Homebrew_PCBs
Archive for Homebrew_PCBs.
Question about etching pcb's
2018-04-07 by r.d. terramir
Copper clad board using muriatic acid would like to find better than 3% hydrogen peroxide if possible. In the usa LA california to be exact.
Also what are some of the better methods of making a pcb cheaply
BTW if needed I have 99 uv led on a circuit board built that a while ago just would need a cheap uv kinda etch resist suggestions welcome there.
terramir
Re: [Homebrew_PCBs] Question about etching pcb's
2018-04-07 by Keith B
Look for clear hair bleach. I think it's around 12% (40 deg. Baume?);
strong enough to burn your bare hands.
I understand janatorial supply shops have it even stronger, but it
starts to get dangerous and these days may find the police checking
you out.
I got mine from the local Sally Beauty Supply.
In this part of the US they seem to show up
near WalMarts.
>terramir
This email has been checked for viruses by AVG.
http://www.avg.com
RE: [Homebrew_PCBs] Question about etching pcb's
2018-04-07 by keith printy
Volume 40 developer for hair dye is about 12%
Lower volume numbers of course have less peroxide in them
Sent: Saturday, April 07, 2018 5:23 PM
Subject: Re: [Homebrew_PCBs] Question about etching pcb's
you out.
near WalMarts.
>terramir
http://www.avg.com
Re: [Homebrew_PCBs] Question about etching pcb's how different is 12%
2018-04-08 by Rob
So what is the advantage of using 12% peroxide instead of the drugstore 3% peroxide?
I use 50ml of muriatic acid mixed into 100ml  of drugstore peroxide.
All of my etching is done in about 4 or 5 minutes.
http://www.learnmorsecode.com/laminator/hotcakes.html
http://www.learnmorsecode.com/ch/index.html
http://www.learnmorsecode.com/DC/index.html
Rob KB3BYT
you out.
near WalMarts.
>terramir
http://www.avg.com
2018-04-08 by Keith B
For single use the 3% just adds more water.
If you are doing the copper chloride bit
the 3% tends to add too much water and over
time upsets the chemistry.
I'm a newby, I've only been using my original
batch of CuCl for five or six years.
>3% peroxide?
>Rob KB3BYT
>> you out.
>> near WalMarts.
>> >terramir
>> http://www.avg.com
2018-04-08 by Rob
What do you mean by
" If you are doing the copper chloride bit"
>3% peroxide?
>Rob KB3BYT
>> you out.
>> near WalMarts.
>> >terramir
>> http://www.avg.com
2018-04-08 by Harvey White
On Sun, 8 Apr 2018 13:52:44 -0400, you wrote:
>What do you mean by
Peroxide/hydrochloric (muriatic) acid works well until the oxygen
provided by the peroxide runs out. The remnants are copper chloride
(CuCl). It will not etch a board by itself (Ferric chloride does
this, eventually, I think). However, by bubbling air through the
solution, the extra oxygen will allow etching. Perhaps a bit slower,
but it does etch. This particular solution has an indefinite life,
but needs to be adjusted every now and then for additional acid.
Adding peroxide simply goes back to the original solution if you add
enough.
If you look at the etching process in a clear solution, you will see
the copper turn dark in waves, this is the copper being oxidized by
the etchant.
Harvey
>> >3% peroxide?
>> >Rob KB3BYT
>> >> you out.
>> >> near WalMarts.
>> than 3%
>> while ago
>> there.
>> >> >terramir
>> >> http://www.avg.com
2018-04-08 by Rob
Thank you.
I was not reusing solutions.
And... I was not using a bubbler.
I am more of a hobbyist.... not doing high production... so I never pursued
how to reuse and revitalize the solution.
>What do you mean by
enough.
the etchant.
Harvey
>> >3% peroxide?
>> >Rob KB3BYT
>> >> you out.
>> >> near WalMarts.
>> than 3%
>> while ago
>> there.
