Inkjet printing of PCB's
2004-05-09 by mycroft2152
I've been following this thread for a while now and it has intrigued
me enough to sacrifice a Lexmark Z52 printer to convert it to a
straight through printer.
The major issues (IMHO) is in finding a resist that will: 1. flow
through the printhead, 2. wet out and print well on the copper
surface, and 3. will not be removed by the etchant.
After a visit to my dentist getting my teeth sealed yesterday, I
started thinking about uv-curable inks. In other words, a 2-step
process, printing the resist and then curing it.
I thought about getting some of the tooth sealer to try, but I
realised I was missing the obvious. We already have uv curable
fluids used for pcb making - the photoresists. I had used a couple
of time years ago and didn't get the results hoped for. I had used
the spray cans of resist to sensitize the boards.
I remember seeing on the web (forgot the link), a range of pcb
making chemical that were sold in apllicator bottles, like liquid
shoe polish. Has anyone used these? Any thoughts?
Myc
Re: [Homebrew_PCBs] Inkjet printing of PCB's
2004-05-09 by Stefan Trethan
On Sun, 09 May 2004 16:20:28 -0000, mycroft2152 <mycroft2152@...>
It's a thermal, i won't recommend it.
You can't use acrylic, and most likely you can't use anything else
than water based. You may try alcohol based.
Yes this is widely used in wide-format printing e.g on plastic.
It would be very good for PCBs.
I could not find a suitable ink. It must be inkjet ink becasue
the ink you get for screenprinting doesn't fit through.
They are not uv-curable, they are uv sensitive.
they don't solidify when exposed to UV. they are solvent based.
As said, no better than laquer, they are no uv cure, only uv sensitive.
> Myc
If you want to try your printer you should start with aluminium foil.
You have disposeable cartridges so no harm done if it doesn't work.
Get some alcohol based marker ink, and try it.
You must clean your cartridge good before trying it.
smell if it is ammonia (water based). try to flush all old ink out with
water,
maybe add windex (ammonia cleaner). then flush again to get pure water in
it.
(print a lot of black pages).
when you are confident that it is pure water empty it, and fill with
alcohol
(methylated spirits or something). let run a bit to fill all the head with
alcohol and get all water replaced.
the fill in permanent marker ink, diluted with alcohol 1:1. You may also
try
the metalworking blue, if it is alcohol solved.
then try printing. the alcohol will have a lower boiling point, but maybe
it is in the range that works. What may happen is that the heat of the
head makes
the nk clog, because only the alcohol is vaporized. then you are doomed
Again, i do not think it is possible to use a thermo-jet. do not try
acrylic floor
polish, i tried it and it doesn't work.
ST
Re: Inkjet printing of PCB's
Hi Stefan,
Thanks for the info. I've got a few old cartridges I can experiment
with. The Lexmark Z52 converted very easily to straight through
printing. A few screws and the paper guides were removed.
I'm not sure if the difference between uv-curable and uv-sensitive
is relevant since the uv resists that are 'only' uv-sensitive work
and are sold for that purpose.
I'm only suggesting their use for the etching process, not printing
legends. I currently print the legend with toner transfer on with
the release paper from labels.
Myc
Re: [Homebrew_PCBs] Re: Inkjet printing of PCB's
On Sun, 09 May 2004 17:26:17 -0000, mycroft2152 <mycroft2152@...>
wrote:
> Hi Stefan,
the flatbed conversion will never be a problem, even if the printer curls
the paper around 5 rollers and folds it afterwards to fit a emvelope.
the problem is the ink.
the chances are high you have done the conversion for nothing (welcome to
the club).
uv curable means the ink you inkjet on the copper solidifies when exposed
to UV.
it is some plastic polimerisation process.
UV sensitive means the ink changes it's properties, so that it can be
whashed
off by developer where exposed. It is a solvent based ink, which must dry
before
you can expose it. the solvent may even attack plastic.
I'm only saying you can't use any of the UV functionailty in resist laquer.
you could use standard laquer all the same.
I'm not sure about plastic compatibility.
good luck
ST
2004-05-10 by DJHaCK
it's not really related but would it work to replace the printer head
with a UV laser and "print" on a
uv-sensitive pcb , a bit like how laser printer work except without a
spinning mirror involved
>wrote:
>>Hi Stefan,
>the club).
>to UV.
>whashed
>before
>good luck
>ST
>Be sure to visit the group home and check for new Bookmarks and files:
>http://groups.yahoo.com/group/Homebrew_PCBs
>Yahoo! Groups Links
2004-05-10 by Stefan Trethan
On Sun, 09 May 2004 20:47:01 -0400, DJHaCK <djhack@...> wrote:
> Hi,
You are talking about a "photoplotter".
They are commercially available.
The probem is you would need to exchage all electronics.
I think it is not exactly the easiest approach as it involves coating with
resist
and developing, which makes it highly questionable if it is simpler than
TT.
of course the quality can be very good.
ST
2004-05-10 by mikezcnc
photoplotter...or imagesetter...using a UV diode because many of them
use a red LED. Jon Elson ha a website where he shows a home made
photoplotter and wrote his own software, quite an amazing design for
home applications. During last NAMES he showed me his PCB made using
this method on his own photoplotter and it is stunning razor sharp.
Jon uses a red LED and a red sensitive coating material but ther is
no technical problem to change it to UV if somone had good reason for
it. Like Stefan said, preparing the PCB for IR snesitive material
takes time and skill but the cost benefits are enormous. Using
Stefan's example I acquired a shoebox of PCBs and now it costs me
pennies on a dolalr to make them sensitive. If only Jon agreed to
sell his design of a photoplotter in form of plans... I saw him
writing on a Gecko group... What we need for this hobby is a
photoplotter. My adventure in getting a commercial unit to work is so
troublesome and expensive that I would rather build one from scratch
than going thru it again. Mike
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan
<stefan_trethan@g...> wrote:
> On Sun, 09 May 2004 20:47:01 -0400, DJHaCK <djhack@a...> wrote:
> > Hi,
head
without a
coating with
> resist
than
> TT.
> ST
2004-05-10 by Alexandre Souza
    Hummm...Link? I looked for Jon Elson on Google and got nothing on
photoplotting :o(
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.679 / Virus Database: 441 - Release Date: 07/05/04
2004-05-11 by mikezcnc
Here is Jon Elson's site. He is a fantastic guy and exceptionally
talented engineer. http://www.pico-systems.com/photoplot.html  Mike
--- In Homebrew_PCBs@yahoogroups.com, "Alexandre Souza" <alexandre-
them
for
on
> photoplotting :o(
2004-05-11 by Adam Seychell
I wonder how he processes the film in TOTAL darkness. Anyone know
where do you buy red light sensitive film  or how much it costs ?
I got quotes some time ago and it was around AUD$1000 for a pile
of sheets. Jon Elson notes that his plotter scans at 0.01"/sec
(0.25mm/sec), which works out to about 5 to 10 minutes for a
typical PCB at 25\ufffdm image resolution.
Adam
> them
> for
> on
>>photoplotting :o(
