Homebrew_PCBs
Archive for Homebrew_PCBs.
slikscreen
slikscreen
2004-04-19 by lostwabbit2001
how can i make a componit silkscreen for a pcb? Thank you
Re: [Homebrew_PCBs] slikscreen
2004-04-19 by Stefan Trethan
On Mon, 19 Apr 2004 02:22:19 -0000, lostwabbit2001
perhaps with silkscreen printing ? ;-)
3 other ideas that spring to mind:
Plotter (multicolor, slow)
toner transfer (black, maybe slightly conductive)
various "transfer sheets" like t-shirt transfer
ST
Re: [Homebrew_PCBs] silkscreen
2004-04-19 by John Johnson
On one board I did, I printed the silkscreen layer on my ink jet onto
paper. When the board was finished and inspected, I glued it down on
top of the board using a glue stick, spray adhesive would work too.
Component legs go through the paper. Looks pretty good, actually.
JJ
> Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark
> Printer at MyInks.com. Free s/h on orders $50 or more to the US &
> Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/bGYolB/TM
> Be sure to visit the group home and check for new Bookmarks and files:
2004-04-19 by Leon Heller
Sent: Monday, April 19, 2004 11:40 AM
Subject: Re: [Homebrew_PCBs] silkscreen
Not much good for SMD, though. 8-)
Leon
Re: component ledgends --was silkscreen
2004-04-19 by wheedal99
I remember someone suggesting ink jet "water slip" paper that
modelers use for decals. That would get you color as well as speed.
Still would have difficulty doing smt --although you can solder
through it.
How wide tracks
2004-04-20 by Anthony Toft
is there a formula for how wide tracks should be? I need to make
tracks capable of carrying 7+A at 12v How fat should they be?
Anthony Toft <toftat@...>
Re: How wide tracks
2004-04-20 by ballendo
Hello,
The ""bible" for pcb design is "Printed Circuits Design" by Gerald
Ginsberg. Published by McGraw Hill, I paid 5 bucks for myt copy of
the '91 edition. You can pick up a copy inexpensively at ABEBOOKS.com
or similar.
Another decent book is Tim Williams, "The Circuit Designers Companion"
Ginsbergs book has several nomographs, one of which answers what
you've asked. But there ar additional considerations. Is the trace by
itself--means away from other traces? How much temperature rise can
you allow? Is the trace on an internal or external layer? What is the
copper "ounce" rating?
From page 40, the three nomographs will get you where you need to be.
Assuming external layer, nothing REALLY close by, and a worst case
temp rise of 60 degrees C. 7 amps requires a 70mil cross section.
With one ounce copper, that's a trace about .053 wide... With 2 oz.,
you need .028-.030 width.
At 20 degrees rise, you need 150 cross mils. So that's a trace
about .120 wide in 1 oz. copper. In 2 oz., it's only .060 wide.
Hope this helps,
Ballendo
P.S. Did you try putting "required PCB trace width" into a search
engine?
FWIW, there is a formula, but the nomographs are easier to use. The
formula is in ANSI/IPC D-949
--- In Homebrew_PCBs@yahoogroups.com, Anthony Toft <toftat@c...>
Re: [Homebrew_PCBs] How wide tracks
2004-04-20 by Stefan Trethan
You can find such things in "design rules" in the links section.
ST
On Mon, 19 Apr 2004 22:32:37 -0400, Anthony Toft <toftat@...>
Re: [Homebrew_PCBs] Re: How wide tracks
> What is the
I ask this question myself pretty often.
Which genius had the idea to measure a layer thickness in weight?
What is is? oz/sq feet, or sq inch, or whatever?
I have no idea at all ow much1 oz is.
Of course i can find out.
I really hate to annoy you but i also really hate the imperial units
system.
please try to at least write the complete unit if you need to use imperial
units.
the standard thicknesses in metric system are 18um, 35um and i think 72um.
which are micrometer, happenig to be 1m divided by 1000000 or 0,001mm
isn't that nice?
I wonder if i will live to the day when we finally all use 1 units system.
ST
Re: How wide tracks - link to calculator
2004-04-20 by Dave Mucha
--- In Homebrew_PCBs@yahoogroups.com, "Phil" <phil1960us@y...> wrote:
http://www.geocities.com/CapeCanaveral/Lab/9643/TraceWidth.htm
Yup,
that's the calculator I use too.
