Datak negative Resist Success
2004-01-09 by ednspace
Thanks to all who answered questions earlier I finally have made some
success with Negative photo resist method. After about a month of
trial and errors I have two nicely etched boards.
Points I changed were:
Better UV light the recommended (ER-2000)
Longer drying times after coating blank with the resist
Shorter developing times.
Better negative now using overhead type laser copy instead of oil
brushed tracing paper.
Now I just need to get some new developer since I have wasted so much
of what I had and probably a little bake oven to dry the emulsion
both after I coat and before I etch.
The only problem I am having is that the resist comes very close to
dissolving in the etchent before the rest of the board is etched
away. Are there other etchents that may be more suitably matched to
this resist or should I just concentrate on drying it very well
before etching and after the developing.
Using ferric chloride with etch times of about 8min warm in bubbles
Again thanks so much to all who offered pointers and helped,
this is a great list, and wonderful to know there are others out
there working through similar issues.
Finally I can make something again :)
ED
ED
