Homebrew_PCBs
Home-Brew CNC PCB Drill
2004-03-24 by Jan Rowland
I had been thinking I had ALREADY added this [subject] photo to the
group, but, well, guess it's Alzheimer's! This quill has a 400 Hz.
12,000 RPM AC motor in it. Some machining to replace 1/4" shaft
on "bottom end" of motor with 1/8" collet/nut! And ABEC-7 bearings.
That "quill motor" is powered by simple "push-pull" 400 Hz
multivibrator and 95 VA transformer purpose-wound for the
application. I had used the old PET you see for years, but the last
of several I had on hand finally gave-in to alpha-particles, so I'm
slowly getting around to converting the 8-bit interface (yep, just a
9-wire cable to puter!) to work through a PC parallel printer-port.
The little blue motor atop the quill is a Slo-Syn 72 RPM SS-25 that
rolls a tiny cam-follower roller around a 1/4" pitch helix. So the
quill-travel is abotu 0.24". The quill can "do a hole" or "go down
and stay until told to return to "home". This latter way, the
machine can engrave.
The screws are 1/2" lead (1/8" pitch/4-start) stub-ACME. Thomson
linear ball-bearings/ways. Baltic birch base. Formica-covered top.
Can do about 3000 holes per hour, drill-rate. (one bit-size! Takes
time to change bits!) Jan Rowland
Re: Home-Brew CNC PCB Drill
2004-03-24 by Steve
Must be that time of year. Wasn't it the same time last year? ;')
I moved it to Files when you first uploaded it to Photos, because
Photos will only allow everyone (but the moderator and the uploader)
to see a puny 300x400 image. And I wanted everyone to see it well, as
it is a very nice setup. I'm going to leave it in Photos with a note
to check Files for a closer view and more details.
It's here as an 800x600 image along with a GIF of the 400Hz generator
to drive the quill motor and a text file describing it:
<http://groups.yahoo.com/group/Homebrew_PCBs/files/Homemade%20PCB%20equipment/>
Very cool, an old Commodore PET computer controls it. Or controlled.
Hey, Jan, do you think it would be difficult to tranfer the program to
a Commodore 64? They are pretty plentiful, I'm in a Commodore64/Amiga
club and can probably find one for you cheap or cost of postage.
Please feel free to upload more details to that folder in Files.
Steve
Re: [Homebrew_PCBs] Re: Home-Brew CNC PCB Drill
2004-03-25 by JanRwl@AOL.COM
In a message dated 3/24/2004 6:17:49 PM Central Standard Time,
alienrelics@... writes:
Ah, yes! Forgive, Steve! Alzheimer's, doncha know! I will remove it from
Photos. Jan R.