Don't forget that you can tin the trace and make it thicker or lay a
copper wire on it and tin that and make a fat trace. Also, some
people use both the top and bottom of the board for beefing up power
traces.
I did a stepper motor driver and used a second board, kinda like a
home-brew 4 sided board and ran huge pins to connect the two boards.
Dave
Re: How wide tracks
2004-04-20 by Steve
> 1 gram is 0.03527396 ounces.
Yes, but how thick is that? 1 ounce / square inch? If so, how thick is
that? 1 ounce / square foot?
Steve
Re: [Homebrew_PCBs] Re: How wide tracks - link to calculator
But don't do that with HF currents, the skin effect will displace
your current to the wall and you effectively increase the resistance.
Have read this somewhere - they have tried but i don't remember where.
ST
> Regards
> Marvin Dickens
Thank you very much Marvin, i thought the line "of course i can find out"
would prevent people from being too helpful...
I know it is simple to convert units with google.
thanks anyway ;-)
ST
> Steve
well, you need the specific gravity...
In metric system even that would be darn easy...
thanks for putting the calc int he links section steve.
Found the following on the page i listed there:
(Remark: 1 oz = > 35µ; 2 oz => 70µ; 3 oz => 105µ Cu)
don't you have 18u boards?
i think they are mainly intended for plating but i have a huge amount of
them
and don't plate them. they work sufficiently for the low current stuff, and
they etch faster.
ST
2004-04-20 by mpdickens
Both systems are taught in the schools here in
America, so I knew the answer without thinking about
it. Besides, I could not help myself when I saw your
post ;)
Regards
Marvin Dickens
Registered Linux User No. 80253
If you use linux, get counted at:
http://www.linuxcounter.org
Do you Yahoo!?
Yahoo! Photos: High-quality 4x6 digital prints for 25�
http://photos.yahoo.com/ph/print_splash
> post ;)
> Regards
> Marvin Dickens
Come on Marvin, you ain't knowing the conversion ratio from gram to ounces
with 8 decimals after the comma, "without thinking"?
I bet one free google search you looked that one up 8-)
ST
2004-04-20 by John Johnson
> system.
Man I hope so. This is getting really old. Inches have been based on SI
since 1887 or so.
JJ
> If so, how thick is
Using the weight per square inch (Or centimeter or
whatever) the thickness can easily be determined.
Regards
Marvin Dickens
Do you Yahoo!?
2004-04-21 by mpdickens
> 8-)
You got me on that one: I keep a cheat sheet with the
fractions that I would have a reason to use and are
rediculously long :)
Marvin
Do you Yahoo!?
2004-04-21 by ballendo
>In Homebrew_PCBs, "Dave Mucha" <dave_mucha@y...> wrote:
>Also, some people use both the top and bottom of the board for
>beefing up power traces.
Be careful! You're making capacitors...
Ballendo
2004-04-21 by Stefan Trethan
> Ballendo
shorted capacitors... wow.. wonder what the capacitance may be.. must be
huge..
ST
2004-04-21 by Vasile Surducan
actually this wouldn't be an impediment but an improvement for the
supply lines...
top 10 wishes,
Vasile
http://surducan.netfirms.com
RE: [Homebrew_PCBs] Re: How wide tracks - botom and top layer = 1 conductor?
2004-04-21 by Willy Gooris
Do you really think You make capacitors? I thought that the definition
of a capacitor is: two conductors separated by a nonconductor. The last
part is trough, but the said 2 conductors are not two conductors, but
one conductor split in two pads (bottom- and top layer) because on
either end and even on other places where they are soldered together. At
VERY high frequencies this might be not completely right thou.
Sent: woensdag 21 april 2004 9:21
Subject: [Homebrew_PCBs] Re: How wide tracks - link to calculator
Ballendo
Yahoo! Groups Links
2004-04-21 by Phil
Maybe an inductor...
However, I think the reasoning goes - if you are making one "trace"
(er connection) that can carry a lot of current, you will need a
return path of similar capacity *somewhere*. Now, if those two are
of a large area and happen to be on opposite sides of the board you
WILL get a capacitor that may need to be taken into account in the
design.
Watching out for board level capacitance is worthwhile.
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan
> > Ballendo
must be
> huge..
> ST
