stuff was made by Calectro or some name like that. Radio
Shacks circuit board kit has alway been crap! I had to drive up the
highway for the good stuff. I used to by blue Vector perfboard weekly.
                                              John
> possibility
> chemical
> be
> > not
> > boards
> > After
> > them. I
> red
> > cut
> guy
> > at
> > <leon_heller@h...>
> > towel on
> board
> > with a
> > kind of
> > > some Xerox
> several
> > > hours
> > > > Leon
> > > > Leon Heller, G1HSM
So the answer would be, don't use paper towels that have printed
designs on them.
> not
> boards
> After
> them. I
> cut
> at
> <leon_heller@h...>
> towel on
> with a
> kind of
> > some Xerox
> > hours
> > > Leon
> > > Leon Heller, G1HSM
2004-09-15 by mikezcnc
Yes, that appears to be the story, at least from Bounty. I checked in
the family on that one and got the raised eyebrows. Oddly enough,
using I don't seem to have to clean as much using H200 as when I was
using the ironing process.  Mike
> designs on them.
possibility
chemical
and
can be
was
> > not
> > boards
light.
> > After
> > them. I
red
> > cut
guy
> > at
> > <leon_heller@h...>
paper
> > towel on
board
> > with a
some
> > kind of
in
> > > some Xerox
several
> > > hours
> > > > Leon
> > > > Leon Heller, G1HSM
