Homebrew_PCBs
Index last updated: 2026-03-30 17:29 UTC
Roll Tinning Machine Cont.
2004-03-04 by gmanca101
Well, after much research and discussion, I've found how these
machines really work. Apparently, the bottom roller is a steel(or
covered) roller that is partially submerged in a solder bath. What
prevents the solder from building up on the steel roller is the
addition of Solder Salts that help to coat a thin layer of solder on
the roller. Then the top roller is usually made of silicon rubber and
the more pressure placed between the two rollers, the thinner the
layer of solder on the pc board. Of course, the cost of this machine
should be minimal seeing as how the main cost of use is the salts and
the replenishment of solder. The ability to acquire cheap salts is
the daunting task; anyone have any ideas on that? I think that the
machine can be homebrewed and be cheaper then TiNNiT and lasts longer
as well.
Re: [Homebrew_PCBs] Roll Tinning Machine Cont.
2004-03-04 by Stefan Trethan
> as well.
OK, you build one and then i copy it ;-)
But i simply have no space for such a giant machine like it was showed in
the pictures,
it must be small....
It would be practical to have it, but i do not know when time allows to
even think
about building one.
ST
2004-03-04 by Alan King
> as well.
Not sure about the more modern stuff, but plenty of older printers etc had a
solid steel core for the platen. Strip the rubber off and one may work fine,
and another with the rubber for the top roller.
May be quite useable if everything is very cheap. If not then only those
with med/high quantity of boards could justify it, it'll represent 10 years
worth of Tinnit for many if there's much cost to it.
And if they're not particularly special, the salts can be found after the
fact for cheap. Hunt down a bulk supplier and they shouldn't be too big an
issue, finding them may take some time though. $2-$3 a pound for bulk and no
doubt solder will be cheaper, and it doesn't go bad very fast either.
There are also many methods to deal with solder, like a thin layer of oil on
top to keep it from oxidizing etc. With a little experimentation there may be
ways other than the salts that are more cost/ease effective for home use.
Also there is always the frying pan dip soldering, it works well enough for
soldering components and should really do well enough for most people's solder
plating too for low quantities. A friend has a commercial machine built around
the same basic principle, it works very well for both uses.
Alan
> etc had a
> fine,
I think you will need heat resistant rubber, like in a laser printer fuser.
but this may still be not enough, maybe one can mold it with heat resistant
silicone.
> enough for
> solder
> around
I wonder if there is not too much tin built up on the tracks.
more description please.
ST
> Alan