>> >> >terramir
>> >> http://www.avg.com
On Sun, 8 Apr 2018 15:03:03 -0400, you wrote:
>Thank you.
If you do one or two at a time, that's one thing. I generally did a
run of 5-10 double sided boards at a time, simply because the setup to
clean the boards, etch them and so on was time consuming. I actually
got more done that way than trying to set up for a board, then three
days later, perhaps another one.
As long as the peroxide solution is fresh, you don't need a bubbler.
Mine was left over from the ferric chloride days, and then CuCl.
Harvey
>> >What do you mean by
>> enough.
>> the etchant.
>> Harvey
>> drugstore
>> >> >3% peroxide?
>> >> >Rob KB3BYT
>> [Homebrew_PCBs]
>> Baume?);
>> >> >> you out.
>> >> >> near WalMarts.
>> >> than 3%
>> exact.
>> >> while ago
>> >> there.
>> >> >> >terramir
>> >> >> http://www.avg.com
Re: Question about etching pcb's
2018-04-08 by cs6061@...
The hydroponic folks use 30% H202 to clean equipment etc.  It's available on line from Walmart, Amazon etc but it's seems rather expensive  at  around $23 per liter.
I used to do a lot of etching, mostly with ammonium persulfate, but these days I can can't justify doing it my self anymore.  Just got two boards done via JLCPCB in China, got 10 copies of each board for a total order price of $7.00. One board was $2 ( 3" x 3.5" two layer double sided .062 FR4) the other was $5 ( 2"  x 3.3" but .032" FR4).  The quality and delivery time (5 days) was superb.  I can't buy the raw stock for that price.  I don't know how they can make any money at those prices.
Craig
Re: [Homebrew_PCBs] Re: Question about etching pcb's
2018-04-08 by Rob
My 70mmX100mm PCBs cost 40 cents each.
The time saved is really where I value printing my own PCBs.
AND
there is one more advantage to printing your own PCBs...caveman electronics style.
HUGE traces.. I can see with my gnarly vision.
Most of my traces are more than 1/8th inch wide.  I don't measure traces in MILs.
So if I make a mistake or want to experiment I can just plain drill another hole and always
find copper.
http://www.learnmorsecode.com/regen/04bottom.jpg
which makes for parts layout wide enough to actually not trip over parts:
http://www.learnmorsecode.com/regen/04top.jpg
http://www.learnmorsecode.com/regen/00regen.html
Craig
2018-04-09 by alienrelics@...
Please do not call it "bleach", it is not chlorine, it is hydrogen peroxide.
Someone coming across this thread may be confused by this. I have no idea what would happen if chlorine bleach and hydrochloric acid were mixed.
Steve Greenfield AE7HD
you out.
near WalMarts.
2018-04-09 by Brad Thompson
Hello--
A Wiki search states...
"The chemical equation for bleach and hydrochloric acid is as follows:
NaClO + 2 HCl ----> Cl2 + H2O + NaCl. In other words, sodium
hypochlorite and hydrochloric acid make saltwater and chlorine gas. ...
Chlorine gas is highly reactive because the bond between the two
chlorine atoms is weak..."
(According to various news outlets, Syria's Assad regime is using
chlorine gas or
another related weaponized chlorine compound against civilians, causing many
casualties.)
Under NO circumstances should you mix these chemicals to use an an
experimental
PC-board etchant!
73--
Brad AA1IP
2018-04-09 by Norm
As a beauticians product, it IS a bleach - HAIR bleach, as the writer specified.  It is not LAUNDRY bleach.  Just as not all acids are HCl, not all bleaches are chlorine based.
Norm  w6nim
you out.
near WalMarts.
Virus-free. www.avg.com
2018-04-09 by Harvey White
Perhaps not all people would make that distinction.
Harvey
>Norm  w6nim
>> peroxide.
>> mixed.
>> you out.
>> near WalMarts.
>http://www.avg.com
