Homebrew_PCBs
Archive for Homebrew_PCBs.
looking for a water heater
2004-03-03 by mumin55555
HALLO!
im want to buy a water heater for the etching tank i am building.
my problem is: no aquarioum heater thermostat goes more then 34
degrees c, while i need about 60 i think- for ammounium phersulphate.
what can i do?
thanks a lot
mumin
Re: looking for a water heater
2004-03-03 by gk_impala
Hello mumin,
If you are not too afraid of opening the Aquarium heaters, you can
modify them to do higher temperatures.
I just modified one to go till 45 degrees C, but it during testing it
also did 50 degrees, and probably more.
I just bought the cheapest one in the shop, called AquaEL, in my case
100 W.
They work using a bi-metal element, which will bend more when heated,
and thus acting like a relay. Adjust the distance to the contact, and
it will switch on higher temperatures. They are just set on a fixed
range.
However, some will be easier to adjust / open up then others,
so there is no quarantee with all makes.
Best bet is with older rubber closed tops, which can be easier opened.
Gertjan
--- In Homebrew_PCBs@yahoogroups.com, "mumin55555" <MUMIN55555@H...>
wrote:
> HALLO!
phersulphate.
> what can i do?
> thanks a lot
> mumin
Re: [Homebrew_PCBs] looking for a water heater
2004-03-03 by Stefan Trethan
On Wed, 03 Mar 2004 16:30:16 -0000, mumin55555 <MUMIN55555@...>
wrote:
> HALLO!
> what can i do?
> thanks a lot
> mumin
tweak it ;-)
"more power"...
or make it yourself from a lab glass tube and some resistance wire.
most likely cheaper and maybe you can not take the commercial unit
apart without damage.
i filled the glass tube with silicone, thermal epoxy would be better.
however i do not use the heater (HCl and H2O2 needs none).
you could also glue a "second floor" in your etch tank and put the heating
wire there,
or a heating plate. (depends on tank material also).
ST
2004-03-03 by Phil
I not sure why you need such a high temperature. I just got done
etching 3 boards in AP using an aquarium heater cranked all the way
up. The first one took about 25 minutes because I was unwilling to
wait for a full warm up. Once the temp reached the high point (about
100 F), etching took about 10 minutes. I also use a bubbler and that
speeds it along.
I'm not sure how I feel about AP in general but it was really cool to
watch the light start to come through the boards. try that with
swamp water, er, FeCl...
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan
<stefan_trethan@g...> wrote:
> On Wed, 03 Mar 2004 16:30:16 -0000, mumin55555 <MUMIN55555@H...>
> wrote:
> > HALLO!
phersulphate.
> > what can i do?
> > thanks a lot
> > mumin
> tweak it ;-)
> "more power"...
better.
heating
> wire there,
> ST
Re: [Homebrew_PCBs] Re: looking for a water heater
2004-03-04 by Alan King
gk_impala wrote:
> Hello mumin,
> range.
Yep with liquid immersion, you should really be able to just bypass the
switch and have the element on the full time. Should work fine since with a
large aquarium and small heater it'll basically be on the whole time anyway, but
I think there is a limit of good return on the heat, after a certain point some
etchants become worse in some respects like etching too fast with too much
undercutting etc.
Alan
2004-03-04 by Ben H. Lanmon
phersulphate.
I use aquarioum heaters in my etch tank of Ferric Chloride, you can
more less bypass the thermostat. Mine have a plastic cap on top
that covers the thermostat control. It will have a stop on it but
you can bypass it and turn it up more. I have two in a 5 gal. tank
and heats it up to over 120 deg.F. that is as high as I can measure
so not sure about what the real temp. is. Takes it a little while
to get it there but they will get it plenty hot. Well etch a 8" x
10" or 8" x 12" board in less than 8 mins.
The heater that I have I got at Wal Mart.
Ben
2004-03-04 by Dave Mucha
wrote:
> HALLO!
phersulphate.
> what can i do?
> thanks a lot
> mumin
If you want cheap, try a warming plate for kitchens.
if you want really cheap, try an old coffee maker warming plate. It
may be small, but will get your fluid pretty hot.
Dave
